Go to Post Inaccurate data is not data. It's guessing. - George1902 [more]
Thread Tools Rating: Thread Rating: 78 votes, 5.00 average. Display Modes
Unread 05-05-2014, 16:21
ArtemusMaximus's Avatar
ArtemusMaximus ArtemusMaximus is offline
Enginerd
FTC #11722
ArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to all
Re: VIAIR 250C-IG Compressor
Originally Posted by Mark Sheridan View Post
Do note the Viar 90C performance is at 13.8 volts. The Thomas 215ADC38/12 is quoted at 12 volts. Thus the 90C has better performance due to the higher supply voltage in its testing. It would be nice to get data points at 12 volts.
Anyone have a flowmeter handy? Maybe just time the two compressors to fill a known volume would be enough.
http://www.viaircorp.com/90C.html#tabs-2
http://www.cfpwarehouse.com/thomas/c...215adc3824.pdf
I found that chart somewhat confusing. I thought that 13.8V referring to last PSI value. If what you are saying is true and 13.8V applies to the whole table than evaluation need to be done for the VIAIR 250C-IG Compressor as well as it has same issue - 13.8V is also stated at the end of the table.
