Go to Post It's really quite amazing what people will find time to talk about in the month before kickoff. - Ekcrbe [more]
Unread 29-04-2014, 23:59
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (MVRT)
Re: I might be missing something with a 6 cim drive...
So have people stalled a 6 cim drive before then?
Unread 30-04-2014, 00:08
Oblarg Oblarg is offline
AKA: Eli Barnett
Yes.
With a 125lb robot (including battery and bumpers) geared 6.1:1 with 4'' HiGrip wheels, we stalled 6CIMs when simultaneously running the compressor on a not-quite-full battery, resulting in a current draw of ~250 amps.
With the compressor off and the battery completely full, the same robot spun the wheels and pulled ~180 amps.
"The breakfast of champions!"
Unread 30-04-2014, 00:15
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Originally Posted by Oblarg View Post
Yes.
But CIMs stall at 133 amps apiece
...? (theoretically as always) their manufacturing specs say so. that would be 800 amps, aka very bad...
Unread 30-04-2014, 00:27
AKA: Eli Barnett
They stall at significantly less than that when you're running them off of a real battery whose effective voltage drops significantly when you start drawing lots of current from it.
It's the same reason that you can stall them at all in the first place; if you naively just calculate from the stated stall torque of the motor you'll find that your robot would have to weigh an ungodly amount to stall them at any gearing you'd see on an FRC bot.
Unread 30-04-2014, 00:43
I am Dave! Yognaut
AKA: Brian Bray
True true. I thought about that but did not account for it.
As the resistance outside the battery decreases and approaches near zero (v=ir so 12=133r so r= ~.1ohms) (the motor stalls), the internal resistance inside the battery becomes a significant percentage of the overall resistance, so the potential difference beyond the two terminals is proportionally less than it were when the internal resistance was a small fraction of the overall resistance. Another point for Ampere's law.
Unread 30-04-2014, 00:54
AKA: Eli Barnett
I, too, failed to account for it in our design this year, with the result being that we had to swap out our gearkits (which was an excruciating process due to the design of our drive) before worlds.
That's the way you learn best, though.
Unread 30-04-2014, 02:53
asid61's Avatar
AKA: Anand Rajamani
FRC #1072 (MVRT)
Ooooookay, we'd better be careful then!
Unread 30-04-2014, 03:26
Answer42's Avatar
Answer42 Answer42 is offline
Answer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud of
http://www.chiefdelphi.com/forums/sh...ad.php?t=89768
I don't know. You can see some pretty interesting design choices in FRC.
My comments do not reflect the views of associated teams.
Unread 30-04-2014, 08:46
How does what you described relate to Ampere's law?
Unread 30-04-2014, 10:56
Stephen.Yanczura's Avatar
Stephen.Yanczura Stephen.Yanczura is offline
opportunist
FRC #0195 (Cyberknights)
Stephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to all
On our practice bot we drove the robot up to a cement wall and had a mentor apply his weight to the top of the bot upping the traction big time. I had the driver lay on the stick full power into the wall effectively stalling all six CIMs at 100%. Fresh battery, new CIM motors, talon motor controllers.
The main tripped in ~8 seconds and for each successive test it tripped sooner and sooner, I stopped after it was tripping in ~5 seconds.
We are geared 5.95:1 in the box and 1:1 (belts) to the 4" HiGrip wheels. (I did some speed tests using encoder logs and we were seeing 12-13ft/sec max robot speed on slightly worn wheels).
We never tripped a main breaker during a match on the competition bot and to my knowledge never tripped a breaker during an estimated 200 hours of driving the practice bot (same breaker I tortured above).
YMMV
stephenyanczura
team 0195 | 2010-Pres. | cyberknights | Conn. | mentor
team 0195 | 2006-2007 | cyberknights | Conn. | mentor
team 1660 | 2005-2006 | harlemknights | NYC | mentor
team 0195 | 2001-2005 | cyberknights | Conn. | student
s.j.yanczura@gmail.com
Unread 30-04-2014, 11:07
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
After building and running robots with 6 motor drive for the past few years, I had never experienced an issue with blown main breakers. This year the team had no issues through 3 regional competitions and champs seeding matches until they found themselves in eliminations on Curie. At this level of competition we had the main breaker kick out near the end of four of our elimination matches. Luckly it did not impact the outcomes of the match as they were very close to the end but it just goes to show the stress on the equipment at that level of competition.
Now you've gotta understand our machine is running 6 CIMs (2 speed 18fps/6.5fps) on drive, 2 RS775s on the reloader, an RS550 on intake and the compressor, so it is a very hungry little thing- drivetrain excluded. We would never dream of running a battery that hadn't come right off the charger fully charged. Even a battery that was fully charged and settled overnight was noticeably sluggish in our machine. It was typical for the battery to be warm after our matches as well as all the 6AWG wiring. I wouldn't use this experience to say that 6 CIM draws too much power. There were other inefficiencies which could have been improved to mitigate the breaker trips. First off, you've got to get the power from the battery to the PD board. Solder all your 6AWG terminals (torch, flux, solder, heatshrink)! The mentor in charge of wiring our machine refused to follow my advice and insisted crimped connections were sufficient. During elims on Currie, each of the terminals was a hotspot capable of burning you at the end of the match- any heat generation is a loss of power so here is improvement #1. Secondly, all the 6AWG wiring was warm- In the future it would be prudent to use 4AWG including higher capacity Anderson connectors (not sure if this is legal as per rules though since there is wording specifying a part number for these to be used). Thirdly, the main breaker was cooking hot. We did try swapping it out for a brand new unit but this did not affect the performance. Instead we borrowed some computer duster from the Robonauts #118 (Thank you so much!) and were able to delay the trips by cooling the breaker between matches. I am not sure if the heat buildup was being generated within the breaker or if the poor connections with the terminals were sinking heat into it through the lugs.
Basically, you just have to be very conscious that a 6CIM robot is going to be hungry. You need to design your gearboxes at the mercy of the main breaker and battery. If you are using 6 CIM single speed, make sure the machine breaks traction before stalling the motors. If you are using 2 speed, then make sure you actually use it! Next time around I would insist on some sort of current sensing device combined with the feedback from an encoder on the driveline which would automatically kick the gearboxes to low gear if there existed a current increase past a certain limit for a certain motor speed for a set amount of time. I can't count how many times I had to yell at our driver "LOW GEAR!" when he found himself in a shoving match. Outside of this, make sure your electrical system is robust as the additional strain is hard on these components. Oversize the wiring if you can afford the weight so that you eliminate your losses due to heat.
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
Unread 30-04-2014, 21:54
asid61's Avatar
AKA: Anand Rajamani
FRC #1072 (MVRT)
Wow, thank you for the informative post!
I talked to one of our electrical team, and he says that it would be simple to add current sensing for shifting in addition to a manual shift.
I'm not sure if he'll go for soldering connections (our electrical team doesn't like solder) but if it's just the big wires it might be okay.
Unread 16-05-2014, 16:29
thrashercharged thrashercharged is offline
FRC #3940 (Cybertooth)
thrashercharged is an unknown quantity at this point
... At this level of competition we had the main breaker kick out near the end of four of our elimination matches.
... It was typical for the battery to be warm after our matches as well as all the 6AWG wiring... There were other inefficiencies which could have been improved to mitigate the breaker trips. First off, you've got to get the power from the battery to the PD board. Solder all your 6AWG terminals (torch, flux, solder, heatshrink)! The mentor in charge of wiring our machine refused to follow my advice and insisted crimped connections were sufficient. During elims on Currie, each of the terminals was a hotspot capable of burning you at the end of the match- any heat generation is a loss of power so here is improvement #1. Secondly, all the 6AWG wiring was warm- In the future it would be prudent to use 4AWG including higher capacity Anderson connectors ...Thirdly, the main breaker was cooking hot.
... Oversize the wiring if you can afford the weight so that you eliminate your losses due to heat.
Keep in mind if you oversize the wiring, solder the connections, shorten wires, etc. you're increasing current draw, not decreasing it, which will just make your main breaker get hotter. I'd think your 6AWG wiring and anything that was getting hot was saving your main breaker from tripping sooner! If you follow through with your plans to oversize the wiring to 4AWG, solder connections, etc. you may find you're tripping that main breaker more often.
Unread 16-05-2014, 16:46
That might not actually end up being the case. Several main breaker trips I saw this past season were quite definitely attributable to hot wires warming up the breaker rather than the breaker itself reacting to true overcurrent.
Unread 16-05-2014, 17:12
That's interesting Alan - thanks for pointing that out. I hadn't considered that. Towards the end of the season our robot was blowing the main too, but I can't say how hot the wires were. It's only a 4 cim drive and Andy mentioned he's never had a problem blowing the main before, but I think this year we had a shorter path from battery to breaker to PDB than we ever had (inches, with one cable just 2 connectors butted together with no wire showing) so we could potentially supply more current through the main breaker than ever before.
Hmm, I wonder if this would warrant throwing some thermocouples on and seeing just what the temp profiles are on the breaker and on the cables leading to it while we stall it against a wall.
What did you see that would make the wires heat the breaker? How did they solve this?
