Go to Post My rule of thumb is that any team who's won four World Championships can count their chickens whenever they want. :p - Karthik [more]
Unread 23-02-2003, 12:19
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
FINE. I'll tell you how to do it. Now, the rules clearly say, 4 sides at 90 degree intervals. Granted that your robot has at least 6 sides and you've got numbers on two sides, then the rules has an easy loophole. Just put one number on the top of your robot and one at the bottom. They are seperated by 90 degrees, are on 4 seperate sides, and your ROBOT is still easily identified by the referee as they should be able to easily see the number on the sides/top. The bottom one just allows you to get around the rules. Or if you have space, put one on the back and use the one on top as the loophole. That's a better method.
M7:
Robots must display their team number, sponsor and school names and/or logos. The judges, referees, and announcers must be able to easily identify robots by Team Number. Teams must display their Team Number in four locations at approximately 90-degree intervals around the side of the robot. The numerals must be at least 4 inches high, at least in ½ inch stroke width and in a contrasting color from its background. Team Numbers must be clearly visible from a distance of not less than 100 feet.
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 23-02-2003, 12:33
Clanat Clanat is offline
Custom Title
#0753 (High Desert Droids)
Clanat has a little shameless behaviour in the past
I think the rule is clear...
M7:
Former Co-Captain
Winner NW Regional 2002 and 2003
Unread 23-02-2003, 12:40
Yan Wang's Avatar
Ithaca is Gorges
AKA: John Wayne
Definition
Dictionary.com
side ( P ) Pronunciation Key (sd)
n.
1 Mathematics.
A line bounding a plane figure.
A surface bounding a solid figure.
2 A surface of an object, especially a surface joining a top and bottom: the four sides of a box.
After def 2, they don't relate to an object. But as you can see, the top is a side, and so is the bottom; side is just a surface. Don't they teach you this in your first geometry class?
If one were to take the rules completely literally, 'around the side' would mean we'd have to wrap the numbers around the side. But clearly that's not the case. Putting a number on top or bottom is still within the rules. The ref may yell at you but there's jack that he/she can do.
Unread 23-02-2003, 12:50
Jeremy_Mc's Avatar
Jeremy_Mc Jeremy_Mc is offline
GitHubber
Jeremy_Mc will become famous soon enoughJeremy_Mc will become famous soon enough
they have to be visible for atlesat 100 ft.
if they're on the bottom, they are not visible.
*jeremy
GitHub - Collaborate on code, documentation, etc. - http://github.com
Unread 23-02-2003, 13:15
Yan Wang's Avatar
Ithaca is Gorges
AKA: John Wayne
The bottom one will easily be seen if the robot flips over as did in the UTC match 8 video But the judges can't penalize you there. The numbers are visible from 100 feet away. Whether at all times is a different issue. Basically, for teams who can't get their numbers on all side, the top is a good side to use and the bottom is a last resort. I'm just trying to help those people who didn't read all the rules carefully.
Unread 23-02-2003, 19:55
uberchris uberchris is offline
#1028 (Ubergeeks)
uberchris is an unknown quantity at this point
Send a message via AIM to uberchris
READ
listin Hilly ALL ya have to do is READ READ READ ....
heheh
XGaNDaLFX
http://firstubergeeks.com/gallery/vi...d=team_pho to
LIVE FREE OR DIE
How to pass your inspection at Nationals, the EASY way Matt Reiland Championship Event 0 04-04-2003 18:39
What happens if your robot doesn't pass inspection? Tton General Forum 10 08-01-2003 21:50
The Case For 'Regionalizing' teams at the Nationals. archiver 2000 33 23-06-2002 23:35
