Go to Post Robot teams will expand to fill the available space. - topgun [more]
Unread 09-05-2014, 16:41
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Turns out Helical Beam Couplers aren't meant to handle that much stress . . .
Or should I say, this particular coupler from China isn't meant to handle so much stress.
We have been trying to dampen some of the vibration caused by a huge lead screw that we use to raise and lower our ball holder. Mounting with grommets and the like helped some, but still the vibration was intense and the noise was horrendous. So I had the bright idea to get some Helical Couplers and see if they couldn't absorb some of the movement.
Unfortunately, I was wrong:
https://drive.google.com/file/d/0B5a...it?usp=sharing
Unread 09-05-2014, 16:45
AdamHeard's Avatar
Lead Mentor
Re: Turns out Helical Beam Couplers aren't meant to handle that much stress . . .
You are using these incorrectly.
You are relying on them to provide bearing support to the leadscrew (via the CIMs bearings) and they are not designed to do that. The end of the leadscrew should be in bearings properly in some structure, the CIM bolting to that, and then coupled with the beam coupler. The helical portion of the coupler then just handling shaft misalignment. They're also not really good at dampening vibration as they are intended to be stiff.
Unread 09-05-2014, 17:29
Monochron's Avatar
Engineering Mentor
As Gregor mentioned, yes we are aware that lead screws operate less than optimally when they are not supported on both ends. It performed exactly as intended with our original coupler in competition though and the only issue we ever had when when the lead screw got a little bent. It still worked well, the vibration just drastically increased.
Unfortunately, our team does not have a Mechanical Engineer of any sort. Us computer guys learn as much as we can about mechanical operation and actuators, but the finer points are sometimes missed. While it never actually failed, it could certainly be improved, so thanks for the input.
Maybe they are intended to be stiff, but they are bendable by hand. If it was as stiff as I expected maybe it would not have deformed as much and taken the vibration a little better?
Unread 09-05-2014, 17:31
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Generally in industrial applications the lead screw will be turned down at each end so that it can sit on a thrust bearing package. In my plant, we then drive them with a timing belt.
An easy way to do that is to get a shaft collar that fits over the threads and pin it in place. Then you don't have to machine down the end.
http://img.directindustry.com/images...84-4327425.jpg
http://gallery.nibou.com/albums/LINE...w_Supports.jpg
Your system is putting a huge amount of axial load into the motor shaft directly. They aren't made to support that type of load.
Unread 09-05-2014, 17:36
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
For FRC applications, we had success with using a coupling nut (http://www.mcmaster.com/#93023a661/=rw83fu) welded to the lead screw. The 1/2" hex interfaces well with a lot of FRC components, making it very easy to drive. We supported the lead screw on each end with thrust and ball bearings. Our lead screw was ~18" long and flexed a bit since we didn't load it evenly, but the setup did a good enough job of isolating the screw from everything else to be very reliable.
We used this in 2010 on our kicking mechanism.
--Madison--
...down at the Ozdust!
Unread 09-05-2014, 22:26
DonRotolo's Avatar
Back to humble
FRC #0832
Those couplers are also not able to manage that much misalignment.
Unread 11-05-2014, 15:02
Monochron's Avatar
Engineering Mentor
The interesting challenge with building a support system for the leadscrew is that, because the leadscrew does not stay stationary as the ball holder is raised, the support system would have to be mounted only to the motor and the leadscrew itself. It might make a good off-season project.
Originally Posted by Madison View Post
For FRC applications, we had success with using a coupling nut (http://www.mcmaster.com/#93023a661/=rw83fu) ...
Yeah, we use with one very similar to that, a little shorter and different diameter and TPI. We were bounded mostly by funding and really wanted to avoid paying $14 for the nut when the leadscrew itself was so expensive.
Right, it wasn't intended to. Like I said above, I added this in hopes that it would absorb some of the vibration and noise, not to make the system perfect.
Unread 12-05-2014, 08:42
hzheng_449 hzheng_449 is offline
AKA: Harrison Zheng
FRC #0449 (Blair Robot Project)
hzheng_449 will become famous soon enough
Where does you team purchase beam couplings? I had the impression that helical beam couplings generally ran >$25, and I'd love to know where you can get them for less.
Unread 12-05-2014, 09:48
Monochron's Avatar
Engineering Mentor
We got them for $6 from China on eBay. Shipping takes about a month (and is free), but as long as you plan ahead properly and commit to buying early then you can save a huge amount of money. In fact, I don't think a single fastener on our robot came from outside of China (aside from KOP and Vex ones obviously). Paying Lowes or Fastenal prices for anything other than stock metal just wasn't in the budget for us.
I'm interested to know the quality difference between the ones we got and a $45+ coupler from McMaster.
Unread 12-05-2014, 12:49
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
You can keep the leadscrew stationary and use a simple linkage to translate the linear motion of the lead screw to a rotational motion.
Name:	2262 leadscrew.jpg
ID:	16996  Click image for larger version
Name:	2262 leadscrew2.jpg
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 12-05-2014, 17:11
Clem1640's Avatar
Clem1640 Clem1640 is offline
Head Mentor
AKA: Clem McKown
FRC #1640 (Sab-BOT-age)
Clem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond repute
These beam couplings are really good for coupling rotational sensors with drive shafts so that small misalignments won't damage the sensor. we use them in our swerve drives to couple the Magnepot Hall Effect Potentiometer which provides us with drive angle measurements for each of our wheels. These couplings are absolutely wonderful and work flawlessly in this application. A photo of the installed coupling is provided:
http://wiki.team1640.com/index.php?t...0209_csm-2.jpg
On the other hand, they won't hold up to very high torque (use Lovejoy couplings for this), massive misalignments or huge angular displacements (use flex joints here). They also cannot be used as the device which keeps everything aligned by itself.
The movie was entertaining, though.
Clem McKown
Head Mentor - FRC 1640 & FTC 7314
Chairman - Downingtown Area Robotics
Unread 13-05-2014, 00:38
Oblarg Oblarg is offline
AKA: Eli Barnett
Oh wow, that's clever. Thanks for sharing that.
"The breakfast of champions!"
Unread 13-05-2014, 10:51
Monochron's Avatar
Engineering Mentor
That's really awesome. Did you end up using that mechanism in your robot this year? I wish I had seen some like that at competition.
Unread 13-05-2014, 11:29
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Yes, that entire thing was mounted onto the robot.
https://www.youtube.com/watch?v=N_gfnubBvvU
Kevin Li
596 - Sciclones
Unread 13-05-2014, 11:43
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Also here is test of the tilt too.
http://youtu.be/78J20Rpzcw4?t=17s
Kevin Li
596 - Sciclones
