Go to Post "If I say its name three times, will it appear in my lab?" - Madison [more]
Unread 30-04-2014, 22:13
YCJeon772's Avatar
YCJeon772 YCJeon772 is offline
Mechanical Leader, CAD designer
AKA: Yuchan Jeon
FRC #0772 (SabreBytes)
YCJeon772 is an unknown quantity at this point
Custom Gearboxes
So our team has been thinking about designing custom gearboxes to achieve a fast high gear and strong low gear. How do teams create such fast/strong gearboxes? I tried playing around with the JVN calculator to see what I could get but couldn't get what we wanted.
2014 North Bay Regional Engineering Inspiration Award
2014 Windsor-Essex Great Lakes Regional Chairman's Winner
Unread 30-04-2014, 22:19
cadandcookies's Avatar
cadandcookies cadandcookies is online now
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Re: Custom Gearboxes
I'm not really sure what you mean by "we couldn't get what we wanted" out of the JVN calculator. Were you using the single speed or two speed tabs? Were you using all the tooth counts of gears that are available from FIRST vendors?
My typical process for drive train gearboxes is to determine what my design parameters are for the gearbox (shifting or no? max speed/min speed? certain time to distance requirements?), then playing around with JVN until I get a set of gear ratios that work.
I guess the main thing about the JVN calulator is that, like all calculators, it's only as good as what you put into it. It's not magic-- one of the often ignored parts of design is determining what exactly you want out of what you're designing. In my experience there hasn't been a single gearbox I've designed that the design wasn't at least in part simplified by the JVN calculator.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 30-04-2014, 22:27
YCJeon772's Avatar
AKA: Yuchan Jeon
When I said "we couldn't get what we wanted", I meant that we couldn't get a fast speed for high gear and a strong low gear. I was using the two speed tab, and yes, I was using the gears that Vex offered. We were hoping to get at least 13f/s for high gear, and a reduction of at least 10:1 gear ratio.
Unread 30-04-2014, 22:29
Joining the 900 Meme Team
FRC #0079
What's driving these numbers? How do you know you want a 10:1 gear ratio? Wouldn't that depend on the wheel size a little bit? And what you're doing?
Unread 30-04-2014, 22:30
YCJeon772's Avatar
AKA: Yuchan Jeon
Well we just want a general gearbox that would have a fast high gear and a strong low gear, and we use 4 inch wheels.
Unread 30-04-2014, 22:31
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (MVRT)
Actually, I've alwasy been confused about something in the JVN calc: it lists the draw at maximum output load, but is that the normal drive load or pushing match load?
Unread 30-04-2014, 22:37
FRC #0079
So, why build your own? That sounds like a pretty cut and dry use of COTS components? For example http://www.wcproducts.net/wcp-shifter-3cim/ (scroll down to the charts for the speeds) has several options that meet your needs.
I'm not saying don't go custom, just saying that you might want to look at options and see what concepts you can steal.
Unread 30-04-2014, 22:38
mman1506's Avatar
mman1506 mman1506 is offline
Hater of Tiny Molex Connectors
AKA: Marcus Quintilian
no team (WARP7)
WCP's drivetrain calculator gives a more in depth analysis than the JVN calculator. http://www.wcproducts.net/how-to-drivetrain/
2016: FRC 865 Mentor
Unread 30-04-2014, 22:43
YCJeon772's Avatar
AKA: Yuchan Jeon
I think it would be nice to learn making custom gearboxes. If it doesn't work, we could always buy them. And I never knew that site that you gave me existed, so I didn't know if there was something like that.
Unread 30-04-2014, 22:44
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
This calculator only works with Vexpro and WCP gearboxes, unless you want to use the same gears and ratios for a custom box.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
RoboChair's Avatar
AKA: Devin Castellucci
With 4 inch traction wheels 1678 Citrus Circuits ran a high gear of 22 fps(theoretical free speed) and a low gear of 8 fps on our 6 CIM drivetrain using VEXPRO ball shifters.
Unread 30-04-2014, 22:46
AKA: Nick Aarestad
As they say, steal from the best, invent the rest. I'd agree that looking at COTS options and borrowing their ratios is probably the best option for you. You might also want to be a bit more flexible with your design-- if you're designing for a certain speed and ratio, you might need to be flexible with your wheel size, for example.
tumblr | twitter
VEXU UMN (2015-??)
Unread 30-04-2014, 22:49
Lead Bumper Mentor
AKA: Mike Marandola
Did you guys have any breaker issues?
Unread 30-04-2014, 23:11
asid61's Avatar
AKA: Anand Rajamani
FRC #1072 (MVRT)
Custom gearboxes are nice, but WCP 3-cim gearboxes are hard to beat.
I would go custom only if I am confident that I can get an appreciable reduction in weight (at most a 2.25lb gearbox) or size (because WCP gearboxes are pretty large). Or if you have a gearbox design you want to try in the offseason, such as a bevel box or something similar then it would be good to try custom.
Unread 30-04-2014, 23:21
Michael Hill's Avatar
Neither, it's an overly simplified model of total current draw. It doesn't take into account stuff like battery voltage drop.
JVN's spreadsheet is a very good first pass, but you really should look into it deeper. Check out Ether's drivetrain simulation program that takes that stuff into account.
