Go to Post Cameras, colors, and tetras, oh my! - galewind [more]
Unread 27-04-2014, 01:54
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (MVRT)
Re: Hexagonal Chassis + 6 CIM swerve drive
If you are using coaxial swerves, I can't see a reason why not to simply use the drive sprockets to power two wheels at once, then use separate turning motors for each wheel. You can even technically use a single 6 cim gearbox to power any number of modules.
Unread 27-04-2014, 03:20
Tyler2517's Avatar
Tyler2517 Tyler2517 is offline
ShortOnes
AKA: Tyler Gibb
FRC #2517 (Evergreen Robotics)
Tyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura about
If you do this you cant have a true 3D swerve drive (X,Y,rotation). Changing the power to each wheel is how you preform holonomic maneuvers.
Unread 27-04-2014, 03:44
asid61's Avatar
AKA: Anand Rajamani
FRC #1072 (MVRT)
Oh really? That's annoying. Thank you for the information.
Unread 27-04-2014, 03:51
Tyler2517's Avatar
ShortOnes
AKA: Tyler Gibb
I think at that point it would be a crab drive or something close to it i might have some hidden benefits but a true 4 wheel independent should out perform it. (or 3 wheel independent)
Unread 27-04-2014, 04:10
Tyler2517's Avatar
ShortOnes
AKA: Tyler Gibb
So random question
What happens if you have say a 8 wheel swerve and you powered the wheels in sets of 2. Could you code them to act like any 4 wheel swerve?
Unread 27-04-2014, 06:28
asid61's Avatar
AKA: Anand Rajamani
FRC #1072 (MVRT)
So random question
If you have to change speeds for holonomic motion, I don't think you could do that even if it's a multiple of 4.
Not to mention 8 coaxial swerve modules plus the associated turning motors/ gearboxes would be massive. That would weight at least 18bs for the coaxials, 2lb per shifter for 8lbs more, and 8 turning motors at 0.5lbs each plus all the chain and sprockets. So 30 lbs+ just for the swerve modules.
Livable, but I'm more worried about space even with coaxials.
Unread 27-04-2014, 06:36
TheHolyHades1 TheHolyHades1 is offline
TheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the rough
So random question
I don't think so. It is an interesting combination, but if I'm not mistaken swerve works on having the ability to control rotation about a point and not a line. You need to power each different point in the rotation at a different speed, and without some sort of differential that wouldn't be possible in swerve.
Unread 27-04-2014, 07:30
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
To the extent that the unpowered omnis are supporting weight, they are robbing traction from the driven wheels.
Why not raise the omni's axel center up an 1/8th (maybe less? 3/32?). This would allow the 3 powered wheels to have optimal traction, while still having good stability when being pushed. At the expense of traction.
(2015-?): 973
(2012-2015): 955
Unread 27-04-2014, 09:12
You could code them like a 4 wheel swerve, be they wouldn't act like a 4 wheel swerve because it wouldn't be kinematically correct. When turning, the wheels would scrub.
Unread 27-04-2014, 11:18
Oblarg Oblarg is offline
AKA: Eli Barnett
To anyone having a hard time understanding why you need to power and turn wheels individually for a true swerve:
Take a rectangle. Move it in some manner that involves both a translation and a rotation. Pick some set of arbitrary points (say the corners), and imagine those are your wheels. It should be easy to see that for any generalized movement, those points are all moving in different directions and at different speeds.
"The breakfast of champions!"
Unread 27-04-2014, 11:30
Correct.
For anyone interested in the math, here are the equations:
http://www.chiefdelphi.com/media/papers/download/3236
Unread 27-04-2014, 13:46
Dragonking's Avatar
Dragonking Dragonking is offline
AKA: Aaron Cannon
Dragonking is just really niceDragonking is just really niceDragonking is just really niceDragonking is just really niceDragonking is just really nice
You could try using 4 cims and 4 mini cims for 4 modules.
2013-2014 Mechanical Subgroup, Scouting Captain
2015 Design Subgroup, Strategy Lead/Scouting Captain
Unread 27-04-2014, 22:48
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Here are 10 pictures of a "semi-swerve" drive I built at about 1/3 FRC scale, using servos to steer and independent motors to drive. The last 8 pictures show how you have to orient the wheels to move various directions, including pivoting around selected points. (These are views from below).
Unread 28-04-2014, 15:58
swerve inverse kinematics math quiz:
http://www.chiefdelphi.com/forums/sh...d.php?t=129185
