Go to Post It certainly shows to never give up, even if all you can do is score a single tetra. - Joe Ross [more]
Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Unread 11-05-2014, 01:59
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Custom bushings
Originally Posted by Tyler2517 View Post
You could try using a set up like 1640 uses for their swerve drive. It can support huge amounts of weight and take a good hit. Its also pretty compact. Just mount it upside down? It uses a thrust bearing to handle the axial loads and a very large bearing to handle radial loads.
Sounds interesting. As I said though, because this is pretty low-budget (we have other stuff to work on too) I wanted to avoid ball bearings.
Slewing rings sounds interesting, but they are a little big.
Unread 11-05-2014, 08:02
Gdeaver Gdeaver is offline
FRC #1640
Re: Custom bushings
I've used 2 tapered roller bearing for turntables before. You could probably go down to 3/4" shaft size. Weight I assume is not an issue.
Unread 11-05-2014, 10:25
David Guzman's Avatar
David Guzman David Guzman is offline
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
Re: Custom bushings
A great material for bushings is UHMW (Ultra High Molecular Weight Polyethylene).
We used this extensively, not only on the robot but at work for many bearing applications. It is very easy to machine, has a very low coefficient of friction and can withstand significant loads for a plastic.
You can get rods from McMaster fairly cheap.
Team 1251 The Techtigers
2010 FL Regional Winner (BIG thanks to 86 and 1612)
2009 FL Regional Finalist (BIG thanks to 79 and 744)
2008 FL Regional Winner, FL GM Industrial Design, SC GM Industrial Design
2007 FL Regional Winner, FL GM Industrial Design, Palmetto Regional Finalist, Palmetto Motorola Quality.
2006 Palmetto Regional Winner, Daimler Chrysler Team Spirit Award
2005 FL Regional Judges Award, FL Regional 3rd seeded and finalist, Palmetto Regional Xerox Creativity Award, Palmetto Regional 1st seeded and finalist
2004 UCF Regional Rookie All-star Award
Unread 11-05-2014, 19:53
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
Re: Custom bushings
I would say +1 to UHMW, Delrin (Acetal Resin), or Nylon 6. All inexpensive all great bearing surfaces.
Another thing to consider if you can wait I would research different suppliers, Mc Master Carr is the fastest and arguably the best but not always the cheapest.
PS "All inexpensive" is a relative statement.
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 13-05-2014, 22:39
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Custom bushings
The thing is, the bushing looks pretty strange, and I can't really change the design at this stage (it follows an ultra-space-saving design that requires its weirdness). Basically I changed the design so it can use a smaller bearing, which is like 7/8" inner diameter and 1.125" outer diameter. However, it has a very large flange that's around 2" outer diameter. I'll look into using plastics for machining and cost without sacrificing strength. I've used UHMW in the past, but we tend to have a lot of acetal so I'll try that on aluminum too.
Unread 14-05-2014, 00:11
highlander's Avatar
highlander highlander is offline
Registered Boss
Team Role: Student
highlander has a spectacular aura abouthighlander has a spectacular aura abouthighlander has a spectacular aura about
Re: Custom bushings
In my experience Delrin machines really easily, while UHMW has a much lower coefficient of friction. However, UHMW is annoying to machine.
Unread 11-05-2014, 13:19
Adrian Clark Adrian Clark is offline
FRC #1678 (Citrus Circuits)
Adrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the rough
Re: Custom bushings
Using bearing for this application might be a little easier on your wallet than you think. 2'' ID thrust bearings are around $5, all you need is one on the top to handle the weight of the turret, one below to lock the whole thing together and some kind of bearing surface in between to handle radial loads. If you do this, since the top of the bushing is no longer a bearing surface you would only need for the inside of the bushing to be slick. This means that you could make a tube (aluminum, delrin, whatever strength is required for mounting) and put a sleeve bushing inside. A 2'' ID sleeve bushing can be bought from mcmaster for around $10. Or simply make the tube out of delrin and use that as your inner bearing surface.
This approach would change your design the least. Any timken or ball bearing for a shaft of that size would have a very large OD, and would require you to modify your design accordingly.
-Adrian
