Go to Post I have long since given up on these hints, and come to the conclusion that they are designed to befuddle us all and amuse Dave. - Rickertsen2 [more]
Unread 10-05-2014, 11:03
ArzaanK ArzaanK is offline
FRC #1325 (Inverse Paradox)
ArzaanK is an unknown quantity at this point
Recommended Sensors
Hello Chief Delphi
This off season, our team is looking into doing various projects. One thing that we would really like to get done is making use of sensors such as encoders, potentiometers and gyroscopes.
Our team has never had much luck with sensors. The extent of our sensor use was a hall effect sensor to measure shooter RPM last year, and a limit switch to tell us when our catapult was retracted. We tried to use Greyhill 63R encoders last year, but with no luck. (1114 and 2056 tried to help us get them working at GTR East last year, with no avail).
This off season, we have had some luck with the old KOP Gyroscope/Accelerometer sensor to detect our robots rotation.
Our main question is, what kind of sensors do you recommend? We've browsed many websites looking for encoders, potentiometers and gyro's but we are lost on which ones work the best.
If you could tell us what kind of encoders you use on drive trains and shooters, the potentiometers you use and the gyro's you use, why you use them, and how they have worked for you, we would really appreciate it.
Thanks,
Arzaan Khairulla
Programmer/Driver
2013 Greater Toronto Regional East Winners with 1114 and 2056
2013 Galileo Division
Unread 10-05-2014, 11:16
Re: Recommended Sensors
lots of good information here: http://www.chiefdelphi.com/forums/sh...d.php?t=120597
Unread 10-05-2014, 11:25
hzheng_449 hzheng_449 is offline
AKA: Harrison Zheng
FRC #0449 (Blair Robot Project)
hzheng_449 will become famous soon enough
For encoders, this year 449 used a US digital H6 Ball bearing encoder (512 CPR) for our drive train, and it worked magically. We like it because it's a heavy duty encoder that is far more robust than the KOP E4P, and it's pretty easy to install.
Last for our last year's robot, our team used both a potentiometer and the KOP accelerometer on our robot. For potentiometers you can basically use any run of the mill 1-10K pot, as long as you can find a way to attach a shaft to it. Also, the KOP gyros and sensors aren't terrible. If you want something better then you could try out a COTS IMU (I Know sparkfun has a few).
Also as a note for analog sensors, you might also want to experiment with various filtering methods to reduce signal noise. Both hardware methods (ie simple low pass filter) and software (LabView is great for this).
Unread 10-05-2014, 12:36
NWChen's Avatar
NWChen NWChen is offline
Alum
NWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to behold
For quick and dirty sensing our team has had a good experience with anything VEX, largely because of their robustness and ease of mounting and wiring. The ultrasonic rangefinder, limit switch, and bumper switch all required very little work (assuming things like female-female PWMs were on hand).
As mentioned earlier, any 1K to 10K-ohm potentiometer should work well. You can use a shaft coupling to attach it to a shaft.
2012 - 2015 • Team 2601
Unread 11-05-2014, 14:48
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
The main question comes down to what do you want to sense, and then how do you do that.
We've had good luck with the KOP Gyro/Accel, but are looking at alternatives due to cost.
For quadrature encoders, we typically use the US Digital ones from andymark, but would not be averse to finding alternatives due to how fragile the connector is. Absolute encoders have varied. Below are two other sensors we used this year and where we bought them. We also use SparkFun as a source.
Light/Dark Sensor (SEN0019) DFRobot.com
IR Distance Sensor (GP2Y0A21YK0F) Adafruit.com
Unread 12-05-2014, 17:23
Clem1640's Avatar
Clem1640 Clem1640 is offline
Head Mentor
AKA: Clem McKown
FRC #1640 (Sab-BOT-age)
Clem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond repute
That's the key question. What do you want to sense?
For our swerve drive, we need to know absolute angle: 360 degrees and stop-less. We use BI Technologies Magnepot Hall Effect Potentiometer Part # 6127V1A360L.5FS to do this. The analog sensor works very well and is ~$11 ea.
Clem McKown
Head Mentor - FRC 1640 & FTC 7314
Chairman - Downingtown Area Robotics
Unread 12-05-2014, 19:02
Tyler2517's Avatar
Tyler2517 Tyler2517 is offline
ShortOnes
AKA: Tyler Gibb
FRC #2517 (Evergreen Robotics)
Tyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura about
It depends a lot on what you are doing. Along with accurate do you need to be.
For instance when we started redesigning out swerve drive we sat down and listed all of the sensors we would want / have to use.
1. Steering encoder (absolute ,continuous)
2. Drive encoder (quadrature)
3. Gyro for field based control.
4. Limit switch to auto home swerve.
Unread 12-05-2014, 20:56
One Eyed Man
To give a bit more background, our 2012 Rebound Rumble robot was... interesting. We used the following sensors:
Axis M11 Camerax2
Hall effect x1
Proximity Sensor x3
Light/Dark sensor x1
IR Prox Switch x1 (from LogoMotion)
Limit Switch x1
Encoder x2
Absolute Encoder x1 (analog)
Ultrasonic Rangefinder x2
I think we maxed out all the DIO on the sidecare that year, and I'm pretty sure I'm missing at least some sensors.
Unread 12-05-2014, 21:29
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Axis M11 Camerax2
Hall effect x1
Proximity Sensor x3
Limit Switch x1
Encoder x2
Sounds awesome! Lets try and guess what they were for.
Axis M11 Camerax2
Vision tracking and a ball pickup camera.
Hall effect x1
Shooter feedback
Proximity Sensor x3
Ball sensors?
Limit Switch x1
Turret soft stop
Encoder x2
Drivetrain
Turret feedback
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 13-05-2014, 09:46
Hugh Meyer's Avatar
Hugh Meyer Hugh Meyer is offline
FRC #1741 (Red Alert Robotics)
Hugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud of
Here is a link to a sensor presentation I have done at worlds in 2013 and Purdue. It shows several types and explains how to wire them.
http://rar.meyermat.net/workshops/sensors/index.html
-Hugh
Unread 15-05-2014, 09:01
One Eyed Man
Originally Posted by Gregor View Post
Sounds awesome! Lets try and guess what they were for.?
Axis M11 Camerax2
- Distance/angle to Target using binocular vision. Ball Pickup is something we're looking at adding now that we have an example to work from. We used this system as (at the time) it provided better accuracy & noise rejection over using one.
Hall effect x1
Shooter feedback
- Correct
Proximity Sensor x3
Ball sensors?
- Correct. We used this for managing the balls in the robot. We maintained positive control & position knowlege over all three at all times through the use of a state machine.
- Used for telling us when our turrent was in the home position.
- We used this at the front of the ball intake to let us know when a new ball was coming in. The proximity sensors were further up the system, and with the three ball limit we wanted to ensure we never possessed a fourth.
Limit Switch x1
Turret soft stop
- We had a "spear" that would come down for lowering the bridge. It was used as a softstop for that.
Encoder x2
Drivetrain
- Correct.
Turret feedback
- Correct, although we would loop it and had to add code which would note this. Our turret had a range of about 3 full encoder revolutions.
- Ball Detection.
