Go to Post Begging, yelling, kicking, and screaming for members of my team to send me updates while I'm at college not doing homework. - Ginger Power [more]
Unread 30-04-2014, 22:31
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Custom Gearboxes
Originally Posted by cadandcookies View Post
I'm not really sure what you mean by "we couldn't get what we wanted" out of the JVN calculator. Were you using the single speed or two speed tabs? Were you using all the tooth counts of gears that are available from FIRST vendors?
My typical process for drive train gearboxes is to determine what my design parameters are for the gearbox (shifting or no? max speed/min speed? certain time to distance requirements?), then playing around with JVN until I get a set of gear ratios that work.
I guess the main thing about the JVN calulator is that, like all calculators, it's only as good as what you put into it. It's not magic-- one of the often ignored parts of design is determining what exactly you want out of what you're designing. In my experience there hasn't been a single gearbox I've designed that the design wasn't at least in part simplified by the JVN calculator.
Actually, I've alwasy been confused about something in the JVN calc: it lists the draw at maximum output load, but is that the normal drive load or pushing match load?
Unread 30-04-2014, 22:38
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
WCP's drivetrain calculator gives a more in depth analysis than the JVN calculator. http://www.wcproducts.net/how-to-drivetrain/
2016: FRC 865 Mentor
Unread 30-04-2014, 22:44
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
This calculator only works with Vexpro and WCP gearboxes, unless you want to use the same gears and ratios for a custom box.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
RoboChair's Avatar
AKA: Devin Castellucci
With 4 inch traction wheels 1678 Citrus Circuits ran a high gear of 22 fps(theoretical free speed) and a low gear of 8 fps on our 6 CIM drivetrain using VEXPRO ball shifters.
Unread 30-04-2014, 22:49
Lead Bumper Mentor
AKA: Mike Marandola
Did you guys have any breaker issues?
Unread 30-04-2014, 23:11
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Custom gearboxes are nice, but WCP 3-cim gearboxes are hard to beat.
I would go custom only if I am confident that I can get an appreciable reduction in weight (at most a 2.25lb gearbox) or size (because WCP gearboxes are pretty large). Or if you have a gearbox design you want to try in the offseason, such as a bevel box or something similar then it would be good to try custom.
Unread 30-04-2014, 23:27
PingPongPerson's Avatar
PingPongPerson PingPongPerson is offline
Hardcore Robot Addict
AKA: Michael Groom
FRC #0955 (CV Robotics)
PingPongPerson will become famous soon enough
This year CV Robotics did our first custom gearboxes since 2008, because we wanted a more durable and flexible to our design option. When I calculate the speed for gearboxes I design, I usually just do a rough calculation (eg. stoichiometry to get from CIM RPM [5000ish] to feet per second). Using this I can compare it to previously used gearboxes to see about how fast we would be going. This year's gearbox was calculated at around 18ft/s:
https://www.youtube.com/watch?v=feS_KxnsZ8s
You can see our robot on the far side in red here:
https://www.youtube.com/watch?v=3UlV...DIBcQ&index=61
The robot may not be going 18ft/s, but next year if we want a faster robot, we can change the gearing so that our calculated value is a little larger, maybe 21ft/s.
Hope this helps,
Michael
Team 955
Raiderbot
Unread 30-04-2014, 23:53
rnewendyke's Avatar
rnewendyke rnewendyke is offline
Mr. Make It Happen
AKA: Ryan Newendyke
FRC #2451 (PWNAGE)
rnewendyke is on a distinguished road
We did custom gearboxes on our 2013 west coast drive and were very happy with the results of it. We went about finding our gear ratios by looking at what other teams had done for speeds in the past as well as analyze how our own drive trains had preformed in the past. It looks like a "fast speed" is around 18 feet per second theoretical (free speed * gear ratio * wheel dia in inches * π / ( 12 * 60 ) and low gears usually run ~ 2 - 2.5 times lower that a gearbox's high gear. The highest high gear that I have ever seen was 24 fps theoretical on 3061's machine this year and in talking to them they said that they felt that their high gear was too high because they couldn't accelerate to top speed on the field and they found it difficult to control.
Unread 01-05-2014, 07:33
Arpan Arpan is offline
Olin class of 2019
FRC #3061 (Huskie Robotics)
Arpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud of
Originally Posted by rnewendyke View Post
We did an entirely custom gearbox on our 2013 west coast drive and were very happy with the results of it. We went about finding our gear ratios by looking at what other teams had done for speeds in the past as well as analyze how our own drive trains had preformed in the past. It looks like a "fast speed" is around 18 feet per second theoretical (free speed * gear ratio * wheel dia in inches * π / ( 12 * 60 ) and low gears usually run ~ 2 - 2.5 times lower that a gearbox's high gear. The highest high gear that I have ever seen was 24 fps theoretical on 3061's machine this year and in talking to them they said that they felt that their high gear was too high because they couldn't accelerate to top speed on the field and they found it difficult to control.
Yeah, it was far too fast. Our driver couldn't react in time and drove like he was drunk when in high gear.
That said, it was fun to be able to get across the field in just over two seconds when there was nobody in the way.
I wouldn't recommend going higher than 18 theoretical.
Unread 01-05-2014, 00:24
VioletElizabeth's Avatar
VioletElizabeth VioletElizabeth is offline
AKA: ECD
FRC #1868 (Space Cookies)
VioletElizabeth is just really niceVioletElizabeth is just really niceVioletElizabeth is just really niceVioletElizabeth is just really niceVioletElizabeth is just really nice
In finals 2 at SVR they blew the main breaker: http://www.youtube.com/watch?v=fi68AQWPtCw
I believe they said this was pushing in high gear by accident or something along those lines. They can give better clarification than I, though.
Edit: Found it! Talks about blowing the breaker: http://www.chiefdelphi.com/forums/sh...d.php?t=128530
Unread 01-05-2014, 07:27
TheKeeg's Avatar
TheKeeg TheKeeg is offline
Michigan Tech Engineering
AKA: Keegan Harrington
FRC #0068 (Truck Town Thunder)
TheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud of
Truck Town Thunder has built their own transmissions for 16 years and 2014 was the first year we bought them. I guess you can say we were experts at designing and building the strongest transmissions out there but it turns out WCP does exactly the same thing. Buying was difficult for us to do because we had never liked what reductions and speed they gave us, but those WCP 2 speed trannys are pretty sweet. We had a low speed of 5 (strictly for pushing) and a high of 15 (which I think could have been higher but we wanted a lower low speed). Buying them saves a ton of time (like 3 weeks for us) and a lot of resources. If you are set in your ways, then good luck to you, but I strongly suggest a store-bought transmission.
Keegan Harrington
Truck Town Thunder
2013-2014: Mechanical Design
"Infinity: you empty out all of the coffee and there is still more orange juice"
Unread 30-04-2014, 23:21
Michael Hill's Avatar
Neither, it's an overly simplified model of total current draw. It doesn't take into account stuff like battery voltage drop.
JVN's spreadsheet is a very good first pass, but you really should look into it deeper. Check out Ether's drivetrain simulation program that takes that stuff into account.
