Go to Post "Field orientation is like a homing pidgeon that can fly backwards." - LostWolf [more]
Unread 23-04-2014, 00:30
TheHolyHades1 TheHolyHades1 is offline
TheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the rough
COTS Shifter Comparison Question
Hello.
We've been looking into the various COTS shifter options available and we've come to find a few different options so far:
AM Supershifter: http://www.andymark.com/product-p/am-superoptions.htm
AM Sonicshifter: http://www.andymark.com/product-p/am-sonicoptions.htm
VexPRO 2 CIM Ball shifter: http://www.vexrobotics.com/ball-shifter.html
VexPRO 3 CIM Ball shifter: http://www.vexrobotics.com/3cimballshifter.html
WCP DS Gearbox: http://www.vexrobotics.com/wcp-ds.html
WCP 3 CIM Dog Shifter: http://www.wcproducts.net/wcp-shifter-3cim/
And we have a few questions.
1. Does anyone know if more COTS solutions exist? It seems each of the major FRC parts suppliers has their own, and I think we've covered all of the major suppliers.
2. How do the gearboxes compare to each other in terms of durability, ease of use, ease to modify/change gear ratio and motors, shift ability, shift speed, ease to mount, etc? We're a relatively low budget team and currently don't have the budget to do testing with all of the various designs.
3. Which one would you recommend (doesn't have to be from the list)?
3. Overall opinion on shifters?
Thanks,
Hades
Unread 23-04-2014, 00:48
Joseph Smith's Avatar
Joseph Smith Joseph Smith is offline
Persistence alone is omnipotent.
FRC #3539 (Byting Bulldogs)
Joseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant future
Re: COTS Shifter Comparison Question
This season we've used the VEX 3-CIM ball shifters with the 3rd stage WCD addon. So far we've really liked them.
PROS:
Lightweight
Easy assembly (except shifting shaft coupler)
Easy to install/pull from drivetrain
Smooth, fast shifting action
Integrated encoder mount
Lots of options for gear spread
Low-maintenance
Good customer support by VEX
Flexible mounting options
CONS:
Shifting shaft coupler tricky to assemble
Encoder gear can slip (this was fixed by replacing it with a new gear provided by VEX with a tighter fit)
Locknut stripping it's plastic socket (minor problem but annoying)
Overall we're quite satisfied with these gearboxes and would recommend them to anyone who wants a light, reliable, smooth shifting gearbox.
Design/fab team 2011-2013
Design/fab mentor 2014--
There are three types of people in the world:
1. Those who make things happen
2. Those who watch things happen
3. Those who wonder what happened.
Unread 23-04-2014, 01:59
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Having used gearboxes from all 3 suppliers, I'd have to say the WCP DS is the best gearbox currently on the market.
I used the AM shifter in 2011. It was the best shifter on the market at the time, but still had some assembly issues and couldn't do a direct drive off the output shaft. I also played around with the super shifter, and have looked at the sonic shifter. My general impression of AM gearboxes are huge hunks of metal that rarely break, but are a lot heavier than need be. They also have lower quality gears than some of their competitions, and are generally less efficient.
We used the 2 CIM Ball Shifters lot year on our P bot, and the 3 CIM ball shifters this year on comp and p bots. They're light, and fairly small, and much more efficient than the AM shifters. However, they're not the easiest to assemble, and almost impossible to service once installed. Our shifters this year fell apart a lot, and were very sensitive to assembly (over tightening the bolts holding that gearbox together could really screw you). We also saw them flex a bit, possibly because of the plastic casing. I'd recommend these as the best low cost option on the market, and especially recommend them if you plan on having a chain reduction after the gearbox to your wheels, gather than direct driving.
The DS is IMO the best shifter on the market today. We used them on our 2013 comp bot and offseason bot. They are extremely light, compact, efficient, and easy to service (although they almost never needed to service it). They're also really designed around WCDs, so they are really great for direct driving the center wheel and chaining the outer wheels. The only real downside is they don't have an encoder in the gearbox (which really isn't that big of a deal). The 3 CIM is a bit big for my taste, and has a lot of gears, so I'd really recommend with sticking with the OG DS. It's an awesome gearbox, I highly recommend it.
-Plutarch
Unread 23-04-2014, 02:13
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Is there something you need that's lacking in the current offerings?
Unread 23-04-2014, 07:31
Well, partly I just wanted to know if other options exist for my own knowledge. However, as I just realized, I did also want to know if any smaller, COTS one cim options exist as I wasn't able to find any. I realize you can just use one cim in some of these gearboxes, but that still make them bulky.
Unread 23-04-2014, 08:15
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Unless being used for something besides a drivetrain I strongly suggest always using at least two CIMs per gearbox.
Unread 23-04-2014, 08:23
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
What if you are direct driving mechanum?
Unread 23-04-2014, 09:18
Mecanum, swerve, crab, etc actually. We want to look into various other drivetrains in the off season and one com shifters could help.
Unread 23-04-2014, 09:24
Paul T.'s Avatar
Paul T. Paul T. is offline
no team (Team WARP)
Paul T. is on a distinguished road
whats the point of shifting? your limited to the traction of the wheels, your not going to trip the breaker at any reasonable speed. It'll just slip. (try to stay away from mecanum, they tend to be a disadvantage if any team against you has a decent drive train. you've never seen a mecanum robot on einstein.
ROOKIE Team 5400 WARP Mentor
Former FRC 1687 Highlander Robotics
Metal of Honor - Battle Cry 13 @ WPI
WPI districts Semifinalists-2014
Unread 26-04-2014, 19:31
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
+1, although I think the reason no mecanums are on einstein is partially because of their very limited usage and availability. We'll see mecanums on einstein in several years probably with Vex mecanums and other suppliers that might come around.
Anyway, I like the WCP shifters because they are all CNC'd and nice and hold 3 cims without problem. The Vex ballshifters are nice, but to me they don't offer as much the WCP shifters do due to weight and size. However, on a budget I would take Vex every time.
If 192 ever sells their gearboxes I would jump on those like nobody. Those weigh half as much as a WCP equivalent.
Unread 26-04-2014, 20:02
KamalRC's Avatar
KamalRC KamalRC is offline
Mechanical Lead 321
FRC #0321 (Robolancers)
KamalRC is an unknown quantity at this point
2590 in the Archimedes alliance in Einstein use mecanums... but for their intake .
Unread 26-04-2014, 20:19
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
There are certainly other COTS solutions to two speed gearboxes out there, but none I've ever found that are nearly as well tailored for FIRST applications.
We've used Andymark Super Shifters in past years, this year we went with a VexPro 3CIM ball shifter and were very happy with it. We also purchased a pair of 2CIM ball shifters but did not use them.
Here's a few things we observed from our 3CIM Ball shifters (This will probably look pretty similar to Joseph Smith's response above)...
Pros
  • Surprisingly lightweight (until you add 3 CIM motors of course)
  • Fairly easy to assemble, but not as easy as the 2CIM Ball shifter
  • Very durable, we took our shifters apart after our 2nd event to switch ratios, and the gears all looked like new.
  • Shifted without issue using the low profile pancake cylinders we got with them.
  • Shifting is virtually instantaneous and can (usually) be done while stopped, in addition to while moving.
  • Changing gear ratios is really easy if you're not also changing the shift spread since it only requires changing out the 3rd stage.
Cons
  • Changing the shift spread requires removing the tiny C-clips for the shifter coupling in order to get the ball gears out which is a HUGE pain. Other than that though the process was fairly simple.
  • We ended up having to create custom spacers to be able to face mount the gearbox with the 3rd stage and have it secured in more than 2 spots. Not a big deal but it would have been nice if something were included with the 3rd stage (or could be purchased) to accommodate this.
  • Assembly instructions could have been a bit clearer in places
For comparison, here's some things we've found out about Andymark Super Shifters we've used in the past...
Pros
  • Easy to mount
  • Decent variety of available ratios (though the Sonic Shifter has far more)
  • Completely enclosed gears (No external 3rd stage)
  • Easy to assemble
Cons
  • The servo shifting doesn't work reliably, don't even try.
  • Steel gears are heavy, but the lighter aluminum gears don't hold up nearly as well.
  • Parts of the assembly seem unnecessarily heavy (The spacer/cover piece in particular).
  • More expensive than its VexPro 2 motor counterpart.
  • Slightly slower to shift than a ball shifter
And finally, even though we did not use our 2CIM Ball Shifters on our robot, we did note the following:
  • They're the cheapest, by far of all the 2-speed gearboxes in common use in FIRST
  • They're very easy to assemble (from the time we opened the boxes we had them both assembled in less than 20 minutes).
  • They're very, very lightweight.
  • They have a very small profile
Beyond that, I would venture to guess their performance characteristics are very similar to the 3CIM ball shifters.
I've honestly been quite impressed with the VexPro gearboxes this year, I'd personally recommend either of their ball shifters.
4. Overall opinion on shifters?
Honestly it depends on the game. Some years there have been games that did not require a shifter at all (2009 comes to mind just to name one), but years like this year where you have a wide open field and a need to cross it quickly but also be able to play defense, a shifter is absolutely essential. The exception to this is if you're using a drive system built for maneuverability over pushing power (like using all omni wheels for instance), in that case a simple low reduction single speed would probably work fine.
Unread 26-04-2014, 20:29
Pros
  • Shifting is virtually instantaneous and can (usually) be done while stopped or moving slow.
Thanks for the detailed comparison. One question though; I was under the impression that the shifters can switch while moving (i.e. at the top speed of low gear)? You've said that it can be done while stopped or moving slowly; does this mean that you can't shift at speed?
Unread 26-04-2014, 20:47
cbale2000's Avatar
AKA: Chris Bale
Sorry, I should have been more clear, as far as I know all shifters can shift at speed, the benefit of the ball shifters that we found is that (in our experience) they can almost always shift while stopped in addition to at speed (think of it as a bonus feature).
This is a result of the difference between a ball shifter and a dog-gear based shifter, a "dog" must be lined up exactly with the holes in the gear in order to shift (and in the case of AM shifters, there isn't a lot of slack in the fit). By comparison, a ball shifter can "roll" into the notches in the ball gears much more easily and at a larger variety of angles relative to the gear, this allows for the shifter to work except in the rare occasion the ball lands on the "flat" between the notches.
Now, in most situations, you wouldn't notice the difference, especially when using pneumatics for shifting, since as soon as you accelerate from stop, the gears will usually engage in less than a second. It can, however, make a difference if for some reason you have an autonomous mode that includes a gear shift in it, especially prior to movement, since if one of the shifters has a longer shift delay than the other it can cause inconsistency in the autonomous.
Unread 26-04-2014, 20:56
Gotcha. That makes sense, thank you.
