Thread Tools |
Rating:
Display Modes |
Re: Which mecanum wheels to buy?
1523 used andymark mecanum wheels for the past 4 years and discovered a few differences between them:
6 inch wheels:
8 inch wheels
We have experimented with gear ratios, motor choice, and code as well. 2011: CIM drive 12.75:1 gear ratio on 8 inch wheels PID controlled 2012: CIM drive 8.45:1 gear ratio on 8 inch wheels PID controlled 2013: Mini-CIMs 8.45:1 gear ratio on 6 inch wheels PID at first event no PID at second- fifth 2014: Mini-CIMs 5.95:1 gear ratio on 6 inch wheels no PID loops We are happy with how our 2014 drive is performing although it was probably not a good choice for this years game. All 4 drivetrains have never suffered an on field mechanical failure beyond carpet/ field tape getting caught in the wheels and the occasional roller damage. Last edited by Max Boord : 23-04-2014 at 16:22. |
Our team has used both sets. In 2013 we used the 6in Andymark ones. This year, we moved to the 4in VEXpro ones.
Frankly, the 4in VEXpro set was rushed a little bit, and they had several problems. But I have discovered all the causes of these various problems and IMHO, despite all the problems we had with VEX, I think I prefer them. They have several problems which are being resolved, but these little things are nice and are very strong. VEX personnel were much easier to work with too. They sold us replacement roller at an extremely low cost for us. THEY WANT THESE THINGS TO WORK. The andymark rollers collected carpet really bad and had a lot of sticky rollers. The VEXpro ones handled these speed much better. But also, I haven't heard of a single team having problems with the 6in variation from VEXpro. I personally prefer the VEXpro variation, because the andymark wheels are just bulky and harder to work with IMO. Feel free to PM me any questions |
https://twitter.com/Team2611/status/...096000/photo/1 Everyone who had them at the tournaments we went to had a problem, especially their 2nd and 3rd events. But VEXpro was great with their support, just be ready to change them. |
On our 2010, 2011 and 2012 robots we used the original 8in AndyMark mecanums (w/o the side outer rollers). These worked well, but after a couple of seasons we had lots of bent axles (which can be easily replaced) and the rollers were pretty worn.
This year we decided to upgrade to the new 8in AndyMark wheels which are a lot beefier than our old ones. They can support up to 500 lbs per wheel, compared to 180 with the old ones. This helps prevent axle bending when if the robot ever slams into the ground (we accidentally drove our robot off the cart once and the wheels were fine). The main functional difference between the original AndyMark wheels and the new ones is the addition of a set of roller outside of the wheel plates. These greatly reduce the vibration of the robot as it rolls from roller to roller. My main complaint with the AndyMark wheels is that they are difficult to assemble. The roller bolts that were provided were just barely long enough to reach the nylon part of the nut on the other side and we had to get them just right to prevent the nuts from falling off or the rollers from binding. We had problems with rollers binding when the wheels were brand new, but after a lot of practice and a couple competitions they now roll perfectly and we haven't had any problems with them at all. Lastly, I would not recommend wheels that use plastic to attach the rollers simply because I have seen snapped off rollers too many times to feel comfortable with them. |
Why do you suppose this is ?
This is due to the 8 inch wheels having less (12 vs 16) and larger rollers (~ 2x the size) therefore causing the wheel to act in a slightly less round way.
Electronica1, the wheel upgrades where not out in 2012 which was the last time we used them. I would think the problem would still exist although slightly reduced with the newer wheels. |
#7
I have not investigated any of them to see which is/are of practical importance, but I can confirm the observed phenomenon, and it surely does have an explanation somewhere in theory. Last edited by buchanan : 25-04-2014 at 15:55. |
#9
I concur.
But my guess would be that the main factor is one not on your list: the transition from one roller to the next is not smooth. It's a not clean handoff. You can clearly see this on a shadowgraph. You can do this experiment at home:
Here's a mec wheel roller design calculator if anyone's interested: http://www.chiefdelphi.com/media/papers/2390 ... scroll down the list of attachments and download the one named "2011-09-30a mecanum roller design calculator" |
#10
I have noticed the same thing. The outer rollers on the new AndyMark wheels touch the ground during the transition from one roller to the next. When we compared our old wheels to the new ones we could feel the big difference that the extra rollers had simply by rolling them across a table.
#12
Did the 8 inch mecanum wheels have the outer roller upgrade?
#14
I used the AM 6 inch mec wheels in 2010 with 45 and didn't have a problem with the wheels (our robot frame is another story). On 461 this year the mecanums have been working pretty well with little in the issues department.
