Thread Tools |
Rating:
Display Modes |
Re: Custom bushings
Re: Custom bushings
It's a turret for a t-shirt cannon. Basically, the actual barrel rotates on something like what the arms this year had (stright piece up + angled claw) to be able to aim and shoot better. It's also practice for future years.
It doesn't weigh that much but due to the design which incorporates bevel gears, there is a large bushing on the bottom coaxial with a shaft going to a bevel gear to rotate the barrel up and down independent of the module's rotation. So the turret experices very slow radial loads in the 100rpm range but around 30lbs axial. The load is on the flange of said bushing. I looked into ball bearings in the 3" range, but they all cost more than $100. I also cannot design for this bearing to be smaller due to some interesting design issues that have to deal with a cim mounted to the bottom of this turret. |
Re: Custom bushings
Could you modify the design to use this? http://www.andymark.com/product-p/am-2714.htm
Re: Custom bushings
You could try using a set up like 1640 uses for their swerve drive. It can support huge amounts of weight and take a good hit. Its also pretty compact. Just mount it upside down? It uses a thrust bearing to handle the axial loads and a very large bearing to handle radial loads.
Re: Custom bushings
The igus slewing rings would work for this. They are just so intriguing - someday I'm sure we'll find the perfect use for the one we have.
They have been available from FIRST Choice some years. |
Re: Custom bushings
Slewing rings sounds interesting, but they are a little big. Last edited by asid61 : 11-05-2014 at 02:03. |
#7
Re: Custom bushings
I've used 2 tapered roller bearing for turntables before. You could probably go down to 3/4" shaft size. Weight I assume is not an issue.
#8
Re: Custom bushings
A great material for bushings is UHMW (Ultra High Molecular Weight Polyethylene).
We used this extensively, not only on the robot but at work for many bearing applications. It is very easy to machine, has a very low coefficient of friction and can withstand significant loads for a plastic. You can get rods from McMaster fairly cheap. |
#9
Re: Custom bushings
Another thing to consider if you can wait I would research different suppliers, Mc Master Carr is the fastest and arguably the best but not always the cheapest. PS "All inexpensive" is a relative statement. |
#10
Re: Custom bushings
The thing is, the bushing looks pretty strange, and I can't really change the design at this stage (it follows an ultra-space-saving design that requires its weirdness). Basically I changed the design so it can use a smaller bearing, which is like 7/8" inner diameter and 1.125" outer diameter. However, it has a very large flange that's around 2" outer diameter. I'll look into using plastics for machining and cost without sacrificing strength. I've used UHMW in the past, but we tend to have a lot of acetal so I'll try that on aluminum too.
#11
Re: Custom bushings
Re: Custom bushings
This approach would change your design the least. Any timken or ball bearing for a shaft of that size would have a very large OD, and would require you to modify your design accordingly. -Adrian |
#13
Re: Custom bushings
These handle competition loads really well (we have had no service needed to our original 4 pivots during the entire competition season comprising 70 matches overall), but the diameters are a lot smaller than what you were looking for in your original posting. BOM's and CAD files are available: http://wiki.team1640.com/index.php?title=Swerve_Central |
#14
Re: Custom bushings
http://www.ebay.com/itm/$@#$@#$@#-6215-2RSR-C3-Deep-Groove-Ball-Bearing-75mm-Bore-130mm-Outside-Diameter-New-/390838773352?pt=BI_Heavy_Equipment_Parts&hash=item 5affce6668 |
#15
Re: Custom bushings
The problem is there are some holes machined in the flange of the bearing. The main bearing is 2" OD, but the flange is 3". I need the huge flange for mounting holes to other stuff. |
