Go to Post It's not about the robot. It's about science, technology, engineering, and mathematics. - Ether [more]
Unread 22-02-2003, 14:00
soezgg soezgg is offline
Senior Member
AKA: Harry Miller
#0639 (The Rude Awakening)
soezgg can only hope to improve
Send a message via AIM to soezgg Send a message via Yahoo to soezgg
the reason our team didnt want to use suction cups is that they are very finiky about their attatching surface...
dust, scratches, oils, moisture in the air all have an effect on how well they grip (or dont grip) the surface.
also: for a suction cup to operate properly the force on them has to be perpendicular to the surface in 2 directions.
when a robot hits it, it will be from the side.
we didnt think they would be a focused subsystem for our bot...
but good luck.
my 2 cents.
Unread 22-02-2003, 14:10
Duke 13370's Avatar
Duke 13370 Duke 13370 is offline
C is for cookie...
#0862 (Team Lightning)
Team Role: Webmaster
Duke 13370 will become famous soon enough
Send a message via AIM to Duke 13370
It's a bad idea to assume you're immovable, or unbeatable, or that much more clever than the rest of us.
Oh, i wish we were, but i know better. we spent mabye $20 dollars on the robot afte the kit and donations. Actually i think the zip ties were only $8, so we prolly spent more like $10.
Any way, I find the power that thing has very ammusing just because we've been testing this on dented, scratched tile, and it was very immpressive to see this thing pull us down.
---Lightning Robotics!---
Unread 22-02-2003, 14:13
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Good idea
This is a good idea and your robot will hold it's position over MANY other robots.
Let's look at this design and evaluate the impact:
It appears that the suction cups are being actuated up and down on a 2" dia cylinder (at 60psi, pulls at 170 lbs, pushes with 180 lbs).
Also, let's assume that they have the same mechanism on the other side of their robot.
From our team's experience, you can pull up on these suction cups with about 100-120 lbs of force before they let go (it depends on the cleanliness of the surface).
So... the cylinders push down, suction cups stick, and the cylinders try to pull up. They probably regulate the cylinder down to 40-50 psi in order to not pull the cups off of the floor. All of the force that they are pulling up on is being transferred to their wheels, and their robot essentially weighs much more than the actual weight of the robot. The downforce on the wheels is shown below in an equation:
Downforce on wheels = robot weight + left side cylinder/cup pulling force + right side cylinder/cup pulling force
Downforce on wheels = 130 + 100 + 100 = 330 lbs.
So... essentially, with both suction cups engaged and the cylinders pulling up, their robot weighs 330 lbs. Although it's not best design practice to simply let the cylinder shaft support the side loads on the vacuum cups, it's the wheels that are exerting the downforce, not the cups. An opposing team not only has to slide the suction cups, but also 330 lbs. of downforce applied to their wheels.
In order to push this robot, an opposing robot has to push with more force than this robot's holding force (at least that's what I call it). Their holding force = 330 lbs. x mu (their wheel's coefficient of friction).
Now, with regard to scratches, these cups still do pretty well. If they had a lower durometer, they may even be more resistent to scratches.
Great 'bot... good luck!
Andy B.
Unread 22-02-2003, 14:14
Senior Member
AKA: Harry Miller
not to complain...but i thought id help you out by telling you that your light shield is illegal...not that you can fix it now or anythign
Unread 22-02-2003, 14:21
Duke 13370's Avatar
C is for cookie...
HUH!?!?!?
Unread 22-02-2003, 14:26
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Your pistons are gonna get bent especially if a robot hits it directly, I hope you BOUGHT SPARES cause it takes a while to fix a bent piston.
Unread 22-02-2003, 14:38
Jeff_Rice's Avatar
Jeff_Rice Jeff_Rice is offline
ElementisRegamusProelium
#1359
Jeff_Rice will become famous soon enoughJeff_Rice will become famous soon enough
Yes, it is illegal, duke.
The top 4 inches of the rotating light must be exposed
Won't hurt ya to get rid of the shield, unless there are moving parts near your light that aren't shown.
"He said my name is Private Andrew Malone
If you're reading this then I didn't make it home
But for every dream that's shattered another one comes true
This car was once a dream of mine now it belongs to you
And though you may take her and make her your own
You'll always be riding with Private Malone" David Ball, "Private Malone"
Unread 22-02-2003, 14:45
comet22 comet22 is offline
comet22 is an unknown quantity at this point
I see your robot as being difficult to move... but by no means impossible... suction can gain you an advantage but most of that advantage will be as said before in downforce. To really gain an advantage being pushed from the side you need to draw vacuum. Also dont underestimate suction on scratched surfaces. It will take a pretty deep scratch depending on the material the suction cups are made out of
Unread 22-02-2003, 14:52
Duke 13370's Avatar
C is for cookie...
No big deal, we can fix that easily, but what about the rule that said "keep it protected", all that is is chicken wire.
Yeah, we can move it, but a lot of teams will really have their work cut out for them.
Unread 22-02-2003, 14:59
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Your light isn't illegal. Don't worry about it. It's upright, it's visible, and it's protected.
--Madison--
...down at the Ozdust!
Unread 22-02-2003, 15:14
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
You want a pic HUH?
Pushing a 300+ kid on our team.
http://www.tahsroboticsteam.org/new/2003-02%20(Feb)-15c/HPIM0162.JPG
Pushing old robot up and over ramp....
http://www.tahsroboticsteam.org/new/2003-02%20(Feb)-15c/HPIM0170.JPG
Aftermath of pushing old robot up and over....
http://www.tahsroboticsteam.org/new/2003-02%20(Feb)-15c/HPIM0174.JPG
P.S. Our wheels are made of (insert words here), they are 6 inches in diameter and are 2 inches wide.....
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 22-02-2003, 15:47
Duke 13370's Avatar
C is for cookie...
none of you links work
Unread 22-02-2003, 16:10
Jeremy_Mc's Avatar
Jeremy_Mc Jeremy_Mc is offline
GitHubber
Jeremy_Mc will become famous soon enoughJeremy_Mc will become famous soon enough
Re: Good idea
again this all relates to the orientation of the robot...sheer vs. tension. it also relates to how fast the other robot is going and how concentrated the force is (remember, force and pressure are not the same thing).
Originally posted by team222badbrad
P.S. Our wheels are made of (insert words here), they are 6 inches in diameter and are 2 inches wide..... [/b]
6 x 2 is wide, but you have a small wheel compared to many teams...we have some wheels made out of err...rubber? that are 8" x 2". not that it gives you more traction, just faster speeds.
*jeremy
GitHub - Collaborate on code, documentation, etc. - http://github.com
Unread 22-02-2003, 16:29
Duke 13370's Avatar
C is for cookie...
Our wheel are 8.5*2 (apx, we shaved a little off), but that doesnt matter mch when we are being held to the floor.
6*2 really doesn't give you any more traction, just a little more of torque.
Unread 22-02-2003, 17:37
Dave_222's Avatar
Dave_222 Dave_222 is offline
I used to be cool.
AKA: Dave the Knaive
#0222 (Tigertrons)
Dave_222 will become famous soon enough
Send a message via ICQ to Dave_222 Send a message via AIM to Dave_222 Send a message via Yahoo to Dave_222
if you knew what they were made of you would under stand. there are more factors than diamiter or width.
"Get up and save yourself from youself."
Maynard
"Let me intorduce myself," the man said. "My name is Roosta, And this is my towel."
