My love spiders out in a web of emotions when I think of you.
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 29-04-2014, 01:15
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (Harker Robotics)
Butterfly/ octocanum drives
So a butterfly/ octocanum drive is where you switch between mecanum and traction wheels, right?
I was wondering what the typical weight and complexity of these systems was. This would be weight per module or, preferably, weight of bellypan + drive base + modules. I have only found one weight listing for an octocanum module, and I think many teams keep the mass under 11lbs.
How long does this take to design? Does this need a particular CNC special part or can it be fabricated with a waterjet/ sheet metal shop?
Any information on these drives would be useful, as I'm looking into different drives for a summer project.
Unread 29-04-2014, 01:29
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
Re: Butterfly drives
Originally Posted by asid61 View Post
So a butterfly drive is where you switch between mecanum and traction wheels, correct?
How long does this take to design? Does this need a particular special part or can it be fabricated with a waterjet/ sheet metal guy?
Assigning names to a "design" is so limiting. That said a butterfly drive conventionally switches between 4 omni wheels and 4 traction wheels.
I would encourage you to sit down with your team and figure out a list of objectives you would like your summer project to fulfill. Once you've done this I would encourage you to use the chiefdelphi search function to read up on butterfly drives from older threads. Once you understand your design objectives, have an idea of where a butterfly type drive falls on that, and seen a number of designs other teams have already made you can properly assess if you should try to design and build one or if your time would be better spent working on something else. When done properly off season projects can be an extremely valuable resource both in terms of populating your team's design shelf and teaching students. The most important thing is to have a full understanding of why you are building what you are building and how you are trying to improve upon what you have done in the past, have seen others do in competition, or online.
Cheers, Bryan
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 29-04-2014, 01:40
asid61's Avatar
AKA: Anand Rajamani
Cheers, Bryan
Actually, right now it's just me looking at drive train ideas; other people have AP tests to study for right now and just a lot of schoolwork in general. I want to have a list of detailed CAD designs to show the team later once we start thinking about summer projects, so that we can make an educated decision about what we want to try.
I've been cadding only swerve drives and shifting gearboxes up to this point, but I was wondering what I should aim for in terms of weight and size if I CAD a butterfly later.
I want to stick with swerve personally, but the problem is that the programming is very difficult. With a butterfly drive, there is already a lot of programming released, not to mention the programming overall is easier.
Unread 29-04-2014, 07:43
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
Re: Butterfly/ octocanum drives
As BJC said, butterfly is [typically] switching between omni and traction wheels; while octocanum is [typically] switching between mecanum and traction wheels.
The main difference between the two are choosing what wheel is opposite of the traction wheel on the pod. While I have not built one, the drives should be slightly heavier than a conventional drive. Majority of these setups use a single gear reduction to the first wheel and then another reduction via chain or belt to the second wheel. This makes up for the weight "missing" from gearboxes.
There are some good examples out there on how they have been constructed in the past. 148 made this type of setup popular in their 2010 release video and their CAD files can be seen on FRC designs and you can see another iteration in their 2011 robot. Another great example is 3847's robot from this year. It was documented fairly well in their build blog. Both of these teams are more than willing to help answer further questions, but these should give you a good starting point. There are plenty of other robots that use these drive types that I didn't mention, these were two I could get my hands on quickly.
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
Unread 29-04-2014, 11:58
RobotDoktor's Avatar
RobotDoktor RobotDoktor is offline
Cat Herder
FRC #4265 (Secret City)
Team Role: CAD
RobotDoktor is just really niceRobotDoktor is just really niceRobotDoktor is just really niceRobotDoktor is just really niceRobotDoktor is just really nice
If you design an octocanum or butterfly, be ready to spend at least two or three months to go from concept to working prototype. If you use bent sheet metal for your modules you need a water jet, if you use 1/4" aluminum plates, you need a good CNC. Do know that they can be much heavier than other drivetrains depending on their features, so they aren't suitable for some games.
Full disclosure: I am not a robot, a doctor, or a German.
Unread 29-04-2014, 12:07
Abhishek R Abhishek R is offline
FRC #0624
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
Though I doubt it would work with mecanum, we used a new format of the "Tex-Coast Drive," (Grasshopper) essentially combining butterfly with a West Coast drive. We don't CAD nor do we have a CNC machine, so simplicity and ease of construction was something we needed. We built the first prototype and the competition drivetrain both in the same six week build season. It weighs just a bit more than a standard 8WD because of the pneumatic actuation. Here's a link to what I mean: Grasshopper Drive System
2012 - 2015 : 624 CRyptonite
Team Website
Unread 29-04-2014, 12:16
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
We went from concept to working prototype in about 3 weeks during build season this year. We didn't do any prototyping or design on that type of drive train before build season started. Do your research and don't be afraid to ask for help. Our drive train wasn't perfect but it did very well and we had to perform very little maintenance on it all season.
Also as noted about it's called Tex Coast Drive now.
There are trade offs in every train and depending on the features you put in it can be lighter or heavier.
Unread 29-04-2014, 13:22
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
I had a great opportunity to talk to a couple of people on your team about your drive train, including manufacturing and maintenance. The insight was invaluable. If we decide to do it next year and improve upon it, we'll definitely send you a heads up with any of our new findings. From what I saw it was the best blend of simplicity, maneuverability and immovability. Who knew it was based upon a concept that was put out 3 years ago by the Killer Bees?
The only thing about the whitepaper I don't quite understand is the 'elastic tensioning'. Could you explain?
2017 Scoring Model
CAD Library | GitHub
Unread 29-04-2014, 13:53
matthew_martin's Avatar
matthew_martin matthew_martin is offline
FRC #4265 (Secret City Wildbots)
Team Role: Communications
matthew_martin is an unknown quantity at this point
As RobotDoktor said, these drives can easily be very complex and heavy. We used it on our competition bot this year, naming the drive base the Dragonfly (And we won Excellence in Engineering at CMP for it). It switches between colsons and mecanum wheels, with each module weighing about 9 lbs. The entire thing with the electrical board, for us, was about 100 lbs packed into 6-8 inches of height. We came so close to the weight budget that we had to cut wires as short as possible just to cut down on weight!
FRC 4265
2012 - Smoky Mountains Regional - Rookie All-Star
2012 - FIRST Championship (Curie)
2013 - Smoky Mountains Regional - Winner
2013 - FIRST Championship (Archimedes)
2014 - Smoky Mountains Regional - Winner
2014 - FIRST Championship (Archimedes) - Excellence in Engineering
2015 - Smoky Mountains Regional - Engineering Inspiration
2015 - FIRST Championship Hopper Division Winner
2015 - FIRST Championship Finalist
Unread 29-04-2014, 13:55
hrench's Avatar
hrench hrench is offline
Mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
hrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to all
A couple years ago our team built a 'slide' drive that used two omni's that were in the middle to translate us and four omnis at the corners to drive. It was terrible, but that's where I first learned of these concept drives.
At the time it occurred to me that you could use something equivalent to a starter bendix drive to push-down the translating wheels only when you need to strafe. In a starter bendix, it moves forward to engage your flywheel using the rotation of the motor--Simple, no space-hogging pneumatics on the frame. I have'nt tried it but I'd be interested Yes, a bendix only moves foreward on one rotation, but I think you could use the concept to design a bendix-in-a-bendix and make one that moves down on both rotations.
And then it occurred to me that this might be better with four-wheels for strafing and four wheels for regular driving . Then I thought why do we even need omni or mechanam wheels for this?
So why does an 'octonum' or any of these others even need translating wheels? If your goal is to strafe, can't you just do that with 'good' wheels?
Unread 29-04-2014, 14:00
Knufire Knufire is online now
This sounds quite similar to how the Robowranglers deployed their middle strafe wheel this year.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 29-04-2014, 14:53
FRC #0624
Originally Posted by gotgreen
Apologies that it was not clear. The shifting bearing block is loose on the frame and has to be tensioned. Theraband is connected to the top of the shift plate where the pneumatic cylinder is attached and tensioned to the frame vertically. This seats the bearing block lower lip into the frame when the wheels are up. Also, when pivoting the blocks the chain is loose when up and tight when lowered. Ideally the pivot point should be moved out to reduce this issue. A small piece of theraband can be connected to the bottom of the block and tensioned to the frame. We are not using this. We just attached a small tensioner and it is working fine. The drivetrain complete w/o electronics is right around 30 pounds.
Here you go. And thanks, it was an experiment for us and it turned out pretty well.
Team Website
Unread 29-04-2014, 15:02
zinthorne's Avatar
zinthorne zinthorne is offline
AKA: Avery
FRC #5827 (Code Purple)
zinthorne will become famous soon enough
This year we developed and used a hybrid of an octane. we went with six wheels instead of 8. We used 4 2-stage vex transmissions geared 3:1 and 8:1. We also used a 12 tooth sprocket from the transmissions to mecanem wheels, and then a 22 tooth sprocket on the mecanem. We then moved to a 44 tooth sprocket on the 6 inch wheels. We built two pods for the mecanem and traction wheels duos, and then ran a bar connected to each beneath the central frame of the robot. A 3 inch piston pushed the bar down in the middle of the robot, engaging the traction wheels and lifting the other mecanems in the pod off the ground.
See link for a picture.
http://www.chiefdelphi.com/media/photos/40492
We welded the pods using 1/4 inch bar aluminum. Our frame is made of c-channel. It was not the lightest of drivetrains, but we still fit everything else on the robot with not too much worry about weight.
We could push 90% of the robots on the field, and we could hold our ground against the other 10%.
Unread 29-04-2014, 15:16
ErvinI ErvinI is offline
AKA: Ervin Ibadula
FRC #0865 (Warp7)
ErvinI is just really niceErvinI is just really niceErvinI is just really niceErvinI is just really niceErvinI is just really nice
I don't remember the terminology too well, but wasn't the 2010 robot a Nonadrive, since it had a ninth wheel that was actuated down to allow for holonomic drive? Their 2011 robot was iirc their first true butterfly after they realized that the ninth wheel wasn't required for basic strafing.
Currently a student at the University of Toronto - Mechanical Engineering
FRC 781 alumni
Unread 29-04-2014, 16:28
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
I talked about the history of 148's articulating drives, and the evolution of the "Tex-Coast Drive" here:
http://www.chiefdelphi.com/forums/sh...9&postcount=15
