Go to Post If it gets people talking about not only robots but science and technology, it's all good. - Koko Ed [more]
Unread 19-04-2014, 07:40
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Re: OH SNAP! Belt failures 2014
Here's a picture of two of our belts that failed:
http://farm4.static.flickr.com/3781/...6ec44e388b.jpg
We figured that the carpet thread wound itself around the drive pulley and increased it diameter, of said pulley, which caused the belts to tighten up and break.
I asked the student if they didn't notice that the field was disappearing from behind them
During the finals at St. Louis, we broke several drive belts. The last very last match we played with only 3 drive belts instead of 4. We won St. Louis.
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 19-04-2014, 11:06
Pretzel Pretzel is offline
Ex-Driver
AKA: Tyler
FRC #1619 (Up-A-Creek Robotics)
Pretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to beholdPretzel is a splendid one to behold
Team 1619 used a tank tread style design this year that used two belts wrapped around four pulleys each to propel our robot. We had our right belt snap in quarterfinals match 1-1 in the Utah regional. This occurred because the belts were the same we had used with a two cim drivetrain in years prior, while this year we had used a four cim drivetrain with a two speed transmission, which gave the belts a bit more abuse (along with the rough gameplay).
We did design to be prepared for a belt failure however, and we back up and running within five minutes. All we needed to do was remove our side panel, slide the belt off, and then slide a new one back on since our design had the side panel acting as the second point of support for the pivots. As soon as the new belt was on, we merely had to slide the side panel back in place and tighten the screws again.
It turns out that the belt had failed at its weld point. The failure itself actually occurred when we were pushed sideways for an extended period of time and one of our guesses as to what happened is that the tread, with it's square edges, had its edge hang up on the carpet. This would allow the best to twist and increase the tension on the belt, which could lead to a snapped belt.
At any rate, our team came out of Utah with a learning experience behind us. We ordered some new belts before the Colorado regional, with twice the steel fiber content, and went back out to compete with no further problems.
It's not done until it's overdone!
Last edited by Pretzel : 19-04-2014 at 11:10. Reason: Added more details about the failure
Unread 19-04-2014, 20:15
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Originally Posted by DampRobot View Post
We had similar experiences at SVR.
We run a 6WD WCD VersaChassis setup with 4" wheels, omnis in front, and either VersaWheels or VersaWheels DT as the center and back wheels. Dropped center, VersaTrucks, and CAM tensioning. We used 4 CIM, 2 Minis in a 3 CIM ball shifter at Davis and took out the Minis at SVR. The center wheel was direct driven off the ball shifter output shaft, and the front and back belts were driven by 130T 9mm wide VP belts on 24T pulleys. We were traction limited in both low and high gear.
What gear reductions on the ball shifter?
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 19-04-2014, 21:04
who716's Avatar
who716 who716 is offline
AKA: Stephen Kalogiannis
FRC #0716 (Who'sCTEKS)
who716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to behold
We initially planed on using gates belts to pivot our ball pickup but the force it took to pivot it made the belts slip way to much for us too feel confident so we Changed that to chains. That was one of our first ever attempts to use belts on our final design.
-WPI number one seed
-Innovation in controls award
- NECMP#4 seed semifinalist
- 9th in NEW ENGLAND
2008- Connecticut regional winners
2004-UTC new England regional Winners
2001 highest rookie seed award winner
Unread 20-04-2014, 00:14
Oblarg Oblarg is offline
AKA: Eli Barnett
I've (thankfully) only seen one belt failure (a snapped HTD belt) during my time in FRC, which occurred on 449's 2008 robot towards the end of Battle O' Baltimore and was likely the product of our extremely shoddy belt tensioning system that year (everything on the drive was on 80/20 sliders, so between every match we'd loosen the bolts going to the gearbox and pull until the belts were tight, then re-tighten - ah, the things you do when you don't know any better...). The belts this year on all the teams I've worked with have held up perfectly.
On the flip side, I've given up trying to keep track of all the drive chain failures I've witnessed...
"The breakfast of champions!"
Unread 20-04-2014, 00:18
DampRobot's Avatar
Physics Major
AKA: Roger Romani
I don't remember the actual reductions off the top of my head, but I know we were 18fps high, and 8fps low, both adjusted speeds.
-Plutarch
Unread 20-04-2014, 09:57
electroken's Avatar
electroken electroken is offline
Electron Tamer
AKA: Ken Pontbriant
FRC #0230 (Gaelhawks)
electroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the rough
We've had one belt failure so far this year. It was a VEX 130 tooth, 15mm belt in our drivetrain which broke straight across, a textbook crimp failure.
I didn't see that belt get installed, but I'm willing to bet it involved prying it over the sprocket with a screwdriver.
Unread 20-04-2014, 11:29
Kevin Kolodziej's Avatar
Kevin Kolodziej Kevin Kolodziej is offline
Operator in 100+ matches
AKA: Yngwie Kamen's roadie
Kevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond repute
Send a message via AIM to Kevin Kolodziej
Team 1675 used 8 belts on our 2014 robot. This was our second experience with belts. Our first use was in 2011 on our roller claw (I don't remember the ratios but they were 15mm HTD belts from Gates on fairly small pulleys). This year we used 8 belts on our robot:
Drive: (4) VexPro 150t 9mm belts, 30t pulley on each end. 6 Wheel WCD Gearboxes with 2CIM shifter, 15:1 / 5.13:1 ratios, 4" wheels. Center pulley was a double pulley, versablocks with cam tension on the outside wheels.
Arm Shoulder: (2) Gates HTD 239t 15mm belts, 18t pulley to 60t pulley. 18t pulleys were driven by 100:1 versaplanetary with 775 motor and additional 18:24 gear reduction. Versablock with cam tension on the shoulder joint. 18t pulleys were on a shaft supported by drive gearboxes.
Roller Claw: (2) VexPro 150t 9mm belts, 30t pulley to 42t pulley, 4" Versawheels on intake. 30t pulley driven by 15:1 Versaplanetary with BAG motor and bevel gears. Versablocks with cam tension on intake wheels.
We experienced 2 belt failures during the 2014 season, both on the drive. On our practice bot, one of the drive belts was shredded (messy, frayed break). The second failure was on our competition bot on Friday afternoon at our second regional. One of our rear drive belts snapped (perpendicular clean break as far as I can remember).
We believe the first failure was due to a pulley failure. The inside flange of the pulley in the gearbox (the one with bolt belts wrapping it) popped off. When the belt walked to the edge of the teeth, it shredded on the sharp edge. We believe the second failure was due to over-tensioning of that particular belt.
After talking with Aren Hill at Vex about our pulley failure, we took a careful look at our alignment and determined that our belts were not straight and that was putting stress on the flanges of the pulleys. I believe it is common practice for smaller timing pulleys to have the flanges pressed on so any misalignment is likely to cause this failure over time. After replacing spacers to achieve better alignment, our walking issues seemed to disappear, however, we still had 4 more pulley failures (total of 5) over the course of the season (3 total on practice bot, 2 on competition bot, both at the gearbox and at the wheel). The failures always seemed to occur on the same half of the drive, which leads me to believe we had an inherent flaw in our fabrication causing a misalignment that we could not detect. For what its worth, however, we did notice that at least one of our drive axles was always towed in towards the gearbox when the belt was tensioned (not overly tensioned). We believe this was a flaw in either the versablock at that wheel or the bearings or some combination of the two. We disassembled the block and bearings and reassembled and the problem persisted. We did not have additional bearings to try swapping out. This was not the corner that we saw our pulley failures in, however, and it did not give us any noticeable problems.
We had no issues with our printed pulleys on our roller claw.
We had some limited belt slipping on our shoulder joint, but this was due to the bottom shaft flexing as the drive gearboxes flexed. A brace between the two gearboxes would likely solve this.
As for loads on the belts, our estimated pushing force was 170 lbs, and the 30t belts on our drive I think had about a 1.5" diameter, so potentially one belt could have seen approximately 250 lb of tension if we were in a pushing match, plus the pre-tension. The shoulder belts saw some shock loads as our arm bounced around a bit, but I couldn't begin to estimate that load. Perhaps the most surprising, however, was on our roller claw. Though generally under very low loads (lightly tensioned, not much load from the ball), there was a match when the screw from the versablock backed out and interfered with the spokes of the wheel (VexPro DT 4"). The belts held up just fine as the motor pulled the wheel through the screw, creating a notch in the wheel from the head of the bolt and bending the 10-32 bolt.
As mentioned above, our drive belts shared a common pulley in the gearbox, and this is where our initial failures occured. When we popped a flange off at this pulley on our competition bot, it was actually the outside flange, not the inside flange, that came off, but the belts did not walk off the pulley.
Final thoughts: We love belts. There's a few things we learned this year about proper tension that we will implement in the future. One disadvantage is when we popped a flange or snapped the belt on the drive, the only way to replace the internal pulley or replace the belt was to remove the entire drive gearbox from the robot, which also involved removing the belts for our shoulder because of the shared mounting. After having to do this a few times, we got pretty good at it and had it down to a 30 minute repair, but this doesn't work for elims. Simple solution to this is to move the output pulley to outside of the gearbox, but that does create other design challenges. But I certainly do not miss trying to put a masterlink on a chain in a cramped part of the robot, upside down! We are going to explore using the printed pulleys in more applications as well. Tooth wear was practically zero and having the flanges not pressed on is a bit more forgiving for alignment issues. I was initially concerned with our choice to use 9mm belts on the drive, instead of 15mm, but the larger pulleys (30t instead of 24t or 18t) seemed to be the right combination for use with the 9mm belts.
Team 71: 1999, 2000 (Driver), 2001-2002 (Driver, Animator) // Team 1064: 2003 (Co-founder, Coach), 2004 (Coach) // Team 1714: 2006-2007 (Mentor, Coach)
Team 1675: 2005-2007 (Mentor, Coach), 2008 (Mentor), 2009-2017 (Mentor, Coach)
FLL: '04 (Judge), '05 (Ref), '06 (Ref), '07 (Ref), '08 (Judge, Ref), '09 (Judge), '10 (Ref), '16 (Judge Advisor) // Ref: '05 (IN, IRI), '06 (IN, IRI), '07 (IN, IRI), '08 (WMR, Curie)
WI RPC: 2006 - 2016 // FRC Inspector: '07 (WI), '08 (WI, IL), '09 (WI, IL), '10 (WI, CMP), '11 (WI, IL, CMP), '12 (WI), '13 (Northern Lights)
2007 WI Woodie Flowers Award Finalist // 2011 Wisconsin Regional Outstanding Volunteer // 2011/2013 Midwest Regional Chairman's Award
Unread 20-04-2014, 15:47
AKA: Eli Barnett
I'm currently playing around with a few drive train ideas with this very issue in mind - send me a PM if you're interested in discussing a few potential designs.
