Go to Post The weight sounds about right, too. If you need more than 65 pounds for your manipulator, then the drivetrain isn't the part you should be redesigning... - s_forbes [more]
Unread 02-05-2014, 11:48
chris.boyle's Avatar
chris.boyle chris.boyle is offline
Programming Mentor
FRC #0068 (Truck Town Thunder)
chris.boyle is on a distinguished road
Re: Share you Autonomous
We used a record and replay system for autonomous this year. Attached are the complete projects for the custom dashboard and robot.
There is a tab on the dashboard for starting and stopping the recording process. It uses the SmartDashboard to communicate between the dashboard and robot.
2014 Chairman's Award--Michigan State Championship
2014 Chairman's Award--Waterford District
2014 Winner--Great Lakes Bay District
2013 Chairman's Award--Kettering District
2012 Championship Division Finalists--Thanks 330 and 639
Unread 02-05-2014, 12:07
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Originally Posted by Bpk9p4 View Post
I really like this idea. The only problem i see with it is you can only do one command at a time. have you found a way to get around this problem?
Yes, and no, you can program a command that does multiple actions, but there is only one command active at a time.
I forgot to mention the best part is that the script file is just a text file that resides on the cRio. The cRio has a built in ftp server, so you can change these sequences, and re-run without connecting to labview, compiling, etc. The whole process to change the script and ftp to the cRio can be done in about a min. We have done this while queuing for a match. It takes less time to change the auto code, and download, than it takes to charge the pneumatic system. We also have a dashboard selection that chooses between 7 automodes.
The sooner we get behind schedule, the more time we have to catch up.
Unread 02-05-2014, 13:27
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
You just need to be smart in how you lay out your commands, and remember they are very high level. Lets take a choo-choo style shooter which starts with the shooter released and a ball on top of it (for whatever reason). Also it takes ~3 seconds to load. Using something like beescript you could have a routine like this:
#Load the shooting mechanism
LOAD_SHOT
#Drive forward 5 feet
DRIVE 5
#Internal timer waits until 5 second mark if not hot
DELAY_IF_NOT_HOT
#shoot when ready
WAIT_ON_LOAD
SHOOT
#Make sure the shooter is down for start of teleop
LOAD_SHOT
You can write your LOAD_SHOT command such that it can drive the shooter motor and wait on a switch. If you do this, you don't start driving until ~3 seconds into auto, which is a problem.
Instead you can write your command to tell a different process the same thing, letting the script continue. It then can meet back up with the WAIT_ON_LOAD command to make sure its ready to shoot. In this way, both the driving and the camera code are running in parallel with the code to load the shooter.
Essentially you can write your commands to set off a parallel part of the code and continue. If all of the main robot actions are handled in a separate process, this becomes much easier to do (and it carries over to teleop).
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 02-05-2014, 13:28
Bpk9p4's Avatar
Bpk9p4 Bpk9p4 is offline
FRC #1756
Bpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant future
any reason you choose to save it on the crio and not just read it from a laptop?
Unread 02-05-2014, 16:22
tr6scott's Avatar
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
Yes, I don't know how to get the cRio to read a file over the FMS to the driver station. Maybe there is something there already, but I have never tried it.
Unread 02-05-2014, 19:00
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
You can implement your own UDP/TCP connection to communicate between the dashboard and the cRIO. We have done this in labview when we needed extra vision processing computing power. Also, the smart dashboard may have similar capabilities.
Unread 02-05-2014, 19:09
wt200999's Avatar
Texas Instruments
AKA: Will Toth
Another interesting way to do this would be to use port 80 (HTTP) or 443 (HTTPS) which are both not blocked, and write some kind of snazzy web app to create/modify/save your scripts. The current cRio already runs a web server, and setting this up on the robotRIO will be even easier. If you are worried about resource usage you can do something to pause or kill the web server when you are not in a disabled mode.
Unread 03-05-2014, 03:11
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
Originally Posted by notmattlythgoe View Post
With some forethought you can create some pretty interesting command groups. And yes you can account for failures. When you add any of the commands you can add timeouts to them. Of course, depending on what has failed to complete could effect if your auto mode is successful or not. Sometimes you might want the robot to not finish the auto mode if one step has failed.
Here is an example of non linear steps.
addSequential(new DriveStraightCommand(0.85, 60));
addSequential(new TurnToDegreeCommand(0.5, 45));
addSequential(new MoveAndShootCommand());
addSequential(new new TurnToDegreeCommand(0.5, -45));
MoveAndShootCommand:
DriveStraightCommand driveCommand = new DriveStraightCommand(0.85, 120);
addSequential(driveCommand);
addParallel(new WaitForDistanceCommand(40, driveCommand));
addSequential(new ShootCommand());
addParallel(new WaitForDistanceCommand(60, driveCommand));
addParallel(new WaitForDistanceCommand(80, driveCommand));
The DriveStraightCommand implements an interface called IProvidesCurrentDistance which will return the distance the command has currently moved. Using this interface you can pass the running command in to other commands and have access to the distance moved at a given time. The MoveAdnShootCommand will start the robot moving, then once it has reached 20, 40, and 60 inches will run a shoot command. The final TurnToDegreeCommand will run once the MoveAndShootCommand has finished.
This still seems linear to me. All it's doing is waiting for some condition and deciding to go on to the next step or continue waiting.
What I was trying to ask is if you could do something like:
if goal is hot:
  fire
  drive forward
else:
  turn
  fire
Unread 03-05-2014, 10:03
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
if goal is hot:
  fire
  drive forward
else:
  turn
  fire
This is one of the things I want to investigate during the off season. This is my untested theory so take it with a grain of salt.
TwoBallTwoHotGoalCommand
HotGoalFinder finder = new HotGoalFinder();
addSequential(new DriveStraightCommand(0.85, 240));
addSequential(finder, 0.5);
addSequential(new DecisionCommand (finder, new TurnandShootSeries(), new ShootCommand()));
addSequential(new DeployArmCommand(Arm.DEPLOY, RobotMap.pickupPower));
addSequential(new DriveStraightCommand(-0.85, 240));
addSequential(new WaitCommand(1));
addSequential(new HotGoalDecision(finder, new TurnandShootSeries(), new ShootCommand()));
HotGoalDecision
public class DecisionCommand extends Command {
public DecisionCommand (IProvidesDecision decision, Command trueCommand, Command falseCommand) {}
   public void initialize() {
      if (decision.getValue()) {
         trueCommand.initialize();
      } else {
         falseCommand.initialize());
   public void execute() {
         trueCommand.execute();
      } else {
         falseCommand.execute());
   etc...
IProvidesDescision
public interface IProvidesDecision {
   boolean getValue();
Unread 03-05-2014, 12:39
pastelpony's Avatar
pastelpony pastelpony is offline
Programmer/Electrical
AKA: Zach M
FRC #3525 (Nuts and Bolts of Fury)
pastelpony will become famous soon enough
This isn't our main autonomous (our main autonomous uses vision tracking to detect the hot goal and shoot at it; don't have access to the team's programming computer atm and left my flash drive in it) but it's a 2-ball autonomous VI that wasn't used in the final code. It's pretty basic as it was written in a blank VI and so I didn't get to use global variables or subVIs. See if it helps.
Unread 03-05-2014, 13:13
AGPapa's Avatar
AGPapa AGPapa is offline
AKA: Antonio Papa
FRC #5895
AGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond repute
if goal is hot:
  fire
  drive forward
else:
  turn
  fire
I've implemented something like that. I have an "if" command that continues autonomous from two different script files based on the result of some function. The first parameter of "if" is the name of the function to check. The next parameters are the name of the script file to run if true and then the name of the script file to run if false. For example, here is the two ball hot script.
in twoBallHot.script
SHIFT on
WAIT 1000
SET_SHOULDER 49
IF right_hot rightHot leftHot
in rightHot.script
DRIVE_STRAIGHT 75 0
TURN 12
WAIT 100
SHOOT
WAIT 400
SET_SHOULDER -5
TURN -152
INTAKE in
DRIVE_STRAIGHT 75 -152
SET_SHOULDER 49
TURN -7
INTAKE off
DRIVE_STRAIGHT 70 -7
WAIT 200
SHOOT
SHIFT off
in leftHot.script
DRIVE_STRAIGHT 75 0
TURN -12
WAIT 100
SHOOT
WAIT 400
SET_SHOULDER -5
TURN -150
INTAKE in
DRIVE_STRAIGHT 75 -150
SET_SHOULDER 49
TURN 17
INTAKE off
DRIVE_STRAIGHT 80 17
WAIT 200
SHOOT
SHIFT off
Team 2590 Student [2011-2014]
Team 5684 Mentor [2015]
Team 5895 Mentor [2016-]
Unread 03-05-2014, 13:37
tr6scott's Avatar
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
Our one ball hot check script was this:
#One Ball, with Hot Checking
WAIT 500
CHECK_HOT
ARM_MOVE 1
SET_ROLLER_SPEED 25
DRIVE_STRAIGHT 96 5000
#Was 3500
SHOOT_HOT 3000
STOP_ALL
The "Check_Hot" Command just checked the hot goal, and wrote the status to a global variable. The "Shoot_Hot" command would look at the global variable, and if hot would shoot without delay, and if it was not hot it would delay the argument "3000" milliseconds, then shoot.
Unread 03-05-2014, 13:57
AKA: Eric
Excellent. That's exactly what I was wondering about.
Unread 03-05-2014, 14:27
AKA: Eric
      } else {
      } else {
   etc...
That looks like it would work. I was pretty sure it would be possible to do something but I thought it might get really ugly really fast. That's a pretty slick way to do it.
Here's something you could do if you wanted to be avoid duplicating the end of command conditions in the subsequent if:
class Continuable extends Command{
	//I don't remember whether I've set this class up is valid Java...
	//this would return self unless you wnated to run a different command.
	abstract public Continuable next();
	public bool isFinished(){
		return next()==null;
class Continues extends Command{
	Continuable current;
	Continues(Continuable cmd){
		current=cmd;
	void initialize(){
		if(current!=null) current.initialize();
	void execute(){
		if(current!=null){
			current.execute();
	bool isFinished(){
		if(current==null) return 1;
		current=current.next();
		return current==null;
Unread 03-05-2014, 14:40
Flywheel Police
		current=cmd;
	void initialize(){
	void execute(){
		if(current!=null){
			current.execute();
	bool isFinished(){
Thanks. This is one of the topics I want to tackle this off season. I'm still struggling with the best way to store the decision, in a command or in another object of some sort that gets passed around. It probably depends on the usage.
