Go to Post We've done that autonomous. After several years of refinement we decided to skip the information collection and just drive into the wall at the earliest opportunity. - Greg Young [more]
Unread 27-04-2014, 22:59
T^2 T^2 is offline
FRC #5499
VEXPro 2014: After The Season
You know the drill.
3-CIM Ball Shifter
This product was a bit of a mixed bag, but the upsides outnumbered the downsides. The gearbox is light, generally reliable, and has a good variety of speed options. We used ours in a WCD with WCProducts bearing blocks, and once the drivetrain was together, we never had a problem with it. We were fast in high gear, pushy in low gear, and only once had to run maintenance on the gearboxes themselves (see next paragraph). Definitely a solid choice for teams wishing to save time on custom gearboxes. I maintain my stance that the ballshift mechanism is both faster and more robust than shifting with dogs.
Most, but not all, of the problems we encountered with these gearboxes arose from user error. Notably, the mounting nuts on the sides (or rather, the top and bottom, when mounted with the stock 3rd-stage plate we used) are not meant for high loads, and will tear through the shell if used in that manner. We found two significant problems that are, I feel, an inherent part of the design. First, the stock 3rd-stage mounting plate's holes for mounting to the frame (of a WCD, in our case) are asymmetric: one is horizontally 1.976 inches from the 3rd-stage output, and the other is 2.024 inches horizontally from the same. This is compensated for by an increase in the hole size. I cannot possibly imagine why the holes could not be symmetric.
The second issue, which is a bit more important, is that the gearbox feels as though it is not designed with a west coast drive in mind. Attaching a WCP center bearing block to the system requires using low-profile 10-32 nuts on the inside of the plate, which are difficult to access with chain in the way. (There might be a better way to do this, but I can't find any documents that say so.) Furthermore, the 3rd-stage shaft runs through two bearings that insert in the same direction: one is a press-fit into the nylon shell, and the other is a slip-fit into the bearing block. If the press-fit fails, as it did for all four of our gearboxes, then the entire output shaft assembly will partially slide out of the robot until about half of the output gear is in mesh. To solve this, we had to Loctite the outside bearing into the bearing block. I'd really rather not.
Speaking of Loctite, this year's ballshift shaft assemblies are an improvement over last year's. We noticed no issue with the shaft coming out of the housing, unlike last year. However, this wasn't the case with all teams; at Champs, I helped another team perform an emergency Loctite replacement on one of their drive gearboxes because the shaft had extracted itself. Overall, I can say that while a better job was done this year with regards to Loctite application, I still wish for a mechanical connection between the shaft and its housing.
Last note: while we didn't use it ourselves, multiple teams with whom I spoke were satisfied with the new plastic encoder gear.
VersaPlanetary Gearbox
The advantages to these are the same as last year; I'll focus on the problems with the new stuff. The 7:1 gear stages we ordered had weak welds, which cracked in short order. I'm sure this will get fixed soon. The main problem we experienced this year was with the new plastic motor mounting plates. While a step up from last year's system, the plates were difficult to attach to the gearboxes because their mounting holes had extremely thin walls around them; tightening the mounting screws just a bit too much led to fracturing. Please either make these out of aluminum, or improve the wall thickness. (Doing both would be best; one of the secondary disadvantages of the plastic plates is their poor rate of heat flow for purposes of motor cooling.)
We found out the hard way that these gearboxes are not meant to take heavy loads while powered by MiniCIMs. They're great for intakes, though.
WCP Cam
Amazing. I wish the hex shaft on the steel model could be a bit longer, though.
Wish List
A 17t #25 sprocket option, for chain-in-tube drives.
A stock butterfly module, paired with a stock frame that can use it.
A hall-effect sensor magnet with the same center hole, but a smaller outer diameter.
That's about it for what 1678 used. If anyone could elaborate on the quality of the VersaWheel DT, the dual-input VersaPlanetary, or the plastic pulleys, that'd be great.
Unread 27-04-2014, 23:54
FRC #1836 (MilkenKnights)
Re: VEXPro 2014: After The Season
We ran chain in tube for our intake this year, and it was a very unpleasant experience. Maintenance is an issue, and you have to be wary of where you place fasteners. A drive would likely be less maintenance than an intake(because it was running significantly faster), and I know that 118 has run a chain in tube drive successfully, however personally in the future I would only consider running belts in tube.
Unread 28-04-2014, 00:11
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Versawheel DT wheels (4" bearing bore) were awesome. We ran them for two regionals and experienced minimal wear. Cheap, effective, and frankly better than any wheel we've used before (that being said, the team hasn't ever used Colsons).
We also used VexPro VersaPulleys, which were absolutely fantastic. I don't think we had a single failure, and they interfaced very nicely with the VersaWheel DTs to make a drive train that didn't break once during competition.
I think 2220 will be using VexPro products for years to come...
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 28-04-2014, 00:19
Aren Siekmeier's Avatar
on walkabout
VersaWheel DT (3.25 Hex Bore)
We sort of fawned over these when they were released, due to their smaller diameter and the fact that they were all one piece, hex bore included, and did not require any additional hardware to mount a heavy, expensive hub. And they were dirt cheap, too, at $6 a pop. Unfortunately, they turned out to be worth about as much: on our practice bot a bit over full weight, we had them slipping at half power, not even close to the static friction supplied by our favorite blue nitrile. We promptly replaced them with 4" performance wheels from Andymark for our comp bot, which were well worth the 500% price increase. I have since heard some stories of the plastic VersaWheel tread melting to the carpet under the right slipping conditions...
HTD Belts and Pulleys
The selection here was great. We only used the metal hex bore pulleys, and I don't think this will change anytime soon... No problems with belt or pulley wear, though we did pop a few flanges off from hard impacts
We absolutely love these. The machining and finish is beautiful on every last part, and they are significantly cheaper and more flexible (for input motor options, ratios, and output shafts) than the P60s they have come to replace. Our only qualm was, as you mentioned, the plastic motor mount plates. Over tightening the screws (an easy thing for an unsupervised minion to do) led to fractures, as did, of course, using thread-locker (another common mistake when unsupervised). We also could have done a better job shielding the BAG attached to it from impact stresses. We saw 3 or 4 identical failures of the plastic mount plate, all of which also resulted in a bent BAG shaft as it fell out of the gearbox. We also invariably lost a sun gear or two in the process. So in the future, we'll be looking into replacing this one part with our own aluminum alternative. Still sure beats building your own gearbox
3-CIM Ball Shifter
After designing our own dog shifters the last two years, we decided to refocus our machining resources by going COTS this year. Turned out to be a good decision, since that sponsor had to bail on us last minute D: We selected the WCD option and had no problems interfacing it with our system. Though I still am a little baffled at the asymmetrical mount holes on the 3rd stage plate, considering how close they are to being symmetrical.
We also once ran into an issue with the encoder mount screws inside the housing coming loose, requiring us to completely disassemble the gearbox to super glue them back in (not a whole lot of fun). Perhaps these screws should thread all the way through the standoffs? Not positive exactly how to fix this without the super glue.
The plastic encoder gear on one of our 4 units did end up losing its press fit over time, so a keyed shaft may be worth considering. Super glue would also work just fine.
In general, we were very satisfied with the price, quality, and availability of all our purchases. Impressive that all three of these were achieved when we're typically told to "pick any two." There were notable improvements in getting parts shipped out during build this season, and none of this affected us since we had ordered all the high priority drive items before build even started. However, the nature of the 6 week build still makes this a problem for some, since a 2, 3, or even 4 week wait can really be a killer.
Unread 28-04-2014, 00:21
Boe's Avatar
Boe Boe is offline
2175 Alum
AKA: Brian Boehm
Boe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud of
3 CIM Ball Shifters:
We had an amazing experience using these after we finally got them, they were light ran great, and had lots of options available.
Versaplaneteries:
My favorite product this year the amount of different stages and motor combinations is insane. I would also like to see the motor mount plate be aluminum if possible.
3.25 Wheels:
We decided to go with these over our usual blue nitrile wheels in the build season, but after getting them on the robot and driving them we really did not like how quickly they wore and didnt feel they gave enough traction compared to the blue stuff. We ended up switching to AM Performance wheels in the last week of build.
New product wishlist:
All in one options for wheels with hex built in. I would absolutely love to see all the vex wheels have a one piece hex option so the hubs are not required thus reducing part count.
2014 IRI-Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship-Winner (Thanks 2052, 4778)
2014 Archimedes Division-Quaterfinalists (Thanks 399, 2056, 2834)
2014 North Star-Semifinalists (Thanks 967, 4607)-Creativity Award-Safety Award
2014 Northern Lights-Winners (Thanks 359, 2502)-Excellence in Engineering-Safety Award
2013 Minne-Mini-Winners (Thanks 2169, 3883, 4239)
2013 MRI-Winners (Thanks 2052, 3130, 3313)
2013 MN State Fair-Winners
2013 IRI-Participant
2013 Minnesota State Championship-Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
2013 North Star Regional-Team Spirit Award-Winners (Thanks 967, 4607)
2013 Northern Lights Regional-Entrepreneurship Award-Quarterfinalists (Thanks 3130, 1675)
2012 North Star Regional-Creativity Award-Quarterfinalists (Thanks 2549, 3130)
2012 Lake Superior Regional-Coopertition Award-Quarterfinalists (Thanks 1625, 2957)
Unread 28-04-2014, 00:26
DampRobot's Avatar
Physics Major
AKA: Roger Romani
VEX Pro 3 CIM Ball Shifters
I had a more mixed experience than T^2 with the ball shifters.
First, I didn't find them as nearly easy to maintain as he did. I consider myself pretty good at figuring out how stuff goes together, and pretty good at fixing things, but I found these gearboxes a bear to maintain. It took two pretty smart guys two full days with my help (and the instructions) to assemble these gearboxes. I don't remember other gearboxes taking so long to go together. A lot of it is there are a lot of different fasteners that need to go into the gearbox, and another big part is that things have go together in a very specific, non-obvious way. If you put it together wrong, you suddenly have to take the whole thing apart again, all because you forgot to put a tiny nut into the inside of the casing in step 7.
Also, they fell apart on us a lot. Over the course of the season, the screws inside of the casing that hold on the encoders or pancakes worked their way out. We had to fix each several times over the course of the season, despite loctiting and tightening as much as possible. It wouldn't be that big of a deal on an open gearbox, except you have to take the whole darn thing apart to get to those two tiny screws because it's a closed gearbox. Also, they're pretty sensitive to the screws holding the case together being overtighened. I remember having to rebuild one side of our comp drivetrain on ship day because it was binding. Turned out that one of the screws holding the casing together was just a tad overtightened, which killed our efficiency on one side of the drivetrain.
The ball shifting is nice. I like it. I wish the shifter cone was a bit nicer, maybe metal like the WCP ones used to be instead of the two side plastic casing it is now.
I liked having a lot of ratio options, and the quality of the gears was very good.
I agree, this gearbox really isn't designed around WCDs.
I'm advising my team next year to go with the 2 CIM DSes. They're a lot smaller, we haven't had reliability problems with them in the past, and they're a ton easier to service. Finally, they're really designed to do a WCD, instead of adapted to work for it.
VersaPlanetaries
This is probably one of the best products ever to hit the FRC market. It's a planetary that just works, and has a ton of options. It's really revolutionized how we build manipulators. I especially love the dual input VersaPlanetary, it's an awesome way to build a crazy powerful arm/whatever really simply.
Pulleys and Belts
Like a lot of teams, we had problems with snapping the belts. I believe this is a MFG issue (and if so, something VP NEEDS to fix), but if it isn't I at least hope were told better load rating specs for these belts. We shouldn't have to worry about belts snapping in something as critical as the drivetrain.
Other than that, it was nice to have hex broached pulleys and an easy way to get belts and pulleys.
VersaWheels
I have mixed feelings. It's nice to be able to replace wheels instead of retreading them (because dealing with tread is a PITA). The wheels have a really great traction right out of the box. On the other hand, they wear extremely quickly, to the point where if we had the supplies, I'd want us to change them out every three matches or so. Also, once they're worn, they have essentially no sideways traction, so they absolutely suck once you get T-boned (thanks 971!). The DTs wear slower and have better sideways traction, but don't have as much forward traction as a new VersaWheel OG.
I'm going to tell my team to do blue nitrile wheels again next year. They are a pain to tread, but don't wear as quick, and have grip to spare.
Hex Spacers
Who knew such a dinky little product could become so useful? I essentially never design in spacers now, I just trust the kids to find the right combo of spacers/VP hex shaft collars to work without any custom design/lathe work.
CAMs
Are the bomb.
-Plutarch
Unread 28-04-2014, 04:16
Thad House Thad House is online now
Volunteer, WPILib Contributor
no team (Waiting for 2021)
We used a lot of VexPro parts this year.
WCP 3 CIM SS WCD
We used them this year, and absolutely loved them. They were reliable, easy to assemble, and easy to mount and remove from the robot, which we had to do multiple times because of belts. They were light, strong, and in general out of the way of the rest of our robot. The only problem with them is that the flanges for the bearing on the main shaft both face the same way, so if the press fit fails, the shaft moves. So please flip the bearing on the back plate and include spacers the correct length so the flange can go on the outside. We fixed that this year by screwing bolts with washers over the flange on the inside, but for next year that would be a great fix. And, even though its not provisioned for it, there was an easy way to mount E4P encoders using just some 3d printed parts and the cutouts in the plate. The only issue we had was them not showing up until week 4.
1/2 Hex Shaft
Love it. Used it on our drive. Never failed once. 'Nuff said.
4" VersaWheels W & DT
We used both on our robot this year. We used the W's in the center, and DT's on the outsides. We have some mixed feelings about them. They wore down really fast, and we were replacing them once an event. They were noticeably loosing sideways grip the later in the event they got. By the end of Galileo finals, one of our DT's was starting to bubble, and another was cracked down the side where it meets the tread. But when fresh, they had tons of grip.
VersaPlanetaries
We used them for the first time this year, and overall we had a good experience with them. We originally had the 7:1 and 9:1 sets, but then they started cracking, and we moved to the smaller reductions. We had issues a few times with screws coming loose, but mostly we just have to make sure to loctite better. One suggestion is to fix the pricing. Buying the gearbox with 3/8" Hex output is $29.99. Buying the 1/2" Hex shaft is $7.99. So why does the one with the 1/2" hex already installed cost $39.99. It just doesnt make sense, and we actually bought the 3/8 and then installed the 1/2 inch to save the money and get more at the same time. Because we did this, we had the snap ring come off of the practice bot, because we could not get the snap ring in right.
Belts
Ah belts. This year we had 6 CIM's. We used 24t 9mm pulleys with 130t belts. We snapped 6 of them over the course of the year. I heard that next year there is going to be a 27t pulley, and the belts are going to be much stronger, which is why I'm not going to worry too much. But please for the belts publish the torque ratings of the belts so we can do the calculations. We switched to using 18t sprockets and #25 chain at worlds, and had no problem whatsoever with it. But if the belts next year are stronger, and we can get bigger pulleys that will fit a WCD we will go back because we loved the students.
Overall, we liked most of the VexPro stuff we used this year. But I do have some suggestions for improvements.
  • Sell the WCP DS with the 3 CIM SS plates. I know they have the exact spacing, so it should be easy. Or sell all the pieces individually so teams can mix and match.
  • If you are going to sell something for the season, make sure it is in stock at the beginning, and not at week 4.
  • A 27 tooth and a 47 tooth gearset for the WCP SS gearboxes. We wanted 10.5 FPS, but to get that, we had to use 14t pinions, which again showed up really late. with a 27-47 we could have used a 12t and gotten very similar to the same ratio.
Team 4488 - Mentor 2013-2016
Unread 28-04-2014, 06:09
Samwaldo's Avatar
Samwaldo Samwaldo is offline
College Student / Between Teams
Samwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to behold
Single Reduction, Single speed gearbox (7:1)
6 CIMS!!! Overall an extremely simple gearbox that was quite reliable and did its job better than we thought. We became known for our drivetrain and won an Engineering Excellence award for it. Were glad we bought 2 extras, and never needed them.
Our only problems/complaints: 1) cover the sides of the gearbox. We created our own covers so that stuff wouldnt get into the exposed gearboxes 2) The hex collar would occasionally slip which would create slop but we could still drive with the gearboxes
Overall easy to deal with and they gained new customers from us.
Team 1099, The DiscoTechs, 10' - 14'
Driver 11' - 14'................Team Captain 13' - 14'
University of Hartford Class of 2018, Mechanical Engineer
2015 & 2016 NE District Volunteer
Unread 28-04-2014, 11:54
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
VersaPlanetary
Used 2, both with BAG motors. One was a 7:1 reduction going to 1.75" Banebot green wheels for our intake. The other was 100:1 to our winch system. Both went together in less than 5 minutes, both worked flawlessly for 3 crazy events.
VersaHubs
We used a lot of different hubs during prototyping. Yet it turns out we only had 2 sprocket hubs on the entire production robot, and they weren't used for sprockets . Dog gear, anyone?
Colson Wheel Hubs
I like the WCP version over the longer VexPro version, yet both worked great. I would like to see VEX Pro (or someone we use often) start carrying Colsons so we don't pay $26 in shipping for $60 worth of wheels.
1/2" Hex Axle
We had an issue with the 36" version of these coming in bent slightly over the 36" length. We were unable to ascertain if this happened during shipping. The straighter 18" version was used on our intake, and the 36" version wound up being a nice lightweight strong set of arms for our catapult.
Framing Plates
Used for ridiculously fast prototyping. Only a couple made it onto the production bot, but they were in key positions and held up nicely.
Hex Shaft Collars
Love them. Love how thin they are, love that they work flawlessly and love that they're black.
Hex Bearings
Used a mix of AM and VEX Pro bearing on the final robot. I think we tacked them on to the orders that were going in at the time, so there was no real engineering reason for one supplier vs the other. All hex bearings worked great though.
Excited For Next Year
1885 mentors are very cautious early adopters. New technology represents the opportunity to take a risk and we limit our risk by limiting the amount of brand new product releases in a given season across all of our suppliers (VEX Pro, AM, WCP, etc). Admittedly only 25% of post-season risk evaluation is from talking to teams - the rest is based upon anecdotes from CD. We only do this because we have over-used "new" products where we apparently overlooked "proper" use in prior years. With that said, here are the "new" VEX Pro items which were thought about this year and will move into our "low risk" evaluations for next year
WCD Bearing Plates (outright excited, to be honest)
WCP DS Gearbox (final config TBD)
15mm HTD belts (general), or 9mm HTD belts for light applications
Bevel Gears for intakes
GitHub
audietron's Avatar
audietron audietron is offline
Red for mediocre performance
AKA: Grayson Burgess
FRC #0965 (X3 Robotics)
audietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to behold
Drive in a Day 2014
This frame is very good. We were able to mount the 3.25 wheels nicely for an incredibly low ground clearance. It was convenient for just about any thing we needed to mount.
Versawheels dt (3.25)
These wheels were great for the most part. I like that they have the hex bore but our problem with them was that we would have traction for about a day of competition matches. This meant we changed out the wheels friday night and would have some traction issues during eliminations because of the large amounts of defense. It would be awesome if they made the spike tread into hex bore and 3.25.
P.s. (A live axile version of the 4 inch mecanum wheels would be great for an off-season project we have.)
2015: Galileo Semifinalists
2015: North Star Regional Finalists (Thanks to 5576 and 2531)
2014: North Star Semifinalist (Thanks to 2175 & 4607)...again
2014: Central illinois Semifinalist (Thanks to 1756 & 1288)
2013: North Star regional Winner (Thanks to 2175 & 4607)
2013: Curie Semifinalist (Thanks to 2056 & 3990)
2013: IRI Semifinalist (Thanks to 359, 1477, & 148)
Unread 28-04-2014, 14:10
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Overall I was impressed considering I was very disappointed by some of the quality from last year in the two-CIM ball shifters and Versa Wheels.
After weighing the pros and cons with our mechanical team we decided to go with the 3 CIM Ball Shifters after discussing what the failures were from last year and how we could prevent them. We narrowed it down to three areas all of which had fixes. To combat our biggest issue from the year with the output shafts falling out (including the replacements) we immediately pinned the shafts this year as a precaution. The second was the odd design of the encoder standoffs having the screws on the inside of the shifter housing. Last year we had a few on the inside come loose and destroyed our encoders. We put some Loctite on these bolts and made sure they were nice and snug before assembly. The last part was swapping for the updated encoder gears after the original press fit ones came loose. We replaced these gears in week 6 but the original two mods were done in minutes during assembly. Overall they were the most reliable shifting gearboxes we have used in four seasons and they lasted through our longest competition season of the year running in 5 competitions and hours of practice without failure.
My only suggestion would be to revisit the mounting of the encoder to eliminate the interior bolts on the standoffs because you can't tighten them without ripping the whole thing apart.
We were very satisfied with the other products we used and the only issues we had were with our VersaPlanetary gearboxes but they weren't assembled correctly the first time around which was our fault.
1058 PVC Pirates 2016 - xxxx
Unread 28-04-2014, 16:40
Chris is me's Avatar
AKA: Pinecone
VersaPlanetary Gearbox + BAG
These gearboxes are really awesome. Very easy to put together, mounts a number of different ways, and gear ratio changes are a snap. We designed for and bought one ratio, tested it, and then decided we wanted to up the torque a bit. All we had to do was buy another gear set, take it apart, swap it in and go. Assembly or a gear swap is a 30 minute job for freshmen whom had never assembled a gearbox before. These are great for prototyping as well. Cool bonus: An 18T HTD pulley fits right on it with plenty of belt clearance even if side mounted.
BAG Motor we had no problems with. Robust, never got warm, no finicky motor leads to deal with, etc. That said we did not apply much load.
Mecanum Wheels
Did not use these on the ground, so I can't comment on their build quality under drivetrain loads, but these wheels were killer on our intake this year. I think these made us the best pickup at our events. Rubber is grippy and Colson-like on these rollers; great grip on this year's game piece. The weight wasn't too bad either. We'll definitely be playing with these on manipulators in the future.
VersaFrame 1x1 .04" wall
The Good: Hole pattern stock is awesome. Not having to drill in a pattern saves so much time and is so easy to play with. We initially used it for our roller claw as it was versatile enough to let us change geometry around. All in all a pretty awesome system.
Don't let the relative length of these sections fool you: I'm a fan of the VersaTubing and would buy again, particularly if it came in different wall thicknesses or hole diameters.
The Bad: .04" wall is only good for some really specific no load applications. Obviously this stuff shouldn't leave the bumper zone but even inside a frame you need a well supported system to survive any kind of impact or cyclic loading.
When we designed the claw using this stuff, we knew that many / most members would not be robust enough to last through competition. We decided we would replace members that broke on the practice bot with thicker wall members until we stopped breaking things. I'm not criticizing Vex for our use of the product outside the bumper zone as we knew what we were getting into and designed the rest of the claw to be strong (solid standoffs, flat "belly pan" pieces to tie things together, etc).
The very thin profile is weaker than I could have imagined and failed in very interesting ways. We used screws mounted to one side of the tube (tool clearance on the other) to retain a dead axle that our intake pivoted about using pneumatics. The axle holes here, as well as the holes that we mounted the pneumatic pivot to, deformed under cyclic loading to the point where the holes were noticeably ovalized and the mechanism had significant slop. We fixed this by adding material to those areas - usually with a thicker gusset plate - but even 16 wall tube had this problem far less than the Vex setup. We also found that over tightening a bolt going through both sides of the tube would very quickly cause the tube to sink in or pull out, without much resistance to warn you of what's happening.
We had our pneumatic pistons mounted to a plate which we riveted with four rivets to a set of 2x 1x1 tubing. The force of these pair of 3/4" bore pistons at 30 PSI was enough to rip the tubing outward, eventually shearing rivets right off. Upgrading to 3/16th rivets helped with the rivets not breaking anymore, but the failure moved to the tube instead of the rivets! We found this was the case with this tubing - if you upgraded to high strength 3/16" aluminum rivets, the tube would plastically deform dramatically before a rivet would break.
VersaFrame 2x1 .1 Wall
We didn't use much of this stuff (just on the shooter), but it was really nice. .1 wall is a good compromise between 1/8" and 1/16" wall material that's commercially available. Again, the built in hole pattern is awesome. We didn't have much need for the alignment lines on the sides but those are a nice addition for locating hole centers and an easy way to tell at a glance if a hole is "dropped".
VersaFrame Gussets
Also excellent. Just the right thickness at .09. Easy enough to drill out to whatever rivet size you feel like using. Saved us a lot of time making these on a router or the haas. The End Bearing Gusset is a really cool and rigid way to put a roller on a stick. The bent 90 degree Angle Gussets are incredible. This is a very hard part to make for us as it requires precision bending, but it's been a part we've always had a need for in odd places. Allowed us to strengthen a small unsupported section of claw tubing very easily. Bearing hole is a cool bonus that I'd like to find a use for someday.
VersaChassis in General
The 5/32" hole pattern was kind of awkward. I would have much preferred a hole pattern for 3/16" rivets that could be drilled out to #10 clearance. #10 hardware and 3/16" rivets seem to be the standard in FRC for a lot of teams. It's fairly easy to find rivets in that size and you can get a variety of different kinds (colored rivets, high strength aluminum, etc). 5/32nd rivets that we used are a bit weird and didn't have the large grip range we were used to with 3/16" rivets.
Overall, I would like the system a lot better if it used a 3/16th rivet hole pattern and if the 1x1 was available in .063 and .1 wall as well as .04 wall. Either way though, it's a very cool system that can really help teams out regardless of resources. We'll be using these products in the future. Perhaps with our own 1x1 tubing though.
HTD Belts & Pulleys
We decided that the quick lead time of Vex belts in build season was worth switching from GT2 to HTD even if it is a theoretical downgrade. We used 15mm Vex belts with 24T B&B pulley stock in our drivetrain. No problems whatsoever to report. No ratcheting, performance changes, or otherwise. Exact centers with 15mm belts are a very good system for FRC drivetrains.
We used a 9mm belt with 18T pulleys on the claw roller. We used CAD to model an exact center distance between parts in an assembly and it ran just fine with no problems. Pulleys were light and durable. The belt subjectively seemed looser than one might expect but it ran like a champ. I don't think I would want to manually tension these belts and just guess the "right" tension when exact numbers work so reliably. These belts aren't going to stretch in an FRC season.
Vex 1/2" Hex Shaft
This stuff is awesome for 99% of use cases. Being able to slip fit through any hex bearing is just so awesome. Saves us hours of facing down our hex shaft stock to fit through bearings. They can't take any load thrown at it (obviously) but they have merit. Subjectively the way these shafts failed didn't quite "seem" like 7075 of a proper temper - the alloy may have been slightly off or untempered? If that was the case though it was close enough not to notice until you were pushing the limits of any 7075 shaft.
A specific problem with these shafts is mentioned in the next section.
Vex Gears
These are great. I love the standard width and the noticeably improved efficiency over competitor's gears. Aluminum gears are also extremely light. In our drive they took whatever we threw at them, and didn't wear much with white lithium grease applied.
These gears do have a problem with our specific use case for them. In order to fit in "any" hex shaft, the hex bore is a bit loose / oversized in these gears. First, I just want to say that it makes no sense for the hex bore in a ball bearing to be tighter and more precise than the hex bore for a gear. Why not use the same oversize broach in the bearings? Second, this loose broach creates a bit of inherent slop / backlash that can stack up very quickly. We made a six stage arm gearbox with .003" added to the centers and using the Vex hex extensively. The slop in the gearbox was compounded so badly that the arm had literally 7 degrees of slop. This was very difficult to fix after the fact and ultimately we replaced the geared arm with a winch-down system because of this slop. This isn't an issue in common 2 or 3 stage gearboxes, but it does prevent us from doing an entirely geared arm which had its advantages. Oh well.
Ballshifter Shaft
We used the shifting hardware from a Ball Shifter this year on our winch and overall the system worked well. It did not need a substantial amount of pressure to release our 80 pound CF spring shooter. There was wear on the gears and shifting plunger over time but it took several hundred shots for it to become a problem and replacing shifting hardware was cheap and easy.
The mechanism to couple the ball shifter to its shifting piston is inherently flawed. A tiny bearing and some rotor clips are clamped on by a plastic device which also captures the piston rod and nut. The bearing did not take radial loads well and ended up seizing. The rotor clips sheared several times with only 30ish pounds applied to the mechanism. We did end up using a 1.5" bore piston with the device regulated to 30 PSI, so forces were a little bigger than a normal shifting piston, but if the setup is that borderline, I would not trust it in a drivetrain either. We ended up making a cool custom coupler designed by our head mentor that used a bigger bearing. We had to thread the end of our Ball Shifter plunger shafts and install a flanged cylinder onto the shafts to retain the ball bearing one way. We used external and internal snap rings to retain it in the other direction. Once we upgraded this piece, the shifter worked pretty much just fine.
I wish the balls wouldn't cut into the gear or shifting plunger so much. Maybe a less hard set of shifting balls could be used, or a steel plunger.
Also, the hex shaft on the end just slid out one day on the practice field. Pretty annoying. We applied some Red loctite and fixed it but there should really be a cotter pin or something.
We found that over tightening a bolt going through both sides of the tube would very quickly cause the tube to sink in or pull out, without much resistance to warn you of what's happening.
Colson Hubs
These are still awesome and they look even better in black. Some teams (20) noticed that the OD was a bit small for a good press fit and that they could slip the press fit before the wheels slipped on the ground in extreme cases. Knurling the outside fixed this. We didn't encounter this problem, but a bigger OD would help prevent teams from running into this problem. Otherwise absolutely no complaints.
Hex Shaft Collars / Spacers
LOVE these shaft collars. Very light, thin, and a good range from tight to loose. These are so useful. The spacers also proved really useful too. Just having hex broached plastic spacers in your toolbox is so much cleaner than making something out of PVC or whatever. Will buy both again.
All in all, happy with the Vex product line this year.
I do have to say, lots of teams are very critical of Vex's belts because of snapping in the drivetrain. I've very much noticed a common denominator between these scenarios- Teams used 24T, 9mm belts without exact centers in their drives. This is simply not a good design for FRC. 9mm belts with pulleys that small are drastically undersized for the application. Using tensioners makes unequal tensioning, overtensioning, or undertensioning very possible which can make these problems worse. You would have failed Gates belts or SDP-SI belts too. I don't know if Vex belts had manufacturing problems or not, but using 9mm belts and small pulleys in the drive is asking for problems. Trust me, go 15mm.
Unread 28-04-2014, 17:13
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
Originally Posted by Chris is me View Post
Ballshifter Shaft
Neutrino remade the shaft in mild steel as well as in stainless (I think 300 series). Both still had significant wear from the balls.
We are thinking of making a hardened tool steel shaft for off seasons, but that may just transfer the wear to the gears instead of the shaft.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 28-04-2014, 17:15
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
The solution for us was to make the shaft out of 4340 steel and harden it to 50c. Never had to change it after that.
R.C.
MadTown Robotics Team 1323
Unread 28-04-2014, 18:03
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Versadog:
The metal bosses of the versakey pattern were REALLY tight in the vexpro gears. Almost unusably so, especially since we only used the versadog as a lathe jig, to allow us to bore out gears without using a 4 jaw chuck, and needed to remove the gear afterwords.
Solenoids/Solenoid manifolds
Extremely useful. Glad that these are available from a mainstream FRC supplier.
Dog Shifters
High quality stuff, but there needs to be a better way to purchase individual components of the dog shift system. There was no way for us to buy the shifting pins used without shelling out $75 for a PTO addon kit at minimum.
Versaplanetary dual stage input
It was not made clear on the website that this part did not provide support to the AM 9015 motors, as the normal versaplanetary does. Additionally, the two screws that hold the dual stage input together did not seem adequate, as the case warped and split open to some degree. Additional screws in the corners would have given it much more rigidity.
Belt pulleys
High quality stuff. 2x wide pulleys for 15mm belts would be appreciated, but what was made avaliable this year was very good.
