Re: I might be missing something with a 6 cim drive...
In addition to frying all 6 motor controllers, the plastic PDB would be molten as well. Your wires would be scalding to the touch, and there would be a large quantity of gaseous substance emitting from the robot. Basically, yes it is a bad thing, but no, it will practically never happen. This is really not something to worry about. We ran a 6 CIM VexPro ballshifter running 3" wheels, and geared to 5.5fps and 15.5fps. In addition to bulldozing everyone we faced, we never blew a breaker once. That being said, we did have a "ramp up function" in the code. Basically, if you jammed the joystick into full forward, the code would automatically and linearly increase the PWM "throttle" very quickly (read: like 1/2 second) from 0 to 100%. Even when throwing the robot from full forward into full reverse, we never had a breaker-blowing situation. The acceleration time is negligible compared to instant-100% because the ramp up is so quick and you have the comfort of knowing whatever you could possibly do to that joystick will not disable the drivetrain. The ramp up has the advantage of suppressing the instantaneous current draw into a slightly longer duration but lower peak draw. |
When testing this year, we found that a new breaker can take 6 stalled CIMs and a compressor (~250 amps) for about 25 seconds before tripping. Note that this is to a large extent cumulative over the course of a match, because these breakers are thermal and they don't dump heat instantly (or even particularly quickly); that is, if you stall for 20 seconds early on, you're going to be in real trouble if you get into another pushing match 30 seconds later.
Actually, I heard 254 stores covers breaker in ice packs or something right before the match. Not sure how true that is.
Of course if we go 6 cim we would have a shfting gearbox. That way we would have pushing power as well. |
Quick question, how would you stall a 6 cim drivetrain in normal usage? The wheels would lift at some point, even driving into a wall, right?
Of course, we would still build in current limitations and preferably shift. |
Even with 2 or 4 wheels off the ground, it's possible for your wheel traction to still be greater than the torque of a 6CIM drivebase (However, unlikely) Keep in mind that in a 6wd configuration, there are only 4 wheels in contact with the ground at any given time. It remains the same for 8wd, with only 4 wheels ever actively touching the ground (assuming center two wheels are dropped) Last edited by Dunngeon : 29-04-2014 at 23:19. Reason: More info |
Fun fact: 6 CIMs at stall consume a total of roughly 9576 watts of electrical power, which is over 9000!
Seriously though, a robot with 6 CIMs under "normal load" output (excluding friction) a total of 2.6 Horsepower, while a 4 Cim drive does just 1.75. At exactly 40 Amps per motor the numbers are (theoretically) 3.86hp and 2.57hp, respectively. And as everybody knows, power/weight ratio is the most important figure. ![]() ![]() |
#7
So have people stalled a 6 cim drive before then?
#9
Yes.
With a 125lb robot (including battery and bumpers) geared 6.1:1 with 4'' HiGrip wheels, we stalled 6CIMs when simultaneously running the compressor on a not-quite-full battery, resulting in a current draw of ~250 amps. With the compressor off and the battery completely full, the same robot spun the wheels and pulled ~180 amps. |
#10
But CIMs stall at 133 amps apiece...? (theoretically as always) their manufacturing specs say so. that would be 800 amps, aka very bad... |
#11
It's the same reason that you can stall them at all in the first place; if you naively just calculate from the stated stall torque of the motor you'll find that your robot would have to weigh an ungodly amount to stall them at any gearing you'd see on an FRC bot. |
#12
True true. I thought about that but did not account for it. As the resistance outside the battery decreases and approaches near zero (v=ir so 12=133r so r= ~.1ohms) (the motor stalls), the internal resistance inside the battery becomes a significant percentage of the overall resistance, so the potential difference beyond the two terminals is proportionally less than it were when the internal resistance was a small fraction of the overall resistance. Another point for Ampere's law. |
#13
I don't know. You can see some pretty interesting design choices in FRC. |
