Go to Post A chop saw may cut aluminum, a knife can also be used to eat ice cream. - fox46 [more]
  #31   Spotlight this post!
Unread 02-05-2014, 14:54
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Custom Gearboxes
Originally Posted by Oblarg View Post
Strictly speaking, what you're doing is not simply dimensional analysis. Dimensional analysis would be multiplying the characteristic size of the wheel by the characteristic speed of the motor; it thus usually results in loss of dimensionless constants.
Isn't that only true if you construct the system using dimensionless constants? You can specify that you're looking for ft/s from rev/min, and use dimensions of ft/rev (from the circumference equation, so your π should be included there in the unit conversion) to keep everything consistent.
  #32   Spotlight this post!
Unread 02-05-2014, 16:01
Oblarg Oblarg is offline
AKA: Eli Barnett
The whole point of dimensional analysis is usually to do calculations without specific knowledge of the equations governing the system, so doing this sort of defeats the purpose. Clearly one can add a sufficient number of non-physical units (such as "revolutions") and reduce any problem to "dimensional analysis" with enough care, but then you're not really doing dimensional analysis anymore.
Unsurprisingly, you usually only do dimensional analysis when the system is sufficiently complicated that you don't want to solve the problem properly (e.g. estimating the temperature of the sun or the size of the mountains on a planet of a given size).
"The breakfast of champions!"
  #33   Spotlight this post!
Unread 02-05-2014, 19:18
Chowmaster4695 Chowmaster4695 is offline
Lathe Master
AKA: Jerry Wright
FRC #4695
Team Role: Tactician
Chowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond repute
Originally Posted by Mk.32 View Post
The CIM mounting holes are decently accessible, hard to see in this photo.
How do you know there is to much reduction? If you read the thread in entirely I believe I commented on it was on the slow side, but worked beautifully.
We are using 1/4-20s to hold the gb together (pretty standard in FRC AM uses it a lot), since that's what we had and they were alum bolts so they weighed nothing compared to the steel ones. I am sure 10-32s would have worked fine but what we had is what we had.
Why does the pocketing have to contour the spacers? It got a little weird since we needed to throw in all the slots which is what bolts it to the robot. And honestly I didn't really care much in the terms of aesthetics; it could have been pocketed more heavily but the mentors on the team wanted to be on the safe side. And the weight difference would have been in the grams.
I know its too much reduction because I have seen the application it is being used in and 2 mini cims is just overkill to move an intake up and down.
And for the rest of the comments, it seems like you know the things I said are the things that could be optimized and you should ask yourself can I do better? Why leave your designs unoptimized? When your design is optimized in weight , speed, and resources that's when your getting the most bang for your buck. Chow out
