Go to Post Eventually, the "less effective" tweaks will settle to the bottom, and the more effective ones will be assimilated by the group. Then someone will tweak the tweak. That's when the fun begins. - Billfred [more]
Unread 12-01-2002, 19:46
Matt_White Matt_White is offline
#0451 (The CAT ATTACK)
Matt_White is an unknown quantity at this point
Aluminum Sprockets
Anyone know where you can buy extruded aluminum that is in the 1/4" pitch pulley dimension. If you can get it extruded in the pulley pattern it saves a lot of time on the mill and weight compared to the cast iron pulleys.
I discussed it with one of the teams at the Great Lakes Regional last year but have misplaced the contact information. Any information would help.
what is or isn't a timing belt? archiver 2001 6 23-06-2002 23:26
Best Wheel Grip? archiver 2001 20 23-06-2002 22:38
two sided timing belt archiver 2001 3 23-06-2002 22:34
would brecoflex belts be allowed? Ben Mitchell Technical Discussion 1 22-01-2002 11:40
Belts, Timing Belts, and Automobiles. Anton Abaya Technical Discussion 5 09-01-2002 19:21
