Go to Post FIRST does have instant replay. Its called the off season. - Wayne C. [more]
Unread 29-04-2014, 11:11
Electric Sheep Electric Sheep is offline
FRC #2546
Electric Sheep is an unknown quantity at this point
Activating iMates in Autodesk 2014
Hi, We are new to Autodesk. We have practiced with an older version used for the Autodesk Vex curriculum at the Vex website site here http://curriculum.vexrobotics.com/. The parts from the library (which are downloaded from the website) when placed as a part have the iMates visible by default. Makes Inventor easier to use (my opinion). I have a some Vex Libraries downloaded from the Vexcad site to ise with AD 2014 but they do not display the iMates. How do I get this to work.
-thanks
the Electric Sheep
Unread 30-04-2014, 16:38
TheKeeg's Avatar
TheKeeg TheKeeg is offline
Michigan Tech Engineering
AKA: Keegan Harrington
FRC #0068 (Truck Town Thunder)
TheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud of
Re: Activating iMates in Autodesk 2014
Here is something that you may find helpful
http://www.g-wlearning.com/cad/97816...F/SupMat02.pdf
Do you have access to the create iMates tool using the iMate dialog box?
Keegan Harrington
Truck Town Thunder
2013-2014: Mechanical Design
"Infinity: you empty out all of the coffee and there is still more orange juice"
Unread 03-05-2014, 09:30
FRC #2546
Smile Re: Activating iMates in Autodesk 2014
Thank you for the link . Ad yes I have the create iMate I in the Author group.
Thanks again. Will let you know how I make out.
Unread 03-05-2014, 09:44
FRC #2546
Hello theKeeg,
Do the parts libraries have to be in some special format? As I mentioned earlier I posted that I downloaded the vex cad libraries from tone Vex wiki. They are in a step file format. Can't get them to work.
