Thread Tools |
Rating:
Display Modes |
#13
Re: RoboRio
I can not confirm 100% at the moment that WPI plans to ditch netbeans altogether for Java. In 2012, they provided both Eclipse and Netbean plug-ins. But did not provide Eclipse plug-ins for 2013 or 2014. What I can confirm is that for C++: WPI is moving from Windriver to Eclipse (which is free). However, even if WPI only provides the official plugin for Eclipse, it is not impossible to set up Netbeans to develop for the RoboRio Arm processor and deploy on your own. For Java this is easy, because all you need to do is add the WPI Library to your linker in netbeans. Since Java compiles to byte-code it is platform independant and no cross-compilation is necessary. For C++: It is not impossible to set-up netbeans to cross-compile for the Arm Processor. The cross-compiler (g++) used on eclipse can be used in netbeans to provide an Arm Executable. After the binary is built for either language, all you need to do then is transfer the binary to the device, and SSH into the RoboRio to run the program. This is essentially what the "Deploy" Ant script provides, and their is no reason why you just can't reuse the Ant Script to do this for you. Currently for Java, netbeans is the supported IDE, however, I have my entire team setup using eclipse, we don't use netbeans for anything. We have been using Java and Eclipse for the last 3 seasons for FRC. I prefer to set up the build on our own, even if WPI provided us with an eclipse plug-in because I can run my own customizable build script. For example, after my build script creates the Jar File and transfers it to the cRIO, it then runs through my Java Code and generates a HTML version of the Javadoc for the code we wrote for the Robot - which is very handy. This is all functionality anyone can have. I personally like eclipse, but for those that want to still use Netbeans, there will always be a way to make it work with some limitation, even if it is not fully supported by WPI. In the past, I have provided turotials for teams to setup eclipse for Java development on FRC. Before the Fall, I will make sure to provide a video tutorial of how to setup netbeans for the RoboRio development. At the end of the day, you are free to use any IDE you like, as long as you can link to the WPI provided libraries and are comfortable SSH'ing into the linux device on your own. Regards, Kevin Last edited by NotInControl : 29-04-2014 at 12:20. |
