Go to Post I think being successful in FIRST is creating an environment where people can grow, learn, change, and recreate... It's about making an environment where kids feel they can be successful... in whatever discipline they choose. - ColleenShaver [more]
Unread 24-04-2014, 15:17
Zyrano Zyrano is offline
AKA: Alvin
FRC #1967
Zyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to behold
Send a message via AIM to Zyrano
Did anyone build an "active" goalie post?
So I threw this idea to a few teams that I worked with at the beginning, but it didn't fit with what the teams goals were. So I'm wondering, did anyone build an active goalie?
What I mean is to have a goalie pole that was mounted on either a piston or a motorized linkage that spins rapidly. This I feel should be within the rules but effectively enlarging the blocking zone by factor of 4-5x, maybe even utilize the 20inch per side beyond frame perimeter rule, and have it rotate in a 60inch diameter circle...
Did any team build anything like this? Was it effective?
W.R.R.F. Board member, 2007-??
Mentor, 2007-??, NDSJ Robotics FRC Team 1967
Mentor, 2013-15 Evasive Robotics FTC Team 6223
Supporter, 2006-11, Bulldogs Robotics FRC Team 581
Supporter, 2007-??, Pioneer HS Robotics FRC Team 668
Supporter, 2011-??, Dark Matter FRC Team 2643
Student, 1999- GRT FRC Team 192
Unread 24-04-2014, 18:13
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Re: Did anyone build an "active" goalie post?
you mean below the 5 ft height limit?
or do you mean that the 8 ft pole is on your 20" extension? I think it would be more effective to move the robot.
Unread 24-04-2014, 18:25
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
I am not sure if I understand this correctly but I think that a Q&A earlier this year stated that if the mechanism was in motion relative to your robot frame while it contacts an opponents ball then it is considered possession.
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 24-04-2014, 19:57
samfruth's Avatar
samfruth samfruth is offline
FRC #1710 (Ravonics Revolution)
Team Role: Driver
samfruth will become famous soon enough
You would be correct. Team 1710 has a defense "arm" that moves back and forth on rails, but not one that spins.
Unread 24-04-2014, 20:14
AKA: Alvin
FRC #1967
I meant above 5 feet, have the <6" cylinder pole on a spinning setup on a separate axis.
So was 1710's blocker deemed legal? or would was it illegal based on the Q&A ruling?
Unread 24-04-2014, 20:31
samfruth's Avatar
Team Role: Driver
1710 is able to use it. The pole is not in motion when the ball is being blocked.
Unread 07-05-2014, 10:46
pandamonium's Avatar
pandamonium pandamonium is offline
FRC #1836 (Milken Knights)
pandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond repute
On newton one of the goalie bots blocked the top of the low goal and I saw a ball resting between the robot and part of the low goal with out going in for about 30 seconds. No foul was called for possession because the opposing robot cant cause them to possess the ball. Just like you cant just spit into an opponents catcher. By the same logic the opposing robot is putting the ball into your mechanism so even if it is posetion it is not a foul...
Unread 07-05-2014, 11:23
pntbll1313's Avatar
pntbll1313 pntbll1313 is offline
2052 Coach, Build/Electrical Mentor
AKA: Pete
FRC #2052 (KnightKrawler)
pntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud of
That is why coaches need to know the rules and when to challenge. If they had a copy of Q&A 170 with them I believe they could have challenged.
Game - The Game » Game Rules
Q170 Q. Regarding possession of opposing alliance's ball: If a robot is attempting to score a 1-pt goal, if an appendage of a defending robot either a) holds the ball from dropping into the top of the goal or b) causes the ball to be "pinned" as it's pushed in the front goal, would it be illegal possession?
FRC4120 on 2014-01-18 | 10 Followers
A. Yes.
Published by GDC
2016 (mentor/drive-coach)
Quarter-Finalist-Einstein, Winner-Carson Division Champs, Winner-10K Lakes, Chairman's Award-10K Lakes, Finalists-Lake Superior,
Winner-MSHSL Robotics Competition
2015 (mentor/drive-coach)
Finalists-10K Lakes, Finalists-Lake Superior, Finalist-MSHL Robotics Competition, Quarter-Finalist-Galileo Division Champs
2014 (mentor/drive-coach)
Winner-10K Lakes, Winner-Lake Superior Winner-MSHSL Robotics Competition, Quarter-Finalist-Galileo Division Champs
2013 (mentor/drive-coach)
Winner-10K Lakes, Winner-Lake Superior, Winner-MSHSL Robotics Competition, Quarter-Finalist-Newton Division Champs
2012 (mentor/drive-coach)
Finalists-Lake Superior, Semi-Finalist-MSHSL State Championship, Semi-Finalists at 10,000 Lakes
2008-2011 (college mentor)
2007 (driver)
Quarter Finalist-Milwaukee
Unread 07-05-2014, 12:07
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
A. Yes.
Published by GDC
Darn, you beat me to it.
Unread 07-05-2014, 12:34
themccannman's Avatar
themccannman themccannman is offline
registered lurker
AKA: Jake McCann
FRC #3501
themccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond repute
973's goalie post actuated from one side of their frame to the other, but I don't think anyone had a goalie post that spun around the outside of their robot.
All posts here are purely my own opinion.
2011-2015: 1678
2016: 846
2017 - current: 3501
Unread 07-05-2014, 13:18
pntbll1313's Avatar
AKA: Pete
Good, that makes at least 2 coaches that were on Newton that would have challanged
2007 (driver)
Unread 07-05-2014, 13:29
Chris Endres Chris Endres is offline
play hard, work harder
AKA: Topher097
FRC #4096 (Ctrl-Z)
Chris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really nice
Although my team never implemented my idea of a goalie bot into our final design, I did, however, come up with a great goalie bot.
So, crab/swerve goalie bot with an extension.
Get in sideways, strafe to block (maybe auto-block), then get out to play as an offender.
Using this idea, we also thought that in auto, we can have an auto-detection of the autonomous balls, then predict their trajectory, and block the balls. This losses the 5 point bonus in the beginning, and any other possible scoring we may have been able to do, but it would be a game changer. If you block out at least 50% of the balls in auto, you are up in points, significantly at the start of teleop. Not to mention you also made it so that your opponents need to chase down the balls before starting an actual cycle.
Of course this bot will include a scorer, most likely a claw.
2009 FLL Illinois State Champions - iLEGO
2010 FLL Illinois State Champions - iLEGO
2011 FLL Illinois State 3rd Place - iLEGO
2011 FLL Illinois State 1st Ambassador - iLEGO
2013 FRC Milwaukee Regional Champions - WildStang
2016 FRC Midwest Regional Finalists - WildStang
Unread 07-05-2014, 13:54
AdamHeard's Avatar
Lead Mentor
Sooooo.... 1114, 469, 973?
Unread 07-05-2014, 15:51
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
This happened to us on Newton - Match Q130 by 1710 when our alliance (48) was trying to clear an autonomous ball. It was pinned above the low goal for about 23 seconds. It was called as an extended possession (50 point) foul. After it eventually dropped in the goal, with a little nudging by 48, it was scored for 1 point. Though I thought it should of been a possession foul and the ball should of been returned to the HP.
You can see the refs gathering by the goal to determine why the ball wasn't scoring at the 50 sec mark..
http://www.youtube.com/watch?v=L0F--bqMLug
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Hopper Division | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
Unread 07-05-2014, 18:08
AKA: Topher097
FRC #4096 (Ctrl-Z)
You forgot the swerve aspect.
