Go to Post You mean nobody else has picked up on the hint about next year's game being called "Whack the Billfred"? - EricH [more]
Unread 18-04-2014, 17:42
RMS of OPR residuals at MSC
By request, attached is a chart that shows the RMS of the OPR residuals vector vs number of matches N played at MSC Quals.
A is the 256-by-64 binary design matrix of the alliances in Qual match schedule.
b is the 256-by-1 column vector of alliance scores for those Qual matches.
x is the 64-by-1 column vector of OPR values based on the first N matches in the Qual schedule. For MSC, N varies from 32 to 128. For N less than 32, the A matrix is singular.
For each of the 97 OPR vectors (for N=32 to 128), the RMS value of the vector of residuals Ax-b is calculated and plotted vs N.
Name:	RMS of Ax-b OPR residuals vs Matches at MSC.png
Unread 19-04-2014, 14:46
Re: RMS of OPR residuals at MSC
By request, attached is a chart that shows the RMS of the OPR residuals vectors vs number of matches N played at WAMOU Quals.
WAMOU had only 28 teams and there were 56 Qual matches.
Name:	RMS of OPR Ax-b at WAMOU.png
Unread 19-04-2014, 14:58
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Any chance you could do the same, but leave out the residuals of the previous matches? I doubt it would differ very much, but it's the real life situation: after X matches, how far off are the rest of the predictions going to be.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 19-04-2014, 16:39
Attached is a chart for MSC that shows the average of the absolute deviation of the partial OPR vectors (based on the first N qual matches) compared to the final OPR vector.
Name:	MSC OPR deviation.png
Unread 19-04-2014, 16:49
After posting the first 2 graphs, I decided that a more intuitive way to see what's going on (for FRC purposes) might be to compare the partial OPRs (based on the first N matches) to the final OPR. This way it's easier to see how the partial OPRs are converging to the final OPR.
Unread 19-04-2014, 16:54
WAMOU average of the absolute deviation of the partial OPR vectors (based on the first N qual matches) compared to the final OPR vector.
Name:	WAMOU OPR deviation.png
Unread 19-04-2014, 17:04
SCMB average of the absolute deviation of the partial OPR vectors (based on the first N qual matches) compared to the final OPR vector.
Name:	SCMB OPR deviation.png
