Go to Post P.S. could we get Kanagasabapathy added to the spell check? or will it not handle words that big? :) - Holtzman [more]
Unread 25-04-2014, 10:18
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: New Championship Layout 2015
It will be interesting to see how this plays out. St Louis does not seem to have the infrastructure to support another 200 teams.
It also seems questionable whether there are another 200 teams that deserve to be at Champs.
2001-2004: Team 100
2006-Present: Team 254
Unread 25-04-2014, 10:23
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
If I were FIRST, I'd go to 8 divisions of 60 teams. 80 more teams means Championship won't overflow (which it was probably going to). Fewer teams per division means there'll be easily 12+ matches/team.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 25-04-2014, 10:24
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Thats exactly what I was thinking.
And Justin, I dont think the EJD can handle 8 full FRC fields. Can it?
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 25-04-2014, 10:37
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
If I'm not mistaken, this is what the footprint layout will look like. The yellow line is about 1 mile, as-the-crow-flies from the entrance to the Dome to Union Station.
Unread 25-04-2014, 10:53
Racer26 Racer26 is offline
It can house ~10 FRC size fields around the perimeter the floor (assuming 40x80 allotments). The problem is noise pollution from adjacent fields, as they're pretty close together.
Personally, I think 4x doublefield divisions are more likely than 8x singlefield.
Using doublefield divisions reduces the noise pollution issue (since 2 fields share a common audio feed), doesn't add a round to Einstein (which is already pinched for time), doesn't need as many volunteers as 8 divisions (but DOES need *some* more than 4x singlefield).
Additionally, doublefield divisions have much higher match throughput. 8x singlefield gives more matches/team by reducing the number of teams playing in a division. 4x doublefield improves utilization.
Also: I don't understand why people say scouting a doublefield division is too difficult. The fields are adjacent to one another, you can sit centrally and watch both. In 2004 and 2006 the Canadian/Toronto regional did exactly this, and it worked just fine. They played with 12 and 16 Elims alliances too.
Unread 25-04-2014, 12:15
Hallry's Avatar
Dare to be FIRST
AKA: Ryan Hall
Eh, I don't know about 10 fields...I don't even know about 8. Chief Dephi users have argued about this in the past:
(Image credit: Patrick Flynn)
Are you expecting the FTAs, Refs, Field Reset, Game Announcers, Emcees, and Queuing Volunteers to constantly run between the two fields?
If a single field has one division of 120 teams with 10 matches each, and a double field has two divisions of 60 teams each with 10 matches each, wouldn't it still result in the same amount of matches played per team? A doublefield may decrease the wasted time between matches though, which could increase the total number of matches player per team.
The 2006 Greater Toronto Regional only had 72 teams total, while having a doublefield division at Champs could be almost double that. Seating is already cramped as it is with 100 teams per division. I don't see having two fields with 150 teams total cramped together working out. Only a small majority would be able to actually sit centrally to both fields, most spectators will probably be towards the end of one of the two fields.
Unread 25-04-2014, 12:54
Depends entirely on how much space you allot per field. Double field divisions allow you to put them a bit closer together.
I calculated several years ago (2011 IIRC) that you can fit 10 FRC fields (I think I calculated on 40'x70' plots), on an NFL Football field. Both Georgia Dome and EJD have floors considerably larger than an NFL field (EJD is bigger).
IIRC, when it was done in Toronto (in 2004, 2006, and to a lesser extent 2011), you needed less than two regionals worth of nearly every volunteer type.
Instead of doubling the number, you increase it by some (say, 30-50%), and give the people (who will be working harder due to the non-stop nature of a double field event) more breaks more often.
Remember: We're getting a new control system (and likely upgraded/new FMS to go with it). There is no reason that it couldn't be designed to support 2 sets of field hardware from a single scorpion-case-replacement.
That's exactly what I was getting at. The time that field reset is doing their job is wasted for teams. Double field divisions significantly reduce that. 2x Single Field Divisions to replace one singlefield division will give twice the matches in the same time, sure. But it does so at the cost of doubling ALL of the field equipment PLUS all of the volunteers.
Doublefield divisions don't need to double SOME of the field equipment (mostly the computers) and don't need to double the volunteers, just increase it some. They don't generate quite 2x the throughput though. They get maybe ~85-90% of the way.
I worked out last year, that each of our four divisions could go up to 140 teams/division, 12 matches per team by doublefielding the divisions, without extending the schedule at all. Additionally, doublefield divisions allow you to run a 16-alliance elimination bracket in approximately the same time frame, which gets more teams into CMP elims.
While I agree seating is a bit of a challenge, you're comparing seating 140-150 teams to watch two fields, regardless of whether its 2 divisions or 1. Most spectators are not scouts, and thus aren't as picky about vantage point.
Toronto used to be played in an OHL Hockey Arena (Hershey Centre) with 5,500 seats. From what I recall, there were plenty of open seats still. EJD seats 66,000. (AFAIK, we stick mostly to the 1xx series sections, which represent maybe 40% of EJD's total, still ~6x bigger than Hershey Centre for an event a little over 4x the size).
Unread 26-04-2014, 20:52
221Sarahborg's Avatar
221Sarahborg 221Sarahborg is offline
Alumna Mentor
AKA: Sarah S.
FRC #1810 (Jaguar Robotics)
221Sarahborg is an unknown quantity at this point
Having three separate venues compared to even two sounds crazy, which just tells you how quickly the expansion of FIRST is going. Maybe the growth rate thing on the Top Ten this year may not be so crazy if they're doing that next year. They'd probably move to a more legible city to accommodate for how many teams go to Nationals for how many there are in just a matter of years.
Unread 28-04-2014, 18:52
Banderoonies's Avatar
Banderoonies Banderoonies is offline
Team Mentor
AKA: Sandra
FRC #0195 (Cyber Knights)
Banderoonies is a glorious beacon of lightBanderoonies is a glorious beacon of lightBanderoonies is a glorious beacon of lightBanderoonies is a glorious beacon of lightBanderoonies is a glorious beacon of light
I would love to see a Rookie Division so that a rookie champion can be crowned each year
Sandra
Unread 25-04-2014, 13:02
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
I'm more curious about how the extra teams will be chosen. More than six qualifying awards? Just more wildcards? Quantity of regionals increasing that much?
Very much looking forward to it. I'm sure we'll hear more once plans are solidified. I wouldn't be surprised if FIRST was still deciding what the setup will be. I'll have to wait until we get more detailed plans, but on paper this looks like a seriously good thing for the program.
I'm also curious about how much FLL/FTC visiting will be eliminated by this change. One of the cool things about Champs has been being able to visit teams from the other programs. I'm guessing separate venues will severely reduce that.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 25-04-2014, 13:07
The 2014 regionals/districts combined were already sending >400 teams.
Several new regionals are coming online each year.
As more district regions come online, you can dial up or down the amount of teams sent to CMP based on team density and available space at CMP easily. Plus in the early years of increased capacity, you simply go to the waitlist again.
Unread 25-04-2014, 16:51
DonRotolo's Avatar
Back to humble
FRC #0832
I believe it's FLL in the Renaissance Grand, with JrFLL and FTC at Union Station. The latter venue seems a bit far, doesn't it?
There's a convenient train system that takes a total of 2 blocks walking - a station at EJD and (of course) Union Station.
2 fields per division? Really? Why not just 8 divisions?
As for 8 (or 9) fields on the floor, no problem. Plenty of room.
Or maybe smaller fields...
Unread 25-04-2014, 17:12
coalhot's Avatar
coalhot coalhot is offline
Assistant to the regional manager
AKA: Phil
FRC #4454 (Artisan Rockets)
coalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant future
Send a message via AIM to coalhot
Wouldn't it be nice to have 8 alliances on Einstein? It would be more of a traditional elimination, with a standard schedule (no need for a mandatory 6 minute timeout between matches).
Current home, 4454 (Glowa's ghetto Philly FRC team). Check us out!
My posts represent my personal views only, and do not represent the views of my team, its school, sponsors, or FIRST.
Unread 25-04-2014, 17:29
dag0620 dag0620 is offline
Because we're FiNE
AKA: David Givens
FRC #1071 (Team MAX)
dag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond repute
I'm gonna be that guy to interject for a moment and say, just because they're moving the other programs to other venues, doesn't mean FRC is expanding.
A. In terms of in the Dome, we're only really losing FTC, so space doesn't become that available. Einstein will still have to be there. Yes we could physically fit in more, but that doesn't necessarily mean we want too. Noise pollution, and just the feeling of being butted up against another field would detract from the experience.
B. In terms of pits, yes this opens up space for a lot more teams. But also this allows FIRST to add a lot more features utilizing that space, including displays, a practice field for each division, space to make an epic Finale, and other things like that.
I think this move is more about letting the other programs grow their championships/Festivals, and less about FRC getting to grow. I could be wrong, but that's my $0.02.
David Givens
Alumnus Team Max 1071 ('13) | FIRST Volunteer | NE FIRST
Away making magic for a bit...
Unread 25-04-2014, 17:32
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Also, space for more involved ceremonies and other such things. FIRST got a lot of backlash for putting a concert stage in the dome in 2011 at the expense of 2 FRC fields, and now does not have to make such compromises.
