Go to Post I wasn't pouting; just cowering in fear because I actually thought you were mad at me... I didn't want a clipboard to the head like Billfred here. - Jon K. [more]
Unread 19-04-2014, 15:26
safiq10's Avatar
safiq10 safiq10 is offline
FRC #2950 (DEVASTATORS)
safiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond repute
Learning and Understanding different drivetrains
Now in an effort to learn more about FRC and better understand it we are currently conducting research about the pros and cons on drivetrains. We want to understand why teams use a certain drivetrain.
Currently we are stuck on West coast drive... We are absolutely stumped on what benefits it gives and why we see some of the more elite teams using it?
2014 Dallas Semi-Finalist (Thanks 3847 & 231)
2014 OKC Semi-Finalist (Thanks 2341 & 2461)
Unread 19-04-2014, 15:32
Abhishek R Abhishek R is offline
FRC #0624
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
Re: Learning and Understanding different drivetrains
The live axles and cantilevered (meaning the axles are only supported on one end) wheels allow for more freedom of space and much easier maintenance.
2012 - 2015 : 624 CRyptonite
Team Website
Unread 19-04-2014, 15:38
Volunteer, WPILib Contributor
no team (Waiting for 2021)
One of the best ways to improve stability of any object is to move the contact patches as far to the outside as possible. On a robot, this involves moving the wheels as far out as possible. Because on a WCD the wheels are cantilevered, there is no need for an outer frame rail. Because of this, the wheels can be as close to the edge of the allowed perimeter. This allows for a stabler robot.
Another advantage is because the wheels are on the outside of any frame, and usually on live axles, remove a wheel only requires removing 1 clip or screw, and the entire wheel pulls off the side. This allows a wheel to be changed very quickly, usually without having to adjust chain tension, or remove alot of robot parts to get to it.
Team 4488 - Mentor 2013-2016
Unread 19-04-2014, 15:42
It's a very balanced drivetrain.
For reference, a "true" WCD is 6 wheels, cantilevered outside of the frame, with the center wheel directly driven off the gearbox and the rest powered by belts or chains, with the center wheel dropped some fraction of an inch--oh, and it uses live axles. I'll be talking about the general 6WD drop-center (as opposed to a 6WD with corner omni wheels and the 6WD scrub turn), rather than a true WCD.
First, it's dirt simple. About the only thing simpler is a 4WD, and it's not that hard to swap it down to that. However, it has a shorter wheelbase, due to the dropped center wheels, so it turns much more smoothly than the "Mexican jumping bean" that I've heard the 4WDs compared to. If one or more of the wheels are directly driven, you just about can't lose half of your drivetrain in one mishap (or you'd have lost it anyway). It's easy to turn when you want it to turn, but not quite as easy as a corner-omni configuration.
The true WCD adds ease of maintenance--the wheels are easy to yank off when you want to swap 'em--but also adds complexity of machining (or increases the cost as you buy the parts).
As a note, the WCD has been in use for 10 years or more. It might not be as maneuverable as a swerve or mecanum, but it's pretty effective, and is likely to be sticking around another 10 years or more.
Unread 19-04-2014, 16:11
Oblarg Oblarg is offline
AKA: Eli Barnett
It offers a wider wheel base, which is more stable, and easy wheel access (as wheels on high-traction drives tend to wear a lot, this is very helpful for facilitating maintenance).
On the down side, it makes maintaining the belts or chain a bit of a pain as they're generally run off pulleys that are mounted inside of the gearbox.
"The breakfast of champions!"
Unread 19-04-2014, 18:41
Rauhul Varma Rauhul Varma is offline
Drivetrain and Design Lead
FRC #0192 (GRT)
Rauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud of
A west coast drive provides a ton of advantages. As others have said, you can maximize your wheel base, improving robot stability. It also can make servicing a drivetrain insanely fast. Our modified WCD set up allows us to switch out our entire drivetrain for entirely new components in under 10 minutes without having to temporarily remove/loosen any non drivetrain component.
Unread 19-04-2014, 18:52
Joseph Smith's Avatar
Joseph Smith Joseph Smith is offline
Persistence alone is omnipotent.
FRC #3539 (Byting Bulldogs)
Joseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant future
I have experience with two different drivetrain styles. #1 is closed frame 6WD/8WD similar to last year's kitbot drivetrain. #2 is West Coast Drive.
#1. Closed frame (8WD) using 1" x 1" x .125" square aluminum tubing. This is the style my team used in 2011 and 2012. We cut and welded the drivetrain frame together before anything else. This method uses dead axles with all six/eight wheels driven by chain from the gearbox.
PROS: very simple design
Low maintenence
Proven and reliable
Robust
Flexible Design
CONS: Medium to heavy weight depending on wheels
All wheels are chained- no direct drive, so it's possible to throw a chain and lose control of one side
Takes up more space
More difficult to swap wheels/tread
#2: Standard West Coast Drive. We used this style in 2013 by necessity in order to package our wide intake under the bumper. We liked it so much that we decided to use it this year as well. It's 1" x 2" x .125" aluminum tubing, riveted together with Vex VersaGussets with a Vex 3-CIM ballshifter. The center wheels are directly driven and the outside wheels are chained.
PROS: Simple to design
Direct Driven center wheels
Easy maintenance
Fast swap wheels/tread
Lightweight design
Robust Design
Widest possible wheelbase
Less space consumed
CONS: Bearings on cantilevered axles need to be well supported and aligned, though the VexPro VersaBlocks are awesome for this.
Requires more machining capability
I love the WCD and don't see any reason not to use it, due to it's low weight and super easy maintenance as well as the benefit of a maximum width wheelbase and direct driven wheels.
Design/fab team 2011-2013
Design/fab mentor 2014--
There are three types of people in the world:
1. Those who make things happen
2. Those who watch things happen
3. Those who wonder what happened.
Unread 20-04-2014, 08:36
Originally Posted by Joseph Smith View Post
Widest possible wheelbase...
maximum width wheelbase...
Just to be clear: wheelbase is the distance from the front to rear axles (length). trackwidth is the distance between the two front (or rear) wheels (width).
Unread 20-04-2014, 12:34
theCADguy's Avatar
theCADguy theCADguy is offline
Design Team Student Leader
AKA: Sean Gibbons
FRC #0020 (The Rocketeers)
Team Role: CAD
theCADguy has a spectacular aura abouttheCADguy has a spectacular aura about
Takes up more space
Actually, throwing a chain does not cause a loss of control on one side. At the WPI regional in 2013, we (Team 20), lost a chain in our west coast drive during a finals match, and had no time to replace it before our next match, so we played that match without a chain, and we experienced was very little loss of control. In fact, it was impossible to tell (from the stands) that we had lost a chain.
We had a similar situation this year at the Tech Valley regional, were we smashed a drive train bearing, and had to remove the affected wheel, as we had no time to fix it. Our WCD performed just as well with 5 wheels as it did with 6, and we won that match.
Unread 20-04-2014, 13:25
Thanks, I'll remember that.
Unread 20-04-2014, 13:28
I think you misunderstand me... Throwing the chain from the gearbox to the wheels in design #1 would result in losing power to the wheels on that side. Of course this depends on how the chain is run, but it's assuming that you have one chain from gearbox to the center wheel and from there the wheels are chained to each other. Also, one of the benefits of WCD that I listed was that throwing a chain wouldn't cause you to lose power on that side because the center wheels are direct driven from the gearbox (in our design at least.)
Unread 20-04-2014, 15:43
AKA: Eli Barnett
Note that one can direct-drive center wheels on a non-WCD 6WD setup (a la AM14U), so this isn't strictly a WCD benefit.
Unread 20-04-2014, 16:48
Back when I was a student on 330 and we were using that type of setup, we never ran just to the center. The gearbox was independently chained to the center and the back wheels; center wheel chained to front wheels. That way, we'd have to jam a chain when it was thrown, or throw two chains, to lose the side.
Unread 20-04-2014, 17:05
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Think of things in more atomic terms than 'drivetrains' and you'll be much better at understanding why teams have arrived at certain styles of drives and what the trade-offs were that led them there.
There's nothing intrinsically good about 6WD or swerve or anything else; good implementations are the result of well-considered details.
--Madison--
...down at the Ozdust!
Unread 20-04-2014, 17:06
AKA: Eli Barnett
This sounds like it'd introduce a lot of frictional losses over just direct-driving the center wheel and chaining to the two outer wheels.
