Go to Post why re-invent the wheel when it still rolls? just make it better. - Tytus Gerrish [more]
Unread 02-05-2014, 01:59
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Tiny wheel
696's WCD in 2013 had 3" Colsons originally. After we couldn't get over the carpet bump,we went to 3.4" custom wheels.
Unread 02-05-2014, 02:10
Tyler2517's Avatar
Tyler2517 Tyler2517 is offline
ShortOnes
AKA: Tyler Gibb
FRC #2517 (Evergreen Robotics)
Tyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura about
Re: Tiny wheel
Were designing a swerve with 2-3 inch wheels right now. It so much easier to get the gearing right. The drive Base is a bit larger, almost on par with west coast. You can definitely support a robot with a aluminum wheel that small. Obstacles could be a problem.
Unread 02-05-2014, 08:37
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
Re: Tiny wheel
Just be sure that you bring spares if you are running wheels that small.
All your tread wear will be focussed to a smaller surface area of tread so a 2" wheel's tread will burn off twice as fast as a 4" wheel's and three times faster than a 6" wheel. After seeing photos of some post-competition racing slicks I would shy away from anything smaller than 4" and even then I would be worried.
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
Unread 02-05-2014, 08:38
fox46's Avatar
Re: Tiny wheel
You could of course mitigate the wear by going wider but then you're increasing size again.
Unread 02-05-2014, 08:52
Rob Stehlik's Avatar
Rob Stehlik Rob Stehlik is offline
FRC #0610 (Coyotes)
Rob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of light
Re: Tiny wheel
Agreed. Rapid tread wear is the main drawback with small wheels. We burned through three sets of 4" wheels last year, and I got tired of changing them (not trivial in a dead axle design).
Unread 02-05-2014, 10:06
Re: Tiny wheel
Originally Posted by Mike Marandola View Post
Ah, the tread pattern was worn off. They aren't too small then.
They told me that they grind the tread off, purposefully.
Unread 02-05-2014, 10:21
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (MVRT)
Re: Tiny wheel
Yeah, I heard that too.
Tread wear. With WCD it shouldn't be as bad to swap out wheels.
Unread 02-05-2014, 11:47
lukedude43 lukedude43 is offline
Doer of stuff and things
AKA: Luke Reinert
FRC #4030 (NullPointerException)
lukedude43 will become famous soon enoughlukedude43 will become famous soon enough
Originally Posted by Joey Milia View Post
The smallest wheels I've seen used were used on 973's swerve drive in 2012.
192 ran wheels just under 3.5in this year and will most likely be going with 3in for the offseason and next year. 3in is probably as small as we'd go for use on a WCD, might go smaller with a swerve drive though. Small wheels make a huge difference when trying to make the drive gearboxes small and light.
I for one would love to see the work of art that a 192 swerve would be.
Unread 02-05-2014, 13:09
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
Re: Tiny wheel
as Brian said earlier I have no idea where the small wheel weakness thing is coming from???
In fact I would argue in many cases they are stronger, as side-load has less of the lever effect on the axle interface. In the world of unicycles (spoked wheels) small wheels are often substantially stronger.
When it comes to tread wear I think people need to adapt more NASCAR philosophy. Run the compound that works well for you change it often, if you're going six cim a lot of smart people (610) will argue that traction limited drive is actually the way to go.
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Unread 02-05-2014, 14:10
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Re: Tiny wheel
We ran 6 3" colson wheels. After 2 regionals there is no visible loss in diameter or pushing power.
Unread 02-05-2014, 14:11
AdamHeard's Avatar
Lead Mentor
Re: Tiny wheel
2.5" on or 2012 swerve.
Smaller wheels don't usually happen because of ground clearance.
Unread 02-05-2014, 14:22
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Tiny wheel
Only thing that hasn't been mentioned thus far is tread wear. Smaller wheels turn more revolutions per distance traveled, thus the tread will wear down faster. Probably not an issue with Colsons.
There may also be something to be said about traction when dealing with non-smoothed treads (i.e. Blue Nitrile or Orange Roughtop). Larger wheels have more contact patch with the carpet fibers vs tiny wheels, thus there are more fibers to push against, meaning increased traction in the forward direction. There is a tradeoff point of where this benefit is removed on very large wheels (> 4"-ish?) However, this is only conjecture based upon findings that 4"x1.5" wide roughtop gets more traction than 4"x1" wide roughtop on FRC carpet (I swear there used to be a whitepaper somewhere...).
2017 Scoring Model
CAD Library | GitHub
Unread 02-05-2014, 14:44
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Re: Tiny wheel
Actually fox46 and Rob both brought that up earlier on this very page. Accelerated tread wear is definitely another drawback to smaller wheels.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 02-05-2014, 14:52
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
Re: Tiny wheel
Originally Posted by smistthegreat View Post
I'm pretty sure 525 and 1551 have used some of the ridiculously small Colsons on octacanum pods in the past.
Wow - good memory! Yes, we used 2" Colsons in 2012.
Unread 02-05-2014, 17:00
I am Dave! Yognaut
AKA: Brian Bray
Re: Tiny wheel
Larger wheels/more contact patch supplies more grip due to the "cleating" effect where the "pinion" of the wheel has physical exertion on the "rack" that is the carpet. Like gears, there is more than static friction meshing the treaded wheel to the fiberous carpet.
If you were only just calculating straight static friction, wheel diameter and even wheel number has zero effect, because while you are increasing contact surface area, you decrease weight per unit surface area in a 1:1 fashion. All that matters in that calculation is coef of friction and weight of robot (f=mu*N)
