Go to Post There is no charge. We just want to help. We are family… - emnasson303 [more]
Unread 19-04-2014, 12:47
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
CNC Router for Aluminum
We're in the market for a CNC router. For the most part this will be used for FRC which means lots of cutting aluminum plate (.125") and plastic. I know aluminum can be somewhat of a challenge. With that in mind what are your thoughts on the best 48" x 48" units out there that can be had for under $15K delivered?
We're looking at the ShopBot Buddy http://www.shopbottools.com/mProducts/shopbot_buddy.htm
and ShopBot Standard http://www.shopbottools.com/mProducts/prSstandard.htm
The Romax was recommended but it's build area is a little smaller than we'd like. http://romaxxcncrouters.com/store#!/...&sort=no rmal
I know we could make such a thing given enough effort. This is coming from a source, though, where we need to buy new.
Given that a lot of aluminum is in our future, are there better options?
Unread 19-04-2014, 13:09
DonRotolo's Avatar
Back to humble
FRC #0832
Re: CNC Router for Aluminum
I have nothing but high praise for the ShopBot stuff. The 48" wide BT48 Buddy PRSstandard is a good size at 24 x 48 (unlikely you'll need to cut larger than that), and they definitely offer discounts to schools. The software they bundle with it - Vectric Vcarve Pro and PartWorks 3D are both powerful and intuitive, and work with SolidWorks and Inventor quite well.
the Alpha series uses close loop motors, and you're unlikely to need that for a robotics team or school. Open-loop steppers are sufficient for anything but the production environment.
With the router provided you'll be able to cut Aluminum (or wood or plastic) with the correct bit. Not super fast, but fast enough. For aluminum you should consider a mist coolant system and a vacuum dust/chip management system.
If you go for the spindle option, you'll gain some flexibility (because the spindle can spin at slower speeds than the router) but not a lot more cutting power. For me personally I would opt for the router, but for a school getting the funding for a spindle afterwards might be more hassle that it is worth.
If you can, definitely take their training. You will absolutely have to teach 2 or 3 kids each year to run and maintain the machine, somewhat like a lathe or mill, it is a complex and sensitive machine requiring some skill and knowledge to avoid damage or injury. Their training goes into a lot of detail, giving you a foundation for student lessons.
Also, give the ShopBot folks a call. They are happy to talk machining and can steer you in the right direction.
I know you need to buy new, so I won't mention the various 'kits' out there, but for others who might not be limited, one can build a machine similar to the 48 Buddy Standard for about $5k, including software & computer. I recommend the KRMx02 (Google it).
Unread 19-04-2014, 13:57
Jared's Avatar
Jared Jared is offline
We have a 4' x 8' shopbot with the spindle that we love. We've made a bunch of stuff on it, and we've used it with wood, foam, plastic, and up to .125 aluminum. The included partworks software is really powerful, but it's much easier to use than a normal CAM package. We've just started using Partworks 3d, which looks great too.
It took us a little while to figure out the best way to cut aluminum. Ours has the spindle, which has no trouble cutting aluminum. We've considered using the mist coolant, but the stuff smells bad and stays in the air, so we just squirt normal coolant on the bit as the thing cuts, and we don't use liquid coolant on thinner aluminum. We do use compressed air, through a vortex tube to cool the air, that helps get the chips out of the way.
The trick that we've found for cutting aluminum is not to go slow. We use an Onsrud O Single Flute aluminum bit, and go about 100 ipm through .125 plate, and I think the spindle rpm is near 14,000.
We have had one little issue with the bundled software. We've been exporting our part to cut as a PDF, then importing that PDF file in Partworks, and occasionally, it gets a little messed up with an edge in the wrong spot.
Unread 19-04-2014, 14:17
dipmeinaluminum's Avatar
dipmeinaluminum dipmeinaluminum is offline
Michael Vilarelle Mentor
AKA: (Former Mentor 354 Westinghouse Pirates)
FRC #0333 (The Megalodons)
dipmeinaluminum is a splendid one to beholddipmeinaluminum is a splendid one to beholddipmeinaluminum is a splendid one to beholddipmeinaluminum is a splendid one to beholddipmeinaluminum is a splendid one to beholddipmeinaluminum is a splendid one to beholddipmeinaluminum is a splendid one to behold
So THIS is the secret to how all your robots look AMAZING!!! LOL
This is awesome! Now I just have to fine the money in the teams couch in the shop...THANKS!
Team#333 (2013-Present)
Team#354 (2000-2013)
https://www.youtube.com/watch?v=Bu5-NvMUQ-Y
Unread 19-04-2014, 17:09
cxcad cxcad is offline
FRC #1683 (Techno Titans)
cxcad will become famous soon enoughcxcad will become famous soon enough
Dumb question: can a router be used like a mill to make wheels and cut box tubing?
Unread 19-04-2014, 17:51
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
What are the power requirements for these machines (Shopbot & KRMx02)? I'm wondering if they can run on a single 120v 20A circuit.
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 19-04-2014, 17:52
Aroki's Avatar
Aroki Aroki is offline
FRC #1787 (Flying Circuits)
Team Role: CAD
Aroki will become famous soon enoughAroki will become famous soon enough
If you made really shallow passes probably, routers spin at much higher speed (and lower toques) and struggle if you try to cut to much off.
Unread 19-04-2014, 20:04
DonRotolo's Avatar
Back to humble
FRC #0832
Yes, albeit much more slowly than a mill. Also, you are limited by the kinds of bits available (since a router spins much too fast for an end mill) and how far they can stick out from the router nose.
Similar for box tubing: The reach of the bit is limited.
Typical limit is about an inch in aluminum.
Unread 19-04-2014, 20:07
Dale's Avatar
Head Coach & Mentor
AKA: Dale Yocum
Thanks Don for the great info. Do you (or anyone else) have an opinion on the ShopBot Buddy, with it's moving work surface, vs the standard gantry ShopBot? Is one more accurate, versatile, or less fussy than another for FRC applications?
Unread 19-04-2014, 20:16
Dale's Avatar
Head Coach & Mentor
AKA: Dale Yocum
They run on 120V 20A with the router. The spindles often need 240V
Unread 19-04-2014, 21:18
FRC #1836 (MilkenKnights)
As you said, solids are hard to do on a cnc router becuase they don't remove material all that quickly. That said, I have heard that 973 has used their router to do box tubing. However, they did make the router themselves, and it is quite beefy. Even then, I don't believe they run a lot of their tube through it.
Unread 19-04-2014, 21:48
My team has a sheet metal sponsor. Would it be worth it to get a router or a CNC mill? We already have a lathe.
Unread 19-04-2014, 22:28
m1506m's Avatar
m1506m m1506m is offline
FRC #1506
m1506m is an unknown quantity at this point
Cool that this thread came up, I just talked our money guys into a cnc router, but I'm looking for a 4x4 of the kit variety that our kids can put together for a summer project.
Unread 19-04-2014, 23:07
Coach Norm Coach Norm is offline
Team 2468 Coach/Adviser
AKA: Norman Morgan
FRC #2468 (Team Appreciate)
Coach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond repute
We purchased this machine in the Fall and ran it this spring for gussetts, box tubing, aluminum, plastic, lexan, etc. http://probotix.com/FireBall_Meteor_cnc_router/
I believe that Lin will be in St. Louis for the Championships.
We ran ends for nearly all of our jobs this year in the 1/8" and 1/4" variety on mostly aluminum.
I would advise getting a Super PID to make the machine more user friendly.
We purchased the Mesh Cam and ArtCam softwares for the machine.
I would highly recommend this machine.
Norman
FRC 2468 Team Lead 2008 - Present
Win The Day!
Unread 19-04-2014, 23:27
jman4747's Avatar
AKA: Josh
Team Role: CAD
Norman
What spindle/router do you use?
#banthebag
#RIBMEATS
#1620
