Go to Post Oh, the magic smoke will just make make it seem a bit more like Christmas. - CJO [more]
Unread 21-02-2003, 20:21
miketwalker miketwalker is offline
Robot Lifeguard
FRC #1902 (Exploding Bacon)
miketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond repute
Send a message via AIM to miketwalker
Swapping codes
I have codes for both the left and right side of the ramp. We want to load the code used in the pits and then somehow swap it before the match in case we are assigned sides and don't get to pick so we can swap codes. It's easy to merge the codes but how have other teams made it to swap sides? Are you using switches? Is there anyway to swap it on the RC itself without a switch? I'm just trying to find the simplest way and hopefully get out of installing a switch on the robot on the practice day. Thanks everyone.
Chopsaw? Chopsaw.
Unread 21-02-2003, 20:29
Eugene Eugene is offline
#0321 (Lancers)
Eugene is on a distinguished road
Send a message via AIM to Eugene
As far as I know you can use the Operator Interface to set what side you want your robot to go, since you can communicate with the RC. The reason why you cannot operate your robot during that time is because the processor that generates the PWM codes and controls the relays is disabled.
Good Luck!
Eugene
Unread 21-02-2003, 21:35
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
ttedrow will become famous soon enoughttedrow will become famous soon enough
Remember, during the human player period, operator will NOT be allowed to touch the OI.
The simple solution is to put a toggle switch on your robot and wire it to a digital input. Then some simple code and you are done.
RigthTurn VAR rc_swB.bit4 '13 Autonomous Mode Turning Direction: 1=Right, 0=Left
IF RigthTurn THEN
'Do Right turn code
ELSE
'Do Left turn code
ENDIF
I hope this helps
Tim Tedrow
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
Unread 21-02-2003, 21:36
#0321 (Lancers)
But, you can touch it before
Unread 22-02-2003, 10:10
FRC Key Volunteer Trainer
AKA: CrazyNate
Keep in mind that FIRST has stated the match list will say which side of the ramp you are on. You can use this information to download the appropriate code ahead of time...
Nate Smith
nsmith@smythsoft.com
Unread 22-02-2003, 13:36
Kevin Rugani Kevin Rugani is offline
#0096 (LEGO Maniacs)
Kevin Rugani is an unknown quantity at this point
Send a message via AIM to Kevin Rugani
Swapping programs
If you look on the Robot Controller, there is a jumper which can be placed on either user or default. I simply loaded a program for starting on the left side while the jumper was on default, then switched the jumper to user and loaded a program for the right side. This was more of a quick solution to switch between programs since we did not have our program selector switches wired yet. The program ran fine each time. The only downside is that the jumper is pretty small and annoying to change sometimes.
Kevin Rugani
Team 96
Email: rugo@wpi.edu
Unread 22-02-2003, 13:39
Robot Lifeguard
Re: Swapping programs
I thought you couldn't overwrite the default code? Also, where did they say you will know which side you are on ahead of time? I thought they just said they might not tell you till just a few minutes before a match? Thanks everyone.
Chopsaw? Chopsaw.
Unread 22-02-2003, 13:49
I loaded our modified program with no problems on the default side, and it ran fine every time (at the UTC scrimmage hosted by aces high in suffield, ct). As far as starting sides, there were printouts of the match schedules which told each team their color and starting side. I'm assuming that F.I.R.S.T. will run things the same way. I am pretty sure you can overwrite the default code, however.
Kevin Rugani
Team 96
Email: rugo@wpi.edu
Unread 22-02-2003, 15:26
AKA: CrazyNate
Re: Re: Swapping programs
The original (2000 I believe) IFI controllers did not allow you to overwrite the code in the Default slot, but due to some faulty STAMP processors which were spontaneously losing the user code, they unlocked the Default code slot to use as a backup,intending you to load a second copy of your code into the default slot. However, nowhere in the rules does it say that the two code slots have to be identical.
Here's the rule which says you will know
in advance where on the field you will be
Nate Smith
Alt codes in Forums? Elgin Clock CD Forum Support 2 27-09-2003 00:45
html codes Tim_Wochomurka Chit-Chat 2 01-11-2002 22:14
