Go to Post Man, what's the point of teaser videos if nobody looks closely at them. - Knufire [more]
Unread 15-02-2003, 23:05
Duke 13370's Avatar
Duke 13370 Duke 13370 is offline
C is for cookie...
#0862 (Team Lightning)
Team Role: Webmaster
Duke 13370 will become famous soon enough
Send a message via AIM to Duke 13370
Argh!
This is for those teams that are using the drives and mounts provided by FIRST (using the drills).
Has anyone else tested these, because for us they dont seem to make it over the ramp very well without popping breakers. We have some serious problems now.
ARGH!
---Lightning Robotics!---
Unread 15-02-2003, 23:10
f22flyboy's Avatar
f22flyboy f22flyboy is offline
Distributor of Mayhem
#0540 (Rhythmic Disturbance)
f22flyboy will become famous soon enoughf22flyboy will become famous soon enough
We are, using a slightly modified version, and have had no problems.
First check your gearing- you may be geared to high. Also make sure that the drills are in low gear
Also check the alignment of your gears and wheels. Disconnect the drill from your gears and wheels, spin the wheel and see how long it spins. If you have a lot of rolling friction you may need to realign your wheels and grease the bearings and gears. If you are using the helical gears make sure they are well greased.
Godwin Robotics Association- Rhythmic Disturbance
Team 540 Forums
FIRST Look... FIRST Shot... FIRST Kill.
Unread 21-02-2003, 23:10
Onizuka's Avatar
Onizuka Onizuka is offline
Onizuka is an unknown quantity at this point
i think the problem that you are having is due to being geared too high. still check out alignments and what speed the drill is in, if its in high then change to low and if its in low check gearing.
otoko wa doko desu ka...
Unread 22-02-2003, 19:48
Pierson's Avatar
Pierson Pierson is offline
Pierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of light
Send a message via AIM to Pierson
We are using the drill motors on 40 Amp breakers in low gear with cool tracks. We didn't have any breaker popping.
http://www.chiefdelphi.com/forums/sh...threadid=18145
Pierson
Former Captain & Fundraiser of Team 360
Join in on these fun threads:
Three Worded Story
Word Association
Unread 22-02-2003, 20:41
Duke 13370's Avatar
C is for cookie...
we litterally have the basic drive train, we hooked up to the big 9*2 wheels, which may have somehting to do with it since they are different from your team's, but if first was so concerned with the one hour robot, why did they give us a drive train that can't make it over the hill with an underwieght (80lbs roughly) robot?
lubing it up may be all it needs, but we really can't do that now.
Unread 23-02-2003, 10:06
Onizuka's Avatar
could you clarifiy if your using just a direct drive(no gear reduction) or using something to reduce the gear ratio. If your not then the drill motors going to have a hard time with those wheels.
Unread 23-02-2003, 10:10
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Errr can someone tell me which position is low gear for the drill motors??????
Unread 23-02-2003, 10:18
Eric Reed Eric Reed is offline
I am somebody now!
#0481 (De Anza Robotics Team)
Eric Reed will become famous soon enoughEric Reed will become famous soon enough
Low position is when the collar on the transmission is pushed forward toward the output shaft.
You shouldn't have a problem getting over the ramp with the one hour transmission set to low. We can do it with our 130 lb bot, even with a small caster on the front (which is very inefficient on the mesh). We are using 9x2 wheels.
Eric.
Team 481
De Anza High School
Unread 23-02-2003, 10:24
Jim Jim is offline
no team (Mcibed)
Jim is an unknown quantity at this point
Send a message via AIM to Jim
Be sure the gears are lubricated with a sticky grease.
Turn the drivetrain by hand; sequentially removing items from the system. You may find one think mis-aligned that is causing the lion's share of binding
ALWAYS ALWAYS ALWAYS use a fresh, fully charged battery. V=IR, low volts and these new motors become "amp hounds".
When you hit the pits at your first regional, be prepared with a game plan to quickly and methodically approach this problem.
Good Luck
Steelkilt Lives!
Unread 23-02-2003, 11:10
Adam Y.'s Avatar
Adam Y.
no team (?????)
Thanks
Unread 23-02-2003, 11:13
Duke 13370's Avatar
C is for cookie...
We use the helical gearset in the black box first provided
Unread 23-02-2003, 13:03
Onizuka's Avatar
In your other thread that you posted in where you said you were capping the max power to the motors at 2/3. try giving full power to the motor and see if that helps.
Unread 23-02-2003, 13:33
Duke 13370's Avatar
C is for cookie...
Oh, yeah, that may help. If i remember correctly, though, we finnally set the speed max to the joystick wheel, but it's to late now.
Unread 23-02-2003, 13:37
DougHogg DougHogg is offline
Robot-A-Holic
FRC #0980 (The ThunderBots)
DougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud of
Are you sure that your transmissions are locked in low gear? As the earlier message said, the white collar should be pushed forward toward the front of the transmission (where the drive shaft comes out).
It might be a good idea to find yourself some smaller wheels, but be sure that you will still have enough clearance on the ramp.
Also what do you have on your other wheels? We were popping breakers in high gear (using the black motors) when we turned and found that we had to reduce side friction on two of the wheels by adding cable ties. (We have 4 wheel drive.) Basically we couldn't turn in place in high gear until we added the cable ties. Even then, we can't just sit there and spin in place for any length of time. The breakers start to pop.
FIRST Team 980, The ThunderBots
2002: S. California Rookie All Stars
2004: S. California: Regional Champion,
Championship Event: Galileo 2nd seed,
IRI: Competition Winner, Cal Games: Competition Winner
2005: Arizona: 1st seed
Silicon Valley: Regional Champion (Thanks Teams 254 and 22)
S. California: Regional Runners Up (Thanks Teams 22 and 968)
Unread 23-02-2003, 13:41
Duke 13370's Avatar
C is for cookie...
Yeah, we're sure, it may just have been a drained battery or something completly different that caused it, but i know the motors were locked in low. One of the other students (scuba_sm) found out how to lock the drives from the inside so they would never slip into high (or low, depending on how it's done), and it works very well.
My computer loves Microsoft ARGH!! HELP ME! team222badbrad Chit-Chat 12 29-01-2005 09:17
Should we bomb/strike Iraq MattK Chit-Chat 129 18-01-2003 21:15
Starting a team in Muncie, IN for Ball State University and the Indiana Academy Amanda Morrison General Forum 6 23-12-2002 03:10
Small Parts --- ARGH!!! archiver 2001 1 23-06-2002 23:33
who works? mike pawlak Chit-Chat 30 23-06-2002 15:12
