Re: 192 2014 Gearbox Parts
Nice parts. I see belts but I don't see any pulleys??
Snazzy. Is the shifter shaft hardened?
I remember one of our mentors dislike ball shifters, because his experience with them in the past has been that the balls wear out the inside of the output shaft. Can you cross-section it on one of the ball holes to see if that is the case? |
I'll try to get a picture of one of the ball cavities, but last I checked there was very little wear on the shaft and no visible wear on the balls. |
I meant the inside of the main shaft. I heard that the inside of the ball cavity can wear out.
Did you machine the output shaft with a 4th axis?
From what it looks like, all you'd need is a 3-axis mill and lathe. Turn the sucker down, mill the two holes and set up the piece in a rotary table to make the hex end.
#7
What was the rationale behind not adding more ball's for each gear to make engagement faster when you shift? Also, what is the benefit of adding ball bearings (my guess at what those depressions in the gears are for) as opposed to the bushings that VexPro sells with their ball shifter gears?
Thanks for posting these pictures; very useful into seeing how this great gearbox was made ![]() |
#8
I used bearings in the gears because they’re more efficient than the bushings. They are slightly bigger but that didn’t hinder the design very much. No problem! Just wait for next year's gearbox, we have big things in store. |
