Go to Post No offense, but telling the Killer Bees they should do something is like telling Micheal Jordan how to dunk a basketball (or Lebron James for you young'ens who don't know who Michael Jordan is)... - Don Wright [more]
Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
  #76   Spotlight this post!
Unread 01-05-2014, 15:51
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Re: RoboRio
Originally Posted by SoftwareBug2.0 View Post
I'd be interested to know how much slower it is. Maybe 10x? I don't have a good sense of how many cycles on an ARM Cortex A9 is equivalent to a cycle on a recent x86. Anybody seen a good comparison?
If you can point me to a benchmarking application, I'll try to run it on the RoboRIO. If you want another comparison between the old & the new, please see this (slide 9). I ran the same test on a 2012 i7 and it was getting 200+ FPS at 640x480 so I took it out of the comparison. Also, please note this was only using one of the two RoboRIO cores.
Side note, from what I've learned at NI Days, the new RIOs have two task schedulers. One is for RT, one is for non-RT.
I recommend reading over the Introduction to NI Linux Real-Time.
  #77   Spotlight this post!
Unread 01-05-2014, 22:12
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: RoboRio
Originally Posted by Joey1939 View Post
(Quick Note: Because of the linux shell you can run whatever java version you want)
He he, well yes, but have fun with that! Java 8 is the only java that works out of the box with no funny flags.
Also somebody was wondering what kind of linux it is: 3.2 kernel (3.2.35-rt52-2.0.0a4 #1 SMP PREEMPT RT armv7l) and its based on OpenEmbeded/Angstrom (it has opkg (dpkg-like) package management). Uses busybox for most things.
I would also not recommending running gcc on it, but you can use stock gcc for cross compiling. I've been using g++ 4.6 armel from the ubuntu 12.04 repositories just fine, though the binutils in the repos don't support a flag as they were too old, so I had to upgrade if I cared to see that flag be labled (worked perfectly find though).
Watchdog.Kill();
  #78   Spotlight this post!
Unread 02-05-2014, 08:44
dubiousSwain's Avatar
dubiousSwain dubiousSwain is offline
The ride never ends
AKA: Christian Steward
FRC #5420 (Velocity)
dubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond repute
Re: RoboRio
5. 5 second launch: The java program is saved on the roboRio as a jar. The jar is uploaded and launched without reboot in under 5 seconds.
This is a thing? So excited now
2015 MAR District Champions
  #79   Spotlight this post!
Unread 02-05-2014, 08:50
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: RoboRio
3. Units and Measures: In java pots will directly return an angle and encoders a distance
Keep in mind the amount of work you will have to do is the same. You'll still have to supply a scaling factor to get an accurate angle, because the rRIO doesn't know if you are using a 1 turn pot, a 10 turn pot, or a 54 inch string pot. The same caveat holds true for the encoders.
I didn't realize in the past that Java didn't have a function that just allowed you to supply a scaling factor when you declare the sensor. That's how LabVIEW has always had it.
  #80   Spotlight this post!
Unread 02-05-2014, 09:08
one_each one_each is offline
FRC #4057 (KB Bots)
one_each is an unknown quantity at this point
Re: RoboRio
Full Java 8 next year! I guess we can just use JavaScript (via Longhorn) as our scripting language. Can't wait until they are ready to order. I think I will save some vacation time to work on some open source.
  #81   Spotlight this post!
Unread 02-05-2014, 13:32
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Re: RoboRio
OTS Linux has multiple scheduling algorithms - a priority-based pre-emptive scheduler for real-time (non-zero POSIX priority) and fair scheduling algorithm for everything else (POSIX priority is zero). And then there is the scheduling algorithm for interrupt threads in the kernel.
  #82   Spotlight this post!
Unread 15-05-2014, 23:25
Re: RoboRio
You can pre-order a roboRIO now from AndyMark (but it won't ship until December). http://www.andymark.com/product-p/am-3000pre.htm
If you don't want to order yet, you can fill out a form indicating how many you want to buy, so to help gauge interest. https://docs.google.com/forms/d/1eiZ...?usp=send_form
  #83   Spotlight this post!
Unread 16-05-2014, 00:17
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Re: RoboRio
Anybody have any idea when the supporting parts (PD board, Pneumatics board and Regulator board) will be available? Same time as the roboRIO?
Team 4488 - Mentor 2013-2016
  #84   Spotlight this post!
Unread 16-05-2014, 00:25
Aren Siekmeier's Avatar
on walkabout
Re: RoboRio
Also, anyone know when we can hope for CAD files of these? The roboRio is already available at https://decibel.ni.com/content/docs/DOC-30419. Waiting for the rest of them to complete the picture
  #85   Spotlight this post!
Unread 18-05-2014, 12:48
MrRiedemanJACC MrRiedemanJACC is offline
FRC #2611 (Jacktown Vectors)
MrRiedemanJACC will become famous soon enough
Re: RoboRio
Has anyone see timing on when we would find out if we are a beta-testing team? My co-mentor applied for it, but I don't think we have found out anything. He is starting a Labview Academy next year at our Career Center and I can't wait for the fun we'll have!
  #86   Spotlight this post!
Unread 18-05-2014, 12:50
Re: RoboRio
The application doesn't close until May 30th so I wouldn't expect to hear anything before that. Probably 1st or 2nd week of June would be my guess.
  #87   Spotlight this post!
Unread 18-05-2014, 13:02
Re: RoboRio
Ahh gotcha, sorry I was thinking it was end of April the application was due, not the end of May. Thanks!
