| Thread Tools |
Rating:
Display Modes |
#31
Re: [FRC Blog] 2015 Control System and Kit of Parts Survey
I was told at St. Louis that we would not be able to use the normal I/O for the relays. They did say that the setup they had there was not the final one, so the new one might be able to do that.
#32
I'd say you are in the minority in using pneumatics, not wanting to use a PCM, and using more than 2 relays. NI / CTRE built the system for the majority of users and yours seems like a pretty signicant edge case. CAN on the PCM is 2 wires using reliable connectors and the programmer is blind to its application. Not really complicated. |
#35
Without reading the 2015 rules, you will not know if you can run the compressor with a spike or if you will have to use the compressor port.
#36
Thanks, Joe J. |
#37
#38
#39
This in going to be a lot of fun
![]() Can't wait to see what the USB radio will entail and also those USB camera's (Hint Hint: Kinect on robot) |
#40
Can anyone provide information on the USB Radio? What manufacture or model number? I am not familiar with this interface.
#41
Beta test teams are using the old D-Links. |
#42
It was an Asus N53. It worked well in isolation and with Windows drivers. The "fun" began when multiple of them were operating at the same time to the same channel with the linux drivers. They stepped all over one another and applying various patches didn't make them that much better.
With driver fixes, it is really nice because it can be mounted wherever you want by using an extension cable and it is about the size of the new motor controllers. Greg McKaskle |
