Go to Post But, as a mentor I should caution you that FIRST is not about you its about the students. - SomeoneKnows [more]
Unread 02-05-2014, 10:00
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: NASA APP KILLED FRC LIVE STREAM @7:30!!!
Don't blame NASA. This is 100% FIRST's fault.
Every year they insist on publishing a schedule that is blatantly wrong. There is no chance Einstein would be done by when they said it would be. There never is...yet they continue to publish a schedule saying it will be.
What is NASA supposed to do? Assume FIRST is wrong and allocate resources for longer than they're told they need them? FIRST needs to get realistic and fix the schedule.
2001-2004: Team 100
2006-Present: Team 254
Unread 02-05-2014, 10:09
Well, if I were running the show that's what I'd do. Because as you said above, they wouldn't have to assume FIRST is wrong if they're wrong every year.
Unread 02-05-2014, 10:12
Cory's Avatar
AKA: Cory McBride
And if they had assumed wrong and added an extra hour because Einstein was 3 hours last year and 2 hours this year? They'd have an hour of dead space. Presumably that costs someone money and wouldn't be well received.
2001-2004: Team 100
Unread 02-05-2014, 10:20
Dead space, or some non-time-critical filler.
1 hour once a year for an event this important? I'd say yes.
But it's OK to disagree.
Unread 02-05-2014, 12:20
Roger Roger is offline
FRC #1153
Rookie Year: 1900
Roger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond repute
You'd think they'd learn from 46 years ago? (The Heidi Game)
How much over the end time was it? Why can't they do it like football games on TV, and have some commentary afterwards? Certainly somebody can discuss what happened over the last couple of days, with highlights from each division, to fill the hour?
Unread 02-05-2014, 10:15
Amo10's Avatar
Amo10 Amo10 is offline
AKA: Andrew Morris
FRC #4468 (LINKS)
Amo10 is on a distinguished road
I completely agree with you. Last year the nasa stream did the same thing but it was actually way worse I think it cut off even before the matches on Einstein started I think. Knowing this I was expecting this to happen. So compared to last year I thought that FIRST did a great job but there is still room for improvement next year. But I also think that NASA is going to need to partly be a part of the solution since even in the sports that are on TV run over and the broadcasters shift there schedule if they do but NASA needed to be notified it was a possibility for this to happen.
Andrew Morris
Team 4468 (2012-2016)
2016 PCH District Columbus Event Winner
2015 Peachtree Regional Engineering Inspiration Award
2015 Peachtree Regional Finalist
2013 Peachtree Regional Rookie Inspiration Award
