Go to Post I say we all stop flaming and pointing out what went wrong or what bad calls were made and start pointing out how much fun we all have at the regionals and what FIRST actually has done for us. - burkechrs1 [more]
Unread 20-04-2014, 17:18
Re: Learning and Understanding different drivetrains
Originally Posted by Oblarg View Post
This sounds like it'd introduce a lot of frictional losses over just direct-driving the center wheel and chaining to the two outer wheels.
Not too much. And it helped with our weight distribution (we tended to run with the CG aft of center whenever we could). The gearbox was between the center and rear wheels, so we had two short chain runs.
This was back in the day when if you wanted to direct-drive your center wheel, you had to make your own output shaft, if not your own gearbox--we didn't have that type of capability, then. Besides, we were a dead-axle team--that is, at the time we did NOT go live-axle if we didn't absolutely have to. (In my time on the team, I can think of maybe 4 live axles that weren't in a gearbox, none in drivetrain--they were all reduction stages in arms or shooters,)
Unread 20-04-2014, 21:27
topgun's Avatar
topgun topgun is offline
FRC #2846 (FireBears)
topgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant future
What about the weight of the bumper mounts? That needs to be added into the weight of the frame as well.
We used a 6 wheel center drop dead axle (JVN axle tube style) and the outside edge of our wheels were within a .5" of the frame perimeter. I am not going to worry about that last inch of width but that is important for some teams.
WCD would have the edge in quickly replacing a wheel, though we could change a wheel pretty quick if needed.
We also used HTD timing belts between wheels which are a lot lighter than chains. We used a short #35 chain between the gearbox and the first wheel.
Part of the appropriateness of the drivetrain is what your team can build, and should be a key part of your decision. Determining that is a good offseason project.
-T
Unread 20-04-2014, 21:33
MrRiedemanJACC MrRiedemanJACC is offline
FRC #2611 (Jacktown Vectors)
MrRiedemanJACC will become famous soon enough
For those of you with WCD I have several questions:
1) How do you locate the wheel in the axial direction? Both inwards and outwards?
2) If you are using the 3 CIM ball Shifter,
a) Do you use the 3rd stage from Vex?
b) Do you only use the support from the bearings in the gearbox or do you add additional support?
3) Is there a set wheel width that you use? (narrower to be able to move the gearbox outward further? ie 1" traction vs a 2" traction?)
4) How much drop do you use for the center wheel?
Thanks! I'm sure as we look into it, I'll have more detailed questions!!
Unread 20-04-2014, 21:40
Thad House Thad House is online now
Volunteer, WPILib Contributor
no team (Waiting for 2021)
1. If you custom machine wheels, you usually keep a nub on the wheel to push up against the bearing. If you don't machine your own wheels, you can just use spacers of some type. This year we 3D printed our own. As for the outside, most teams use either e-clips, snap rings or a bolt and washer with the axle threaded on the end.
2. We used the WCP gearboxes, so I don't have much of an answer here, other then you usually would need the 3rd stage to actually have enough reduction for a functioning robot.
3. The wider of a wheel you go, the more grip you can get from that wheel. Since we don't machine our own wheels, we use whatever we can get. This year, that was VersaWheels. The general rule is to have the wheels as far to the edge of the perimeter that is allowed.
4. This year we used 0.1". The old standard used to be 1/8", but with the smaller wheelbases that we are currently seeing, that number has to drop, and we have found 0.1" to work the best.
Team 4488 - Mentor 2013-2016
Unread 20-04-2014, 22:14
Kabir Manghnani's Avatar
Kabir Manghnani Kabir Manghnani is offline
FRC #0649 (MSET Fish)
Kabir Manghnani is an unknown quantity at this point
A well done WCD can give a team a pretty good step up from the competition for a lot of reasons that have been mentioned above and i dont think i need to delve into here but it does seem like your team is looking to take it to the next level (correct me if im wrong). Finding a consistent drive base and sticking with it isn't a bad thing, it gives you time to perfect your manipulator(s) which can really help your gameplay. But if you are looking to upgrade here are a few options to mess with in the off season.
1) 2-Speed gearbox: If you haven't already started using one it can really help your game play. Our team has loved the ability to race across the field and push people around at the other end if we need to once we get there
2) Integrated Manipulators: I actually missed it at SVR in 2013 but Team 118 (go watch their video, its brilliant) had a pick up that (this is what it looked like from their reveal video) dropped out of the bottom of their drivetrain. (Now that's cool) and its was a intresting way to keep from getting their pick up smashed.
3) I'm not even sure: Look to 118's drivetrain this year. In their reveal video this year (https://www.youtube.com/watch?v=PtRewwr59d8) just at around 15 seconds. Its amazing system but what happens is that omni's fire down using pistons and its got three great usages that i can imagine. A) Just as they do in the beginning a launch to really get you going might be helpful. B)Lets say you are getting defended and pushed across the field, you've got no traction at this point and even though you can get your wheels moving you cant get out of the push (ask your drivers about this, they know the situation) you fire down the omnis and just coast away, while ramping up your wheels and as soon as you coast out of their reach you sprint out of the way, freeing you from the pin. C) Turns, the ideal turning system would be high traction in the back and omni's where you want to turn right? So... fire down just one set of omni's (Look to 1:06 in the video) they manage to pull of these almost diming maneuvers throughout the video which i can only imagine happen because of the turning help that the omni's provide. This must be an incredibly powerful set of pistons and some fairly complicated code to make it easy to use but its a great summer program.
I'm reminded of a quote by Adam Heard of 973 (Correct me if I've got the wrong person) "World Champions are build in the off-season."
Good Luck!!
FRC Team 649
Vice- President
Programmer
Chairman's Lead
Scouting
The voices in my head may not be real, but they have some good ideas!
Unread 21-04-2014, 13:09
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Originally Posted by Joseph Smith View Post
#2: Standard West Coast Drive.
CONS: [...]
Requires more machining capability
What extra machining capabilities are required for a WCD? As far as I have seen it looks like you can purchase most all of the parts required from dealers?
I ask because my team is looking into making the switch to WCD next year but we have virtually no machining capabilities.
Unread 21-04-2014, 13:48
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
In 2013 3309 used a WCD.
1) snap ring on the outside and the wheel hub was made to touch only the inner ring of the bearing.
2) used a custom gear box but the COTS options are very good.
3)Used Colsons that year, we plan our wheels to be traction limited in low gear. We were geared a little to high so we never added grooves to the colsons or switched nitrile rough top tread.
4) It was 0.125, it worked but was a bit too much. I would not complain if I had to use .125 but if I could get 0.100 I would go for it.
This year my team used octonum which was harder to change wheels. So the biggest thing we noticed was that if you have a practice bot and drive more than 10 hours a week. Wheel changing becomes very important. So next year 3309 is going back to west coast drive. Especially comparing our practice time to elite teams, we need to up our game. We are targeting 20 hours a week (including autonomous work). We are also hoping to practice against more orange county teams next year, so wheel wear will be very high. So changing wheels quickly is a major concern for us.
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
Unread 21-04-2014, 16:24
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
We went to a 6 wheel WCD this year and are very happy with the results.
Now that VexPro and West Coast Products produce easy to incorporate parts for west coast drives, just about any team can upgrade.
You can use the Versa rails and Versa blocks to create the drive rails. In fact you can get everything for a WCD from VexPro and West Coast Products.
We did not use the Versa rails as they are, in my opinion, not strong enough for this year’s game. You can make your own frame rails very easily with just a good drill. The VersaBlocks center the bearings and create the offset by their orientation so perfectly drilling the rail is not required. Just a hole big enough for the axles to fit through. Normally the offset is about 1/8" between the center and outer wheels. If you center your weight you will have no issues with turning with all traction wheels.
We are using the West Coast Products 3 CIM 2 speed transmission with the 3rd stage. It is geared to run at 5fps and 15fps on 4" wheels.
You will want to get the third stage, as mentioned before.
The 3 CIM is quite heavy and you should definitely add additional support. With so many different gear selections available for these transmissions you can tune your drive speed for whatever wheel size you are running.
We LOVE these transmissions!!
At our regional we ran the 4"x1" Versa wheels. These were OK for a first attempt but were fairly easily worn out and did not give quite the traction we wanted. The wear was easily overlooked since the Versa wheels are quite inexpensive.
We have upgraded to 4"x1.5" Colson wheels for the championships.
We would of gone wider but our drivetrain is set and wasn’t sure if the 2" wheels would fit without major modifications.
Since the change to the event times we were not sure that there would be time for it.
Good luck with your drive train change. PM me if you have any questions. I can send you our CAD files or talk more in length on you first try at WCD.
After our first attempt was so successful we doubt we will ever go back. Unless of course it is a water game, then all bets are off.
Aloha
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Hopper Division | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
Unread 21-04-2014, 18:32
Clem1640's Avatar
Clem1640 Clem1640 is offline
Head Mentor
AKA: Clem McKown
FRC #1640 (Sab-BOT-age)
Clem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond repute
WCD is a great tank drive-train. Love it.
But we use 4-wheel independent swerve. It works for us. It carries a high cost; brings significant benefits for those who execute it well.
For a perspective, see: http://wiki.team1640.com/index.php?title=Swerve_Central
Clem McKown
Head Mentor - FRC 1640 & FTC 7314
Chairman - Downingtown Area Robotics
Unread 21-04-2014, 18:37
Andrew Lawrence
Posts: n/a
http://www.chiefdelphi.com/forums/sh...9&postcount=19
Post I made a while ago with a decently large amount of information on drive systems.
Unread 21-04-2014, 18:39
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Few people realize how revolutionary these blocks and the whole Versa system are for drivetrain design. You can literally buy a WCD off the shelf, with a lot of features designed for easy customization and to be really easy for low resource teams to use.
By the way, we used .0625" 6061 2x1 this year in a standard WCD and in the rest of our frame. No bending, breaks, cracks in the powdercoat, etc. They are behind strong full perimeter bumpers, but nothing that the average team couldn't create. Even for a game like Arial Assault, the VP tubing is more than thick enough. IMO, you can go thinner (like we did) and save a ton of weight without running into strength problems. We had a sub-10lb frame, all because we used 1/16" tubing everywhere and relied on strong geometry rather than tubing to make our frame robust.
-Plutarch
Unread 21-04-2014, 18:40
Oblarg Oblarg is offline
AKA: Eli Barnett
I chuckled.
"The breakfast of champions!"
Unread 21-04-2014, 18:47
Andrew Lawrence
Posts: n/a
Yeah, the guy who invented those blocks must be a genius.
