Go to Post And Dave...should I borrow someone's hair dryer from here in case the NASA truck needs some de-icing again this year? - Billfred [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Unread 09-05-2014, 13:44
AustinShalit's Avatar
AustinShalit AustinShalit is offline
AKA: אוסטין
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
[FRC Blog] 2015 Control System and Kit of Parts Survey
Blog Date:
Friday, May 9, 2014 - 12:42
Please see the blog post below for important information from our Kit of Parts team, Kate & Collin:
2015 FRC Control System
One of the exciting parts of the 2014 FIRST Championship was the ability to show off the new hardware components that will make up the 2015 FRC Control System. Members of the CS Team from FIRST, National Instruments, Cross the Road Electronics, and WPI also had the opportunity to take questions from the audience at two 2015 Control System presentations.
2015 CS Layout
2015 FRC Control System Layout
This graphic shows the basic layout of the 2015 FRC Control System. The roboRIO from NI replaces the cRIO, Analog Breakout, and Digital Sidecar. More specs on it can be found here. The Power Distribution Panel (PDP) is from Cross the Road Electronics and replaces the Power Distribution Board used from 2009-2014. The Pneumatic Control Module (PCM) is also from CTRE and replaces the Solenoid Breakout and Spike Relay required to drive the compressor. The PCM connects to the PDP via CAN. The PDP can connect to the roboRIO via CAN to allow current monitoring on each channel. The final new component is the Voltage Regulator Module (VRM), also from CTRE. This component allows access to different voltages to supply power to custom circuits, cameras, sensors, etc.
A chart comparing the 2014 and 2015 FRC Control Systems can be found here.
We’re looking for a wide variety of teams to help us test and develop, and test and develop, and test and develop the 2015 CS. Beta testing will run July through November 2014. Each beta test team will be loaned 2015 hardware to complete the testing. To apply to be a beta test team, please fill out the survey here. The deadline for filling out the application is May 25.
2014 KOP Survey
We’re interested in your feedback on the 2014 FRC Kit of Parts. This feedback is instrumental in pointing us in the direction of new parts for potential inclusion in the 2015 KOP. Last year, more than 1400 people filled out the KOP Survey. This feedback is sent to Suppliers to help them make the best use of their donation. Please have one student and one mentor fill out the 2014 KOP Survey here.
http://www.usfirst.org/roboticsprogr...tem-KOP-Survey
Unread 09-05-2014, 13:46
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Re: [FRC Blog] 2015 Control System and Kit of Parts Survey
There aren't any Victors in that diagram.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 09-05-2014, 14:01
Ginger Power's Avatar
Ginger Power Ginger Power is online now
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
That was my first thought as well! I really hope that's not an indication that Victors are not compatible!
Unread 09-05-2014, 14:02
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
I'm assuming it's just kind of assumed, and you can replace a talon with a Victor.
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 09-05-2014, 14:05
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
I'm so looking forward to the roboRIO just for the update to Java 8.
Unread 09-05-2014, 14:06
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
When the equivalent diagram for the cRIO came out, there weren't any CIMs in the diagram, and people got real worried about that as well. I wouldn't read too much into it.
Unread 09-05-2014, 14:25
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
So many fun features that we'll finally have access to.
Any post that I make expresses only my opinions. I do not represent the opinions of my team or of any entity affiliated with my team.
As a Mentor:
2016 - Engineering Inspiration at Greater Pittsburgh Regional
As a Driver:
2014 - Winner of Greater Pittsburgh Regional
Unread 09-05-2014, 14:27
Flywheel Police
The two I'm looking forward to the most are ENUMs and Generics. It's amazing how much you take them for granted when they've been around for so long. Having access to Maps will also be nice for things like property readers.
Unread 09-05-2014, 14:45
Pratik Kunapuli's Avatar
Pratik Kunapuli Pratik Kunapuli is offline
Probably browning-out on Astro-Turf
FRC #1648 (G3 Robotics)(EWCP)
Pratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to all
Nor any CAN enabled Talons
Official Driving Record: 101-59-0
2012-2015 Student 341 Miss Daisy
2015-Current Mentor 1648 G3 Robotics
Unread 09-05-2014, 14:48
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
No keys on the laptop either! Touchscreens only
Unread 09-05-2014, 15:06
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
The new pneumatic breakout looks awesome. The ability to control and integrate the pressure switch and compressor without programming is going to help a lot of younger teams get up and running.
Unread 09-05-2014, 15:32
ayeckley's Avatar
ayeckley ayeckley is offline
AKA: Alex Yeckley
FRC #2252 (Mavericks)
ayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond repute
I guess I'm not wild about the fact that what we used to be able to accomplish in three modules (cRIO, PDB, Digital Sidecar) now takes four (roboRio, PDP, PCM and VRM). I get that it's less expensive overall and that each of the components is physically smaller, but it's not a slam-dunk improvement in terms of the architecture. I guess CAN (and all of the benefits and drawbacks thereof) is now mandatory if a team wants to use pneumatics.
I'm also a bit surprised that the Bridge/Access Point is USB-based. When I saw the pre-Alpha unit at NI Week last year it wasn't obvious that this was the route they would go.
I guess it is what it is...
Unread 09-05-2014, 15:42
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is online now
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
We ended up with 4 in the old system once you account for the voltage regulator for the radio anyway. This system should allow teams that don't need regulated voltage or pneumatics to only use the RoboRIO and PDP.
Unread 09-05-2014, 15:50
Electronica1's Avatar
Electronica1 Electronica1 is offline
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
One advantage of more modules is that if one of them breaks it is cheaper to get it replaced.
Unread 09-05-2014, 15:55
StAxis's Avatar
StAxis StAxis is offline
Mentor/Drive Coach
AKA: Zach CH
FRC #1902 (Exploding Bacon)
StAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud of
I certainly hope that the red cypress board being in the picture means that the driver station software will be readily compatible with it next year.
