| View Poll Results: 2015 - What would you like to see in 2015's point system? | |||
| No change: Continue to use foul points to penalize rule breaking. |
34 | 45.33% |
| Sport style: Points must be earned. Penalty in other form (time-based,free-throw,etc) |
22 | 29.33% |
| VRC style: Replace tech fouls with yellow/red card system. |
17 | 22.67% |
| Others: Comment below. |
2 | 2.67% |
| Voters: 75. You may not vote on this poll | |||
| Thread Tools |
Rating:
Display Modes |
2015 - What would you like to see in next year's point system?
Share your thoughts in the poll and get your creative juices going... I have captured a few approaches discussed previously as options. Last edited by billylo : 10-05-2014 at 22:54. |
Re: 2015 - What would you like to see in next year's point system?
Sports style would be great, however I think it would either add more time/match or be on one extreme of the strong/weak spectrum. One way you could do it would be to add a "free throw" or something similar, but this would make matches longer. The other option would be disable fouling robots, but this would allow weak teams to commit as many fouls while punishing elite teams more. I think the best solution is the yellow/red card system because if you commit a foul, then you are penalized and not your partners. There is no reason to make a team lose a match because their alliance partner put their hand into the field or their goalie stick bent out of the six inch cylinder. These should be punished, just not to the alliance partners as well.
If you do not want people to foul, you must make it a big enough penalty for them to not want to foul. Take basketball for instance, I think that the "intentional" fouls at the end of games for time strategy reasons is kinda ridiculous.
In this game, if the robot pin and ball herding fouls were not so large it would have happened more and in fact been a large part of teams strategies. As it was, there was a lot of teams "accidentally" bumping the ball and some flagrant pins that helped them win games when refs were distracted this year because it was something you could do with relatively low risk. If it is either get caught with a questionable foul and loose the match or do it and win and possibly not get the foul, there are a lot of people who will take that chance. Even though it isn't in the spirit of friendly competition, if strategically it works, people will do it to win. I can even hear the arguments from those people already in my head "with a sports style game the robot should be designed to overcome pinning and blocking, either maneuver or push through blocking and shooting over or around other robots; basically that the other teams just need to design and learn to drive better". I think the yellow/red card style is the only way you could do it fairly, but since those are currently for egregious actions, I think those should still stay that way. If we stay with a sports style of play, I think a similar system could be used for regular fouls in a way to penalize one team without penalizing the alliance. Have penalties called out with penalty points assigned to the offending team, if they add up over a certain amount during the competition, then they give a negative QP for that team. One or two incidental fouls would not affect any given team either. Could even be used as a tie breaker stat. During quals, the penalty points total and any negative QP would affect the overall standings, making people definitely not want commit fouls and would only affect one team. This could even factor through to district/regional/world rankings to have meta game implications. No one would intentionally commit fouls and would even try to avoid fouls because there would be a huge negative incentive. |
Theoretical change to Aerial Assist in the vein of "sports style fouls"-what if some fouls were changed from point values to pedestal delays? |
Of course, for some alliances, that wouldn't be an issue. I know I reffed at least one match where the alliance didn't finish clearing their auto balls. |
Yellow card/red card can also result in qualification point deduction for the offending team only during qualifications.
#7
kidding Some sort of "x strikes and you're out" system might be worth exploring. Certain fouls are assigned certain point values, with yellow cards being equivalent to at least 51% of foul points rounded up to the nearest whole number, and red cards equivalent to 100% of the total foul points. When you reach x foul points, you forefit all possible points for the match, excluding the foul points you earn (this means QS and every other sorting statistic). After you "foul out" of a match, your foul-out counter is reset but the foul statistic is carried on through the competition as a sorting metric. The foul point system would reset itself for eliminations, but you gather points for whole alliances. The biggest pro is that this system wouldn't negatively affect alliance partners who can't control your robot, but the biggest con is that this could result in an increase of quasi-intentional fouls as part of a strategy if not ket in check. |
#8
Maybe have fouls incorporated more heavily in ranking system by adding an additional column that would weigh down team on the amount fouls they commit ( I forget if this system is already implemented) but I think a sports foul would more appropriate for a game like this years, but it all depends on the game.
#9
Might not be a bad idea, except that a by-team ANYTHING is just about impossible in the rankings currently, so aggregate fouls would have to be used. Then you get the whole "my partners stink at clean play why do I have to suffer" debate. If used, I'd call it the 2nd tiebreaker: lowest foul points committed. |
#10
Though, if something like the sports-style penalty were to be implemented, it can't have a irrecoverable effect. For example, in soccer, a penalty kick can easily decide a game because of the low scoring nature of the game. It does take a large infraction to initiate a PK, but still something to think about nonetheless when you aren't able to be responsible for an alliance partner's mistake.
#11
First of all, I think we should make it so that the FMS requires refs to enter which team(s) commited every foul. Then, I would say that during quals, you subtract a certain ammount from the offending team's qual score for the match. An example system for scoring would be:
+10 for a win +5 for a tie -1 for a foul -3 for a tech foul For any given match, you cannot earn a negative qual score (eliminates embarrassing negative overall scores and makes it so that you can't ruin your chances of ranking high with 1 really bad match). For elims, go back to the current style, only subtract points from the offending team's score. I understand that we have it add to the other team's score to reduce scores of 0 and make teams feel less self-conscious about committing the foul, but in elims that shouldn't be a problem, and I am annoyed of having to preface every conversation about good scores with "penalty free." The score you get should be the score you earn. |
#12
The way games seem to be made now is that a concept is developed and then anywhere from a month to a year is spent thinking of all of the holes in the concept and "patching" those holes with penalties either too subjective to accurately predict or too objective to be flexible.
The problem needs to be dealt with earlier - use the design of the game to incentive the kind of play you wish to see. Don't just make it a penalty to play a certain way - make playing that way a dumb idea for other reasons. Protected zones limit penalties to certain, obvious areas of the field and seem to incentivise offense effectively. Fouls are going to be a part of any game design at this point, but putting more active thought into them throughout the process and figuring out how to make a game that just doesn't need that many fouls is key. |
#13
I would be on board with sports-style fouls, but in most sporting models, that involves stoppage of play or extended periods after the 'end' of the match. I don't think adding complexity to the timing of matches is a good thing for competitive robotics games. |
#14
All fouls which do not affect fair play should move to the yellow card / red card system. If the violation does not give a competitive advantage to the alliance then penalize the offending team only in a way that reminds them what the infraction was. Many safety violations are already handled this way like G1 and G2. Really wish G40 had been handled this same way.
Some additional candidates. G16 - Crossing the white line too early after auto. G21 - Robot momentarily extends outside field boundary. G24 - Robot extending more than 20" beyond frame perimeter, especially in the instances when something on the robot breaks loose, but does not break free. G39 - Stepping outside of the marked team areas. |
#15
I'd prefer to see a game that does not need to use fouls/penalties to ensure that it is played as envisioned by the GDC. Adding fouls to the game is a last resort for when game design, field design, and robot/inspection rules cannot adequately constrain the gameplay on the field.
Momentary "your robot/foot/hand crossed an invisible line and you gained no advantage from it" fouls should be warnings and not penalties, like Aaron pointed out. All fouls (and hopefully there aren't many of them) should be announced with the final scores, including the team number(s) that incurred the fouls. Always. Otherwise, it is hard to scout. Foul points make for a really controversial first tiebreaker, and just about anything else should be more heavily weighted (since a large percentage of foul calls involve some subjectivity). |
