Go to Post WATER GAME! Always a water game... - kendra21093 [more]
Unread 03-05-2014, 22:20
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
pic: Highlander Robotics reverted gearing shifter
Unread 03-05-2014, 22:25
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Re: pic: Highlander Robotics reverted gearing shifter
This looks really good Joe! Will 1687 be running these at BattleCry later this month?
Any concerns about using lexan as your sideplates instead of aluminum? Not necessarily for cracking but also for flexibility of those plates.
Either way it looks really nice, can't wait to hear how they work out for that defensive monster you guys made this season!
We had many debates about running 3 CIM ss, 2 CIM two speed, or 3 CIM two speed and debated the main breaker tripping.
In the end we ran 3 CIM ballshifters (as it was cheaper than WCP 2 CIM shifters) and tripped our main breaker once during the final seconds at UNH. After having to play 5 semi final matches our robot was getting very worn out and in the finals we t-boned 176 for a solid 7 seconds before tripping with 5 seconds left on the clock.
1058 PVC Pirates 2016 - xxxx
Unread 03-05-2014, 22:34
Joe G.'s Avatar
AKA: Josepher
Thanks Brendan! Yup, we plan to have two of these manufactured and in the robot within the next week.
Not too worried about the 1/4" Lexan, we've done a lot of similar things over the past few years with no issue, due to our inhouse CNC router which handles Lexan beautifully, but just can't do aluminum. You have to be a bit more mindful than usual about creating a broad footprint for both mounting and supporting standoffs, but as long as that's well done, they hold up fine. Our shooter gearbox this year used similar construction, and didn't get the reinforcement from butting right up against the chassis sheet metal that these guys will.
Looking forward to playing with you guys at Battlecry!
Unread 03-05-2014, 22:37
Oblarg Oblarg is offline
AKA: Eli Barnett
How does the shifting actually work on this? I could be wrong, but it looks to me like you'd need the shifting assembly on the primary shaft to make this work, but I only see one on the secondary shaft (and I can't figure out what it's for, since it seems like it'd work fine with only one on the primary shaft).
"The breakfast of champions!"
Unread 03-05-2014, 22:43
Joe G.'s Avatar
AKA: Josepher
The dog shift assembly is on the primary output shaft, just hidden by the CIM motors -- what you're seeing above is the much more visible encoder mount and coupling. The 70t primary reduction gear and 48t dog gear are bolted together and both free spin on the shaft, engaging with the output only when the dog is pulled towards the CIMs. Extending the shifting piston engages the 60t gear nearest the front face of the gearbox, such that power must pass through the reduction of the secondary shaft.
Unread 03-05-2014, 22:48
AKA: Eli Barnett
That makes a lot more sense, thanks.
Unread 04-05-2014, 00:04
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Very clever! I like the idea of using extra reductions on a low gear.
Unread 04-05-2014, 08:15
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
what are the gear reductions and the rest of your drive train?
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 04-05-2014, 14:25
Joe G.'s Avatar
AKA: Josepher
High gear is 6.4:1, low is 11.4:1, giving us speeds of about 8 and 14.5 feet per second, riding on 4" treaded colson wheels, set up in a belt driven WCD with sheet metal construction. Utilizing gears that we had on hand was a high priority for this design, as budget for offseason improvements is next to nonexistant, and this played a large part in driving these choices. Future iterations would likely have a larger reduction spread and faster high gear, as long as the game calls for it.
Unread 04-05-2014, 16:15
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Any reason why you opted for a low of 8 fps instead of something like 5?
Unread 16-10-2014, 13:38
Kevin Kolodziej's Avatar
Kevin Kolodziej Kevin Kolodziej is offline
Operator in 100+ matches
AKA: Yngwie Kamen's roadie
Kevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond repute
Send a message via AIM to Kevin Kolodziej
Did you make a custom output/shifting shaft for this gearbox? It seems that the stock WCP shafts don't have enough room to fit two gears on the high side and still be secured through a bearing at the plate. We've been investigating a very similar concept and if the stroke of the shifting cylinder is limited to less than 1/2", it looks like it might be possible, with some creative use of spacers for the low side gear. I'm interested how you solved this issue.
We're not comfortable making a stepped hex shaft like the WCP shafts are. The AM dogs work on 1/2" hex shafts, but the dog profile is different between WCP and AM and would introduce some backlash into the system when reversing directions.
Team 71: 1999, 2000 (Driver), 2001-2002 (Driver, Animator) // Team 1064: 2003 (Co-founder, Coach), 2004 (Coach) // Team 1714: 2006-2007 (Mentor, Coach)
Team 1675: 2005-2007 (Mentor, Coach), 2008 (Mentor), 2009-2017 (Mentor, Coach)
FLL: '04 (Judge), '05 (Ref), '06 (Ref), '07 (Ref), '08 (Judge, Ref), '09 (Judge), '10 (Ref), '16 (Judge Advisor) // Ref: '05 (IN, IRI), '06 (IN, IRI), '07 (IN, IRI), '08 (WMR, Curie)
WI RPC: 2006 - 2016 // FRC Inspector: '07 (WI), '08 (WI, IL), '09 (WI, IL), '10 (WI, CMP), '11 (WI, IL, CMP), '12 (WI), '13 (Northern Lights)
2007 WI Woodie Flowers Award Finalist // 2011 Wisconsin Regional Outstanding Volunteer // 2011/2013 Midwest Regional Chairman's Award
