Go to Post The only fee our team charges is for your heart and soul. No refunds. - Koko Ed [more]
Unread 02-05-2014, 01:34
Maxwell777's Avatar
Maxwell777 Maxwell777 is offline
Is allowed to touch stuff now
AKA: Jackson Gray
FRC #0842 (Falcon Robotics)
Maxwell777 has a spectacular aura aboutMaxwell777 has a spectacular aura aboutMaxwell777 has a spectacular aura about
4-speed gear automatic gearbox
I jokingly mentioned to a teammate earlier that we should cad a 4-speed gearbox, but now that I think about it, has anyone else ever done a 4-speed gearbox and controlled it like an automatic transmission in a car? It seems fairly straight forward, have an encoder on the shaft to determine if the robot is either stalling (trying to push another robot) or has stopped accelerating (has hit full speed), and in response, either shift up or shift down.
Has anyone done anything like this and do you think it is worth doing?
But why?
Unread 02-05-2014, 01:40
Re: 4-speed gear automatic gearbox
FRC0033, Killer Bees, did one many moons ago. http://www.chiefdelphi.com/media/papers/1580
Bear in mind that the motors used are no longer FRC-legal.
And yes, this was automatic. I seem to remember that associated code filters wound up in a sponsor's product because they were handy.
Unread 02-05-2014, 01:45
wasayanwer97's Avatar
wasayanwer97 wasayanwer97 is offline
Take from the best, invent the rest
AKA: Wasay Anwer
FRC #0668 (The Apes of Wrath)
wasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant future
Not sure if anyone has ever done it before, but from a practical standpoint, I can't imagine a situation that would justify the complexity and relative bulk of a 4-speed gearbox.
From a design standpoint it's relatively straightforwards. It would just be either the addition of an extra shifter stage (if you wanted to try to use COTS shafts/parts), or a custom shifting shaft and multiple-position cylinder/actuator.
If you wanted all four speeds on the same shaft, you'd probably find it easiest to use a custom ballshifter. (Though I don't have any experience with >2 speed drives.)
"Coming together is a beginning; keeping together is progress; working together is success."- Henry Ford
FRC Team 668: The Apes of Wrath
Pioneer High School, San Jose CA
http://www.theapesofwrath.org
Talking to other FIRSTers is great. Add me on Facebook!
My Page
Unread 02-05-2014, 01:52
Maxwell777's Avatar
AKA: Jackson Gray
Awesome. They managed to make it pretty compact. It doesn't look much bigger than your avg single speed gearbox.
Was it ever built/used? Is there a video of it?
But why?
Unread 02-05-2014, 01:53
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team 968 did a 4-speed gearbox a couple different years. I want to say it was 2004 and 2005. I don't remember if it was autoshifting though.
On 696, we tried an autoshifting algorithm on our 2-speed this year and did not find any appreciable distance in field-crossing time when compared to leaving it in high gear, even with varying the shift point through a range of set points.
Unread 02-05-2014, 02:19
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
One of our mentors made an excel graph of acceleration without friction with selectable speeds and calculus and stuff. It basically showed that speeds from 10-30fps will accelerate at almost the same rate until they top out at max speed. The only real change in accleration rate was noticed when we changed the inputs from 4 cim to 6 cim.
It's not extremely difficult to autoshift. Normally you would be in high gear, but the driver would have a low gear override pushbutton to go into low gear for normal driving. Then you could just put a current sensor in the motor circuit and shift into low gear whenever current gets too high.
4 speeds seems excessive to me, because all you really ever need is a normal drive gear and a low pushing/ positioning gear.
You can also just use PWM control to lessen the duty cycle of the motors if current spikes.
Unread 02-05-2014, 02:26
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
I really do think that with enough work at it, this could be a better solution than a single or two-speed drive. The real problem that any team faces is shifting speed vs. the actual advantage gained from a new speed.
Side note: I believe that 217 did a CVT in 2002. That may be of interest.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 02-05-2014, 04:16
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Here is the main problem with anything more than a single or 2 speed gearbox:
Time
The field is 54 feet long, and (this year) 25 feet wide. The furthest distance you could possibly need to travel, straight line, is ~60 feet.
The question is not whether you get more top speed out of 4 gears, but whether or not you can do such a thing in 60 feet, including stopping. If you have a straight line top speed of 30fps (or 1116.437fps for that matter), if you cannot reach said speed by the time you cover the length of the court, you have an improperly designed gearbox.
We ran a 5.5fps and a 15.5fps drivetrain this year, with 6 CIMS in ballshifters. The actual, tested, realistic acceleration time we got from starting in first gear, reaching 5.5fps, then shifting up "on-the-fly", only gained us hardly measurable time. We, like most if not all teams who use shifting gearboxes do not use them for decreased acceleration time, but for torque vs speed selection-low gear for plowing, high-gear at all other times. Integrating some smart code to decide which gear to use based on wheel speed is definitely a good thing, but not why the shifters were chosen for the design.
Is such a challenge to build a compact 4speed transmission a great off-season project? sure- but consider this before using it on next years game: the field is everything.
If you save 0.1 seconds crossing the field with your new system, but you only do it 2-3 times a match, is it worth all that effort just for the extra 0.3 seconds you gain? Also, if we have another game like 2010 or 2010, having more speeds is useless because the field is even smaller.
Also, will you ever get a straight-line path? more often than not, no. There will be some field element, or one of the other 5 robots in you way, that you will have to steer around. Steering slows you down, in all cases of tank drive, as you must slow one side to turn that direction. That will further hinder your capability.
Sorry for being the Debbie-Downer, but that is my $0.02
Unread 02-05-2014, 08:01
Abhishek R Abhishek R is offline
FRC #0624
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
We used auto shifting this year, and it did help us get up to speed faster. I can't comment on the specific technical aspect as to why, but in both 2013 and 2014 our robot always starts in 1st then shifts up to 2nd on the fly then back down to 1st when we come to a stop. It puts less strain on the battery - we could leave it in second all the time while we had a fresh battery, but found it could quickly get run down.
2012 - 2015 : 624 CRyptonite
Team Website
Unread 02-05-2014, 08:35
techtiger1's Avatar
techtiger1 techtiger1 is offline
Coach Drew?!?!
AKA: Drew Disbury
FRC #1251 (TechTigers)
techtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond repute
Send a message via AIM to techtiger1
recommend less led lights on the robot next year 624, it might save some battery .
Team 1251 The TechTigers
"Inspiring future innovators, one stripe at a time"
2004 Rookie All Star Orlando Regional
2006 Palmetto Regional Winner
2007 Orlando Regional Winner
2008 Orlando Regional Winner
2010 Orlando Regional Winner
2013 South Florida Regional Winner
Unread 02-05-2014, 10:46
Stephen.Yanczura's Avatar
Stephen.Yanczura Stephen.Yanczura is offline
opportunist
FRC #0195 (Cyberknights)
Stephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to all
When I was on 195 as a student in '05 I copied the 33 design, made a few changes and we used it on our robot that year with our (at the time) perennial tank track drive. It was cool, fun, and a great experience BUT wholly unnecessary.
stephenyanczura
team 0195 | 2010-Pres. | cyberknights | Conn. | mentor
team 0195 | 2006-2007 | cyberknights | Conn. | mentor
team 1660 | 2005-2006 | harlemknights | NYC | mentor
team 0195 | 2001-2005 | cyberknights | Conn. | student
s.j.yanczura@gmail.com
Unread 02-05-2014, 10:55
JohnFogarty's Avatar
AKA: @doctorfogarty
Not that this is the thread for that, but the amount of LEDs they had on their robot...I don't even think they were drawing much more than an amp.
John Fogarty
Unread 02-05-2014, 11:53
Side note: I believe that 217 did a CVT in 2008. That may be of interest.
Here's 217's whitepaper on their CVT (from 2002). http://www.chiefdelphi.com/media/papers/1361
Unread 02-05-2014, 11:59
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
Team 1503 built an offseason drivetrain that utilized two 4 speed transmissions designed by Pat Fairbank. Check it out here.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 02-05-2014, 12:04
gurellia53's Avatar
gurellia53 gurellia53 is offline
word up
AKA: Andrew G
FRC #1736 (Robot Casserole)
gurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to behold
It would be cool and fun to design, but probably not practical for an FRC game if used like an automatic transmission. Like other people have said, the field is too small to decrease travel time significantly.
Automotive automatic transmissions are used because of a narrow range of speed from the power source (engine) and a high range of output speeds. Electric drives typically don't use a shifting transmission because a motor produces torque from 0 RPM to a high RPM plus they can remove cost associated with a transmission and final drive.
I could see a 4 speed more useful in FRC if used like an ag tractor trasnsmission where different speeds are used for different tasks. For example:
speed 1 - power takeoff
speed 2 - ultra-low pushing gear/high precision driving (4 fps)
speed 3 - low gear for typical game play and acceleration (8 fps)
speed 4 - high gear for quickly travelling 60 feet (16 fps)
FRC
Robot Casserole 1736: 2007 - 2008, 2013 - present
Team Neutrino 3928: 2012
