Go to Post ah, common sense, not as common as one might think... - Ansem Retort [more]
Unread 05-05-2014, 23:12
baumgartensam's Avatar
baumgartensam baumgartensam is offline
AKA: Sam Baumgarten
FRC #0751 (Barn2Robotics)
baumgartensam will become famous soon enough
Stellaris® MDL-BDC24 same as Jaguar??
Hey everyone,
I was looking for specs on the maximum operating temperature for a jag and I noticed jags don't seem to really exist outside the world of FIRST. I found this TI spec page (http://www.ti.com/lit/ug/spmu064c/spmu064c.pdf) for the Stellaris® MDL-BDC24 and it seems identical to a Jag. I don't plan on buying any to use on a robot but do these specs seem to be the same as a Jag (aka is the jag just a rebranded Stellaris® MDL-BDC24). There are a lot of useful specs in that datasheet and overall there is more documentation on these than Jags. Thanks!
Unread 06-05-2014, 01:50
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Re: Stellaris® MDL-BDC24 same as Jaguar??
Yes - depending on which Jaguars you're talking about. The 2011 KOP checklist lists the MDL-BDC24 as the KOP Jaguar motor controller.
The Jag was originally made by a company called Luminary Micro using their Stellaris microcontroller. These are the "brown jags", part MDL-BDC. Luminary was bought by TI back in 2009, and an updated version of the controller was released. These are the "black jags", part MDL-BDC24.
I can't speak for the "modern" Jags distributed by VexPro, but I think they're essentially the same. TI (or Luminary Micro for that matter) never really wanted to be in the motor controller business, they just made the Jag because it was something neat to do with the Stellaris microcontroller. So manufacturing it got passed off to IFI within the last couple years.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 06-05-2014, 15:50
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Its not that TI doesn't want to be in the motor controller business (because they certainly are), TI just doesn't generally provide products to end users. Calculators are the exception to that rule.
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 06-05-2014, 17:51
s1900ahon s1900ahon is offline
AKA: Scott McMahon
FRC #2468 (Appreciate)
s1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant future
Generally, companies like TI who supply product (semiconductors) to their customers do not like to compete with the products made by their customers (motor controllers). Reference designs often provide an example of what can be done with the company's technology, but aren't intended to be sold to the end user.
Jaguar was a bit of a strange creature in that it was designed to suit the needs of FIRST (per a request FIRST made for a new motor controller back in 2008), but the justification within LMI to undertake the effort was that it must also be a reference design.
So, the "don't sell a product that can compete with a customer's motor controller" rule was broken in this case due to the philanthropic good of supporting FIRST.
Unread 06-05-2014, 21:18
Coach Norm Coach Norm is offline
Team 2468 Coach/Adviser
AKA: Norman Morgan
FRC #2468 (Team Appreciate)
Coach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond repute
You would know since you were the lead on this project.
FRC 2468 Team Lead 2008 - Present
Win The Day!
Unread 07-05-2014, 13:42
sparkytwd's Avatar
sparkytwd sparkytwd is offline
FRC #3574
sparkytwd will become famous soon enough
I'd just add that if you happen to get an MDL-BDC24, it will need to get flashed with the FIRST approved firmware
Unread 08-05-2014, 00:08
Only to use it with CAN. The stock firmware is perfectly fine for FIRST PWM operation.
