Go to Post Have you hugged a Martian today? (Dave, don't answer that.) - Billfred [more]
Unread 28-04-2014, 14:57
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Whacky Einstein Layout Proposal
Our team had probably the worst seats possible for Einstein this year. We couldn't see any action other than the blue ball flying through the high goal and maybe the tops of the taller robots. We couldn't see much of the big screen behind the field either.
I was looking at the way the field was set up and noticed something. All of the best sight-lines are at the side of the field (duh), yet we only had spectators on one side of the field (other than about 50 people sitting in the small bleachers on the far side of the field). Then I thought about having an extra 200 teams next year and how there would be a LOT of people not actually able to watch Einstein.
That got me thinking: how could you get people close to the field on BOTH sides and increase the number of people that got a good view. Then I had a thought: Move the field to a corner of the dome floor and put it right up against the stands with the long-side of the field sticking out toward the center of the dome floor.
I attached some pictures, with the limits of the good sight lines drawn on in red. The attachment on the left is the current setup, and the attachment on the right is the proposed setup.
If the field is pushed up against where the tunnel is, half of the seats in that area don't exist anyway since the tunnel is there. Therefore, you don't lose much seating there, but you gain a lot of good seats since you still have the good seats in the end zone, but you also gain most of the sideline seats.
I'm thinking that the presentation stage could be put behind the alliance wall that points toward the center of the dome.
Anyway, it's a thought.
ID:	16937  Click image for larger version
Unread 28-04-2014, 15:44
TheKeeg's Avatar
TheKeeg TheKeeg is offline
Michigan Tech Engineering
AKA: Keegan Harrington
FRC #0068 (Truck Town Thunder)
TheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud of
Re: Whacky Einstein Layout Proposal
This is an interesting idea. I do think that inviting more teams next year requires us to rethink the Einstein layout, but I don't know if this is the best way to do it. Knowing that FRC will be the only event their and that there will probably at least 6 fields (possibly 8) not including Einstein, I think your layout is a little bit constricting on the other field's space. Personally, I think the best way to solve the problem is to have a rapid teardown crew that will take the fields down that are along the length of the arena and set up Einstein in the center of the whole arena. This way people can see the field on both sides of the arena and there is not an awkwardly faced field that doesn't fit in. The problem with putting it in the center is that there is no ideal place to put the presentation wall.
Keegan Harrington
Truck Town Thunder
2013-2014: Mechanical Design
"Infinity: you empty out all of the coffee and there is still more orange juice"
Unread 28-04-2014, 16:17
JohnFogarty's Avatar
AKA: @doctorfogarty
Unfortunately I might have a little insight into Einstein's placement that you might not know about. Both the Boeing VIP Hospitality lounge and the Media Lounge are facing direct center of where Einstein currently sits. I was under the impression that is the main reason for it's current location, though I am puzzled by it considering there are box lounges all around the arena on Level 3. However, it did make sense that they put it where it is because of it's proximity to the main entrance that we use.
You have to think that FIRST give's some priority to where it places the Einstein field so that the sponsors and potential new ones get good/perfect viewing of the event. Is this a un-fixable problem? Nope. They'd just have to make the walk a little longer for the VIP's to re-orient the fields.
John Fogarty
Unread 28-04-2014, 16:45
Patrick Flynn Patrick Flynn is offline
Patrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond repute
http://www.chiefdelphi.com/forums/sh...4&postcount=73
This is something that has been addressed almost every year we have been in St. Louis, see above post from last year.
There are boxes all over the 3rd level but the only 'club' area is in the end-zone. All the other boxes are smaller and most likely owned be private companies not the Edward Jones Dome, so yes I would consider this an unfix-able problem.
Although the location suggested by Chris could still work if the stage was placed on the VIP club side of the field.
Decisions on where to place one field cannot be made in a vacuum. Where would you place 4-8 other fields? You cannot expect these fields to be taken down in time as there is only an hour between the end of divisions and start of Einstein. Sure some fields get done earlier, but you will never know which one it will be.
I do like the idea of expanding the 'good' viewing areas
Unread 28-04-2014, 17:21
Chris Endres Chris Endres is offline
play hard, work harder
AKA: Topher097
FRC #4096 (Ctrl-Z)
Chris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really nice
I do think that the seating for the Einstein field needs to change. But we also need to remember that the whole stadium is just for FRC next year, therefore, there will not be FTC nor FLL on the Einstein field for their own competitions. This will mean that FIRST will have to have the Einstein field untouched, taking away seating options that can be used for another division, seats that were once used for FLL spectators. If FIRST decides to change the position of the fields, they need to make sure it doesn't waste seating during the rest of the competition.
2009 FLL Illinois State Champions - iLEGO
2010 FLL Illinois State Champions - iLEGO
2011 FLL Illinois State 3rd Place - iLEGO
2011 FLL Illinois State 1st Ambassador - iLEGO
2013 FRC Milwaukee Regional Champions - WildStang
2016 FRC Midwest Regional Finalists - WildStang
Unread 28-04-2014, 17:28
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
There are box lounges all around the arena on Level 3.
There are suites all over the 300 level, but the Clarkson Jewelers Club is in the south end zone. It's basically a giant suite for all of the VIPs.
Unread 28-04-2014, 17:31
Cynette Cynette is offline
Worry is a poor use of Imagination
AKA: Cynette Cavaliere
FRC #1511 (Rolling Thunder)
Cynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond repute
Send a message via ICQ to Cynette Send a message via AIM to Cynette
And I though we had the worst seats on Einstein! Small things would have made a difference to us. The first was to remove the half circle of decorative flags over the speakers area. Not only were we too far away to really see the field, but we couldn't see the video screen. The second would have been to broadcast everything on the second opposite screen. When it was on, it was very helpful in letting us know what was going on.
Cynette
The best angle from which to approach any problem is the TRYangle
--Chinese Fortune Cookie
Rolling Thunder, Team 1511: The Thunder just keeps getting louder!
Unread 28-04-2014, 17:43
AKA: @doctorfogarty
I am aware of this. I was in it several times this year as I was an invited guest through my University.
I just was not sure if the other boxes were the same size as the one that they currently have the VIP suite in.
John Fogarty
Unread 28-04-2014, 18:17
Libby K's Avatar
Libby K Libby K is offline
Always a MidKnight Inventor.
FRC #1923 (The MidKnight Inventors)
Rookie Year: 1992
Libby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond repute
They are not. The ones you're referring to are private, lockable rooms designed for parties of about 10-15 people. FIRST uses them as quiet areas for meetings, media interviews, etc. As an example, my family met with the three Bart Kamen Memorial Scholarship winners in one of those boxes last year since it was a good place to be quiet and on our own.
The only place it makes sense to put VIP is the Clarkson Jewelers Club, as there's plenty of seating both inside the lounge and with views of the field - and it is easily accessible by arena ramp, escalator, and elevators.
Libby Kamen
Team 1923: The MidKnight Inventors
2006-2009: Founder, Captain, Operator, Regional Champion.
2010-Always: Proud Alumni, Mentor & Drive Coach. 2015 Woodie Flowers Finalist Award.
229: Division By Zero / 4124: Integration by Parts
2010-2013: Clarkson University Mentor for FLL, FTC & FRC
FIRST Partner Associate, United Therapeutics
#TeamUnither | facebook, twitter & instagram | @unitherFIRST
questions? comments? concerns? | twitter: @libbyk | about.me/libbykamen
Unread 28-04-2014, 19:08
NickTosta NickTosta is offline
Team 195 Alumni & Former Driver
no team (The Cyber Knights)
NickTosta is an unknown quantity at this point
One potential problem with your proposed layout is that everyone would have to either sit sideways in their seat or turn their neck the entire time.
Current college student (electrical/computer engineering), former base driver for Team 195
2011 (36-10): WPI Champions, CT Champions, Galileo 13th seed & quarterfinalists
2012 (26-15-2): NYC Finalists, CT Champions, Archimedes 7th seed & quarterfinalists
Unread 28-04-2014, 19:38
wet_colored_arc wet_colored_arc is offline
FRC #1126 (SparX)
wet_colored_arc is an unknown quantity at this point
In the two years I have gone, I have been frustrated by an inability to actually see anything useful from where I was sitting. I like the energy of being packed in, but I certainly didn't get much of anything out of the view I had. It has been one of the more disappointing aspects of the competition for me.
I'd like to see the main screen video shown also on Archimedes or Curie, or ideally have two additional screens that are angled to the corners of the end zone. That way, sitting on the side has some modest utility and helps maintain the energy and the sense of community. I have pretty much given up on being able to see anything useful on the field or stage itself anyway.
Unread 28-04-2014, 20:11
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
4th level views during Einstein absolutely sucked...couldn't see the scores as the view of the bottom half of the main screen was blocked by the light truss over the field The point is, wherever (if ever moved) it would be nice to consider the impact placement has on the poor folks up in the nose bleeds...
"A genius is just a talented person who does his homework" T. Edison
Unread 28-04-2014, 23:14
Jaxom Jaxom is offline
AKA: Michael Hartwig
FRC #1986 (Team Titanium)
Jaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant future
Why does Einstein have to be untouched? Is this a tradition that can be dispensed with?
Mentor http://www.teamtitanium.org/
Unread 28-04-2014, 23:26
AKA: @doctorfogarty
I mean, wasn't the finals field rotated through by each division back when world was at Epcot?
John Fogarty
Unread 29-04-2014, 00:20
Zylviij's Avatar
Zylviij Zylviij is offline
The quieter you become...
AKA: Blake
FRC #1732 (Hilltoppers)
Zylviij is an unknown quantity at this point
The matches were suspenseful, even from the 400+ section. I could see the robots and nicely watch the matches. The view to the giant screen was obstructed by lighting equipment. The closing ceremonies were hard to see because of the lighting equipment and the flag decoration. I propose moving the lighting up as a FIRST step toward making a more enjoyable experience. All of the paper airplanes were no obstruction when compared to the "sky truss" blocking our views.
