| Thread Tools |
Rating:
Display Modes |
Turns out Helical Beam Couplers aren't meant to handle that much stress . . .
Or should I say, this particular coupler from China isn't meant to handle so much stress.
We have been trying to dampen some of the vibration caused by a huge lead screw that we use to raise and lower our ball holder. Mounting with grommets and the like helped some, but still the vibration was intense and the noise was horrendous. So I had the bright idea to get some Helical Couplers and see if they couldn't absorb some of the movement. Unfortunately, I was wrong: https://drive.google.com/file/d/0B5a...it?usp=sharing |
Re: Turns out Helical Beam Couplers aren't meant to handle that much stress . . .
You are relying on them to provide bearing support to the leadscrew (via the CIMs bearings) and they are not designed to do that. The end of the leadscrew should be in bearings properly in some structure, the CIM bolting to that, and then coupled with the beam coupler. The helical portion of the coupler then just handling shaft misalignment. They're also not really good at dampening vibration as they are intended to be stiff. |
Unfortunately, our team does not have a Mechanical Engineer of any sort. Us computer guys learn as much as we can about mechanical operation and actuators, but the finer points are sometimes missed. While it never actually failed, it could certainly be improved, so thanks for the input. Quote:
Generally in industrial applications the lead screw will be turned down at each end so that it can sit on a thrust bearing package. In my plant, we then drive them with a timing belt.
An easy way to do that is to get a shaft collar that fits over the threads and pin it in place. Then you don't have to machine down the end. http://img.directindustry.com/images...84-4327425.jpg http://gallery.nibou.com/albums/LINE...w_Supports.jpg Your system is putting a huge amount of axial load into the motor shaft directly. They aren't made to support that type of load. |
For FRC applications, we had success with using a coupling nut (http://www.mcmaster.com/#93023a661/=rw83fu) welded to the lead screw. The 1/2" hex interfaces well with a lot of FRC components, making it very easy to drive. We supported the lead screw on each end with thrust and ball bearings. Our lead screw was ~18" long and flexed a bit since we didn't load it evenly, but the setup did a good enough job of isolating the screw from everything else to be very reliable.
We used this in 2010 on our kicking mechanism. |
Those couplers are also not able to manage that much misalignment.
#7
The interesting challenge with building a support system for the leadscrew is that, because the leadscrew does not stay stationary as the ball holder is raised, the support system would have to be mounted only to the motor and the leadscrew itself. It might make a good off-season project.
Right, it wasn't intended to. Like I said above, I added this in hopes that it would absorb some of the vibration and noise, not to make the system perfect. |
#8
Where does you team purchase beam couplings? I had the impression that helical beam couplings generally ran >$25, and I'd love to know where you can get them for less.
#9
I'm interested to know the quality difference between the ones we got and a $45+ coupler from McMaster. Last edited by Monochron : 12-05-2014 at 09:51. |
#10
You can keep the leadscrew stationary and use a simple linkage to translate the linear motion of the lead screw to a rotational motion.
#11
These beam couplings are really good for coupling rotational sensors with drive shafts so that small misalignments won't damage the sensor. we use them in our swerve drives to couple the Magnepot Hall Effect Potentiometer which provides us with drive angle measurements for each of our wheels. These couplings are absolutely wonderful and work flawlessly in this application. A photo of the installed coupling is provided:
http://wiki.team1640.com/index.php?t...0209_csm-2.jpg On the other hand, they won't hold up to very high torque (use Lovejoy couplings for this), massive misalignments or huge angular displacements (use flex joints here). They also cannot be used as the device which keeps everything aligned by itself. The movie was entertaining, though. |
#12
Oh wow, that's clever. Thanks for sharing that.
#13
That's really awesome. Did you end up using that mechanism in your robot this year? I wish I had seen some like that at competition.
#14
#15
Also here is test of the tilt too.
http://youtu.be/78J20Rpzcw4?t=17s |
