Go to Post using CD to answer my question is not the way to get the "ALL-BINDING FIRST ANSWER." - rees2001 [more]
Unread 06-05-2014, 02:55
Rauhul Varma Rauhul Varma is offline
Drivetrain and Design Lead
FRC #0192 (GRT)
Rauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud of
192 2014 Gearbox Parts
Here are a few parts from our gearbox this year; these were run through all three of our competitions this year.
(All the images below can we found in full resolution at: http://imgur.com/a/eERy6)
Output Shaft (7075-T6 Aluminum)
44T Vex Pro Gear w/ Custom Shifter Bore
34T Vex Pro Gear w/ Custom Shifter Bore
Cluster Shaft (Vex Pro 1/2" Hex Stock)
24T Vex Pro Gear
Unread 06-05-2014, 02:56
FRC #0192 (GRT)
Re: 192 2014 Gearbox Parts
14T Vex Pro Gear
Shifter Shaft (4340 Steel)
Pneumatic Hub (6061-T6 Aluminum)
89T & 94T Belts (3mm Pitch 9mm Wide GT2)
Unread 06-05-2014, 04:14
Chowmaster4695 Chowmaster4695 is offline
Lathe Master
AKA: Jerry Wright
FRC #4695
Team Role: Tactician
Chowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond repute
Nice parts. I see belts but I don't see any pulleys??
Unread 06-05-2014, 10:04
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (MVRT)
Snazzy. Is the shifter shaft hardened?
I remember one of our mentors dislike ball shifters, because his experience with them in the past has been that the balls wear out the inside of the output shaft. Can you cross-section it on one of the ball holes to see if that is the case?
Unread 06-05-2014, 20:15
FRC #0192 (GRT)
The shifter shaft was not hardened as the prototype did not show enough wear to warrant hardening the shaft.
I'll try to get a picture of one of the ball cavities, but last I checked there was very little wear on the shaft and no visible wear on the balls.
Unread 06-05-2014, 21:57
asid61's Avatar
AKA: Anand Rajamani
FRC #1072 (MVRT)
I meant the inside of the main shaft. I heard that the inside of the ball cavity can wear out.
Unread 06-05-2014, 22:22
mman1506's Avatar
mman1506 mman1506 is offline
Hater of Tiny Molex Connectors
AKA: Marcus Quintilian
no team (WARP7)
Did you machine the output shaft with a 4th axis?
2016: FRC 865 Mentor
Unread 06-05-2014, 23:01
kitare102 kitare102 is offline
AKA: Eric
FRC #3042 (Cobalt Catalysts)
kitare102 is an unknown quantity at this point
From what it looks like, all you'd need is a 3-axis mill and lathe. Turn the sucker down, mill the two holes and set up the piece in a rotary table to make the hex end.
Unread 06-05-2014, 23:26
highlander's Avatar
highlander highlander is offline
Registered Boss
Team Role: Student
highlander has a spectacular aura abouthighlander has a spectacular aura abouthighlander has a spectacular aura about
What was the rationale behind not adding more ball's for each gear to make engagement faster when you shift? Also, what is the benefit of adding ball bearings (my guess at what those depressions in the gears are for) as opposed to the bushings that VexPro sells with their ball shifter gears?
Thanks for posting these pictures; very useful into seeing how this great gearbox was made
Unread 07-05-2014, 02:00
FRC #0192 (GRT)
We used a lathe to turn the counter and bore, then mounted the shaft in an indexer on a manual mill and made the ball cavities and the hex with 2 work holdings.
With a .625” OD this driveshaft is smaller than the drive shafts on the Vex Pro gearboxes. In addition it’s 7075 aluminum not hardened steel, so introducing a fourth ball could have made the shaft susceptible to shear failure. Even if the shaft was strong enough for a fourth set of balls, it would have taken too much time in analysis to prove for the marginal gain in shift speed.
I used bearings in the gears because they’re more efficient than the bushings. They are slightly bigger but that didn’t hinder the design very much.
No problem! Just wait for next year's gearbox, we have big things in store.
