Go to Post The scent of a smoking Globe motor is familiar to many. - Alan Anderson [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
  #31   Spotlight this post!
Unread 09-05-2014, 19:34
magnets's Avatar
magnets magnets is offline
Re: [FRC Blog] 2015 Control System and Kit of Parts Survey
Then use a spike relay off one of the relay ports. If you feel you need more than 4 spikes, some of the general purpose digital i/o can be set up to run relays (probably).
I was told at St. Louis that we would not be able to use the normal I/O for the relays. They did say that the setup they had there was not the final one, so the new one might be able to do that.
  #32   Spotlight this post!
Unread 09-05-2014, 20:36
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Originally Posted by magnets View Post
My biggest dislike is the lack of relay ports. We usually don't use pneumatics besides for shifting, so we never have a compressor on board. If we use one spike for shifting drive (so we don't have to buy a $90 board that is way more complicated than it needs to be), then we only have three spikes left for motors. We usually use at least that many.
Is there a any particular reason you're using spikes instead of Victors/Talons for the motors? The only time I think we've used a spike over a motor controller was when we temporarily maxed out our PWMs outputs. Given that the new RIO allows for 20 PWMs, I don't see this being an issue.
  #33   Spotlight this post!
Unread 09-05-2014, 20:47
magnets's Avatar
Yes. The spike costs half as much as the victor.
  #34   Spotlight this post!
Unread 09-05-2014, 21:04
Jefferson Jefferson is offline
AKA: Jeff Clements
FRC #0016 (Bomb Squad)
Jefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond repute
I charge my pneumatics with a relay that is many years old. I buy a single $34.95 relay for shifting. I would not like to purchase $180 worth of pneumatics boards, instead, I would like to purchase 1 new spike relay for use on the competition robot, and use an older relay for our practice robot. That is spending 5 times as much money to accomplish the same task. In my personal opinion, providing CAN functionality to the pneumatics board is too complicated.
Ah. I see what you are saying.
I'd say you are in the minority in using pneumatics, not wanting to use a PCM, and using more than 2 relays. NI / CTRE built the system for the majority of users and yours seems like a pretty signicant edge case.
CAN on the PCM is 2 wires using reliable connectors and the programmer is blind to its application. Not really complicated.
  #35   Spotlight this post!
Unread 09-05-2014, 22:55
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Without reading the 2015 rules, you will not know if you can run the compressor with a spike or if you will have to use the compressor port.
  #36   Spotlight this post!
Unread 10-05-2014, 09:48
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Originally Posted by Tom Line View Post
<snip>
For anyone who wants to get involved and see the stuff 'before December', by all means sign up for the Beta testing and be part of the solution. The more experienced teams who test, the better. Keep in mind though that part of being a Beta team means holding a seminar for other teams, so none of the information comes as a shock to anyone.
I dug around a bit trying to find the Beta Signup Page. No Joy. Can someone please point me to it?
Thanks,
Joe J.
Team #88, TJ2
  #37   Spotlight this post!
Unread 10-05-2014, 10:00
Joel Glidden's Avatar
Joel Glidden Joel Glidden is offline
My heart pumps diesel.
FRC #4293 (Komodo)
Joel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of light
Beta Sign Up
-Joel
  #38   Spotlight this post!
Unread 10-05-2014, 19:46
JamesTerm's Avatar
JamesTerm JamesTerm is offline
Terminator
AKA: James Killian
FRC #3481 (Bronc Botz)
JamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to behold
I just wanted to highlight the words "get involved" as in actually investing time in testing and having more activity in the beta forums etc. We'll need to step it up more than ever... For example, I'm still somewhat frustrated about the SmartDashboard lockup bug that was never found during beta testing... grant it... it was hard to reproduce, but that's where the beta program comes in... testing over and over again.. to increase chances of finding the intermittent bugs.
  #39   Spotlight this post!
Unread 10-05-2014, 23:18
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
This in going to be a lot of fun
Can't wait to see what the USB radio will entail and also those USB camera's (Hint Hint: Kinect on robot)
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
  #40   Spotlight this post!
Unread 06-12-2014, 12:42
DaveFrederick's Avatar
DaveFrederick DaveFrederick is offline
FRC #1895
DaveFrederick is a jewel in the roughDaveFrederick is a jewel in the roughDaveFrederick is a jewel in the rough
Can anyone provide information on the USB Radio? What manufacture or model number? I am not familiar with this interface.
  #41   Spotlight this post!
Unread 06-12-2014, 12:45
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
The USB radios didn't work as well as hoped. Beta test teams are using the old D-Links.
  #42   Spotlight this post!
Unread 06-12-2014, 18:29
It was an Asus N53. It worked well in isolation and with Windows drivers. The "fun" began when multiple of them were operating at the same time to the same channel with the linux drivers. They stepped all over one another and applying various patches didn't make them that much better.
With driver fixes, it is really nice because it can be mounted wherever you want by using an extension cable and it is about the size of the new motor controllers.
Greg McKaskle
