Go to Post its like the championship being ice cream, its pretty awesome IRI is like adding toppings, making it even more awesome - Aren_Hill [more]
Unread 21-04-2014, 12:28
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Re: Starting configuration in the Goalie Zone
Originally Posted by BigJ View Post
It may be placed anywhere, but you have to declare a final position, after which offensive (non-goalie zone) bots get to pick positions.
Ok thanks.
Unread 21-04-2014, 12:31
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
And just to cite a rule:
Originally Posted by G4
TEAMS positioning ROBOTS in the white ZONE have precedence over opponents placing ROBOTS in the GOALIE ZONE.
Which was later clarified in the Q&A to be like I stated (goalies must place first, then white-zone bots may (re-)position)
Unread 21-04-2014, 19:23
We actually had an issue with that in L.A.--one of the teams was playing goalie, but they positioned, their opponents positioned, then the goalie team repositioned, and then their opponents repositioned.... After a couple of rounds of that, one of the refs went over and kept them from moving the robot again.
Basically, once you've placed, your opponents can adjust--but if you adjust again, so can they. Do it too often, and get called for delaying the match.
Unread 21-04-2014, 22:05
They made us change after initial practice rounds, we now have to automate movement during autonomous rather than just being a static blocker pre-placed.
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 21-04-2014, 22:14
Sorry, but there is nothing in the rules that says that you have to MOVE--in any way, shape, or form--during automode. You can, in fact, just sit there, regardless of where you are on the field--it's called the Mars Rock automode (you sit there and wait for Opportunity to come along). Whoever made you change that can go read the rulebook again--standard penalty for not knowin' the rules.
Unread 21-04-2014, 22:16
We did movement to gain a "surprise" position advantage otherwise the offensive bots know where we will be at the beginning of autonomous. So perhaps I misspoke... they made us stop pre-placing the bot "Mars rock style" after offense set up.
Unread 21-04-2014, 22:18
Well we did it to gain a "surprise" position advantage otherwise the offensive bots know where we will be at the beginning of autonomous.
True, true. I was thinking it was because someone thought sitting still was illegal. You could always use reverse psychology and move during practice... and then sit still during a real match or two!
Unread 21-04-2014, 22:22
I doubt we'll get in practice but we'll see... good idea
Unread 21-04-2014, 22:37
Bacon&Waffles Bacon&Waffles is offline
FRC #0107
Bacon&Waffles is an unknown quantity at this point
Just as a thought is there are rule saying that you can't use an opponent's hot goal to move to their hot goal to block balls? I think that something like this would be able to really mess up the auton of many great robots.
Unread 21-04-2014, 22:39
Nope, no rule at all on that.
Note, however, that you'll still have to move over there...
Unread 21-04-2014, 22:49
FRC #0107
Well so long as you have a really fast robot you might have a chance because if you block the first hot goal (or start there) then once the hot goal switches you will already know that it is hot before the other robot knows. Buuuut that would be insanely hard. Either way it would be interesting to take a look at!
Unread 22-04-2014, 00:37
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
You could also adapt the cheesy poof hot goal detection method to goalie movement
Unread 22-04-2014, 09:22
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
If CheesyVision is used against 254 to kill their auto, the world will end!
Unread 22-04-2014, 09:32
Yup, cheesy vision is VERY interesting
Unread 22-04-2014, 09:45
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
Yes I have caused that many times. But somebody keeps recreating it.
