Go to Post Just like it is not all about the robots, it is not all about winning the Chairman's Award. - Paul Copioli [more]
Unread 21-02-2003, 15:33
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
Image Discuss: Our anchor is more powerful than you bot
Unread 21-02-2003, 15:34
Matt Reiland's Avatar
'The' drive behind the drive
F.Y.I. It's never good to use the rod of a cylinder for lateral support
I think you will also be suprised by the force of some of your opponents, in fact I know you will
Unread 21-02-2003, 15:41
Jeremy_Mc's Avatar
Jeremy_Mc Jeremy_Mc is offline
GitHubber
Jeremy_Mc will become famous soon enoughJeremy_Mc will become famous soon enough
i really hope you're not using the ability of a human to push your robot as grounds for these claims.
a robot can hit with much harder force than any human. you should take another robot and hit yours with it to test these things.
no one person could move a robot at our exhibition, but then another team's bot rammed it and it slid 2 feet.
plus, i don't think suction cups are going to be very effective due to the nature of the HDPE.
*jeremy
GitHub - Collaborate on code, documentation, etc. - http://github.com
Unread 21-02-2003, 16:00
Duke 13370's Avatar
Duke 13370 Duke 13370 is offline
C is for cookie...
#0862 (Team Lightning)
Team Role: Webmaster
Duke 13370 will become famous soon enough
Send a message via AIM to Duke 13370
those aren't jsut any suction cups, those are sheet metal holders, and they don't slide, and are tested for about 300 lbs. Yeah, the pnematic might bend, but at that point, our robot will have fallen to pieces and we'll be out for good (that wouldn't be fun )
Oh, and they actually work best on smooth materials like the HDPE.
<edit> We are more worried about this monster bending our robot's frame than we are of anyone else doing that.</edit>
---Lightning Robotics!---
Unread 21-02-2003, 16:17
DanLevin247 DanLevin247 is offline
Missing In Action
#0247 ('da bears)
DanLevin247 is on a distinguished road
Send a message via AIM to DanLevin247
Nice looking bot...but wouldn't it be wise to somehow protect that cylinder? It would really suck if you guys got hit or ran into someone, and fubar'ed your suction system in the process.
'daaaaaaaaaaaaaa bears!
It's all fun and games till someone gets hurt.....then it's hillarious!
Unread 21-02-2003, 16:19
MarcusF MarcusF is offline
#0157 (Aztechs)
MarcusF is an unknown quantity at this point
Send a message via AIM to MarcusF
They do work on smooth surfaces, but the HDPE will become very worn and will not be a flat surface after a few dozen matches, it will have pits in it. Just my opinion
Unread 21-02-2003, 23:33
comet22 comet22 is offline
comet22 is an unknown quantity at this point
i would add a lateral support beam, it wouldnt be too difficult, but i do believe you will be slideable... you aren't drawing vacuum which will make your suction less effective.
Unread 22-02-2003, 00:36
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
That's odd, because we had those (MSC right?) and they slid pretty bad, i can also tell you they didnt make it on our robot.
Purdue Alumni
Cummins, Inc.
Unread 22-02-2003, 04:05
Eric Bareiss's Avatar
Eric Bareiss Eric Bareiss is offline
It's a Bird
AKA: BoogyShoes
FRC #1492 (Team Caution)
Eric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of light
Send a message via AIM to Eric Bareiss
They look like Anver suction cups to me, and if they are then yes they do slide. They don't slide very easily, but if someone like team 60 or 45 comes up the ramp at full speed, off the ramp you go.
FYI - The 300lb tested force is lifting force, the shear force (sliding) is probably going to be less that 50lbs.
Unread 22-02-2003, 04:12
sevisehda's Avatar
sevisehda sevisehda is offline
sevisehda is an unknown quantity at this point
Send a message via AIM to sevisehda
Nice hatch for the controls.
I'm not sure if that cylinder will that very long. I can almost gaurantee the shaft will bend after 1 good hit.
Even that bracket that holds the cylinder looks weak, you may want to put it on the end of the cylinder where the shaft comes out. So as not to crease the wall.
The HDPE isn't a very hard surface and will start to get scratched and pitted very fast. If you take into acount all the collisons and action on the ramp it won't stay smooth very long.
I'm not saying you wont be able to stay on but I don't think you stay on for long.
Unread 22-02-2003, 08:58
RobDeCotiis RobDeCotiis is offline
FRC #1660
RobDeCotiis can only hope to improve
Send a message via AIM to RobDeCotiis
try this: flip the piston upside down. make a mounting bracket to connect it to a piece of extruded aluminum so the aluminum is flush with the back of the piston when the piston is extended. have the piston retract to pull the extruded alumiinum bar down, pushing the suction cups onto the ground. that way, the piston rod is inside your bot when you're taking the force, and wont bend nearly as easily if you take a hit. other than that, not too shabby.
Unread 22-02-2003, 10:03
Duke 13370's Avatar
C is for cookie...
I get the vaugest feeling we prolly won't want to take to many hits on this thing, but it is very cool to watch it lift the opposite side of the bot.
Unread 22-02-2003, 11:46
Dave_222's Avatar
Dave_222 Dave_222 is offline
I used to be cool.
AKA: Dave the Knaive
#0222 (Tigertrons)
Dave_222 will become famous soon enough
Send a message via ICQ to Dave_222 Send a message via AIM to Dave_222 Send a message via Yahoo to Dave_222
You just better hope you dont meet us cuz we push at well over 300 lbs and um suction cups arent stoping us.
"Get up and save yourself from youself."
Maynard
"Let me intorduce myself," the man said. "My name is Roosta, And this is my towel."
Unread 22-02-2003, 12:32
Duke 13370's Avatar
C is for cookie...
do you have any images up?
<edit> nevermind, I found it. It doesn't look like you have enough traction to do that, are you sure you can push 300lbs.?</edit>
Unread 22-02-2003, 13:13
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
It's next to impossible to make any judgements about tractive effort by looking at a picture. Big tires doesn't equate to big traction. Cool belts don't equate to big traction, either.
In fact, this season, I expect many people are going to have to relearn all they though they learned about traction - especially where the HDPE is concerned.
As someone already mentioned, the 300 lbf. figure you have is probably for tension, not shear. Suction cups don't really resist shear all that well, and there are robots out there that can exert well in excess of 300 lbf., anyway.
Against some robots, you'll likely be fine. . . .well, assuming that your drivetrain has the oomph to move other robots with similar ideas out of the way. Against others, you won't stand a chance. There's always someone who does it better, or differently, or some way you never even considered.
It's a bad idea to assume you're immovable, or unbeatable, or that much more clever than the rest of us.
Edit: Grammar. Also, do you understand the difference between pushing something that weighs 300 lbs. along a surface and exerting 300 lbf.?
--Madison--
...down at the Ozdust!
