Go to Post It doesn't matter to me where a FIRST local event is held, I'll be there! - Barry Bonzack [more]
Unread 22-04-2014, 19:16
Oblarg Oblarg is offline
AKA: Eli Barnett
pic: Offseason Drive Idea, Refined
Unread 22-04-2014, 19:20
MarkoRamius1086's Avatar
MarkoRamius1086 MarkoRamius1086 is offline
Robot Inspector
AKA: "Petrie"
FRC #1086 (Blue Cheese)
MarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to behold
Re: pic: Offseason Drive Idea, Refined
Definitely take the time and meticulously draw out the shafts and whatever spacing system you will use. All the correct hardware and tolerances. You (or whoever assembles it) will kick you in the butt when it comes together and there are issues with spacing. Looks good otherwise!
Tip: When you go to rivet it put the shafts and the bearings in first. This will ensure that you do not have alignment issues with your rigid frame
HEROES DIE, BUT LEGENDS LIVE FOREVER!
Unread 22-04-2014, 21:20
AKA: Eli Barnett
Already done; spacing uses the stock VexPro delrin hex spacers with a bit of wiggle room added in the gusset spacing.
Will do.
"The breakfast of champions!"
Unread 22-04-2014, 21:38
PingPongPerson's Avatar
PingPongPerson PingPongPerson is offline
Hardcore Robot Addict
AKA: Michael Groom
FRC #0955 (CV Robotics)
PingPongPerson will become famous soon enough
I cannot see how close to the frame perimeter the motors are, but I would be wary of the wires coming out of the back of the CIMs getting damaged by another robot ramming you. Other than that it looks really solid. Nice work!
Team 955
Raiderbot
Unread 22-04-2014, 22:01
AKA: Eli Barnett
I'd have to double-check the CAD, but I believe there's about a half inch of clearance.
I might move them in a bit anyway to allow for wider wheels.
Unread 22-04-2014, 22:18
DampRobot's Avatar
Physics Major
AKA: Roger Romani
It seems like your kind of converging on what 971 does, except with tubing instead of sheetmetal. They have their CIMs over their wheels, but also actually make the output of their gearbox a gear that connects to a gear on their center wheel, but externally to their gearbox. That way, they can take the gearbox off without taking the center wheel out, or take any belts off.
-Plutarch
Unread 22-04-2014, 22:27
AKA: Eli Barnett
Here are a couple more pics, if anyone's interested.
View from bottom, with transparent tube to show shaft coupling:
http://imgur.com/G6Z9AdW
View of whole chassis from top:
http://imgur.com/dGeCOPH
