Go to Post Because, y'know, FIRST can't make it easy for us. - WinterPoet [more]
Unread 13-05-2014, 00:17
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
Ball Shifter Force Requirements
As an offseason project, I'm considering developing a non-pneumatic shifter for the Vex Pro ball shifters. It would seem that the pneumatic cylinders supplied with the kit provide more than enough force to use reliably, and servo setups have been attempted a few times without success. Somewhere in the middle is the tipping point between sufficient force and not enough.
Has anyone collected data on how much force is required to engage the ball shifter under load?
Has anyone used a non-pneumatic means of shifting the ball shifters that they'd like to share?
Unread 13-05-2014, 00:20
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Re: Ball Shifter Force Requirements
think 67 used window motors one year
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 13-05-2014, 00:42
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
For the ball shifter they have not, for the dog setup they have.
R.C.
MadTown Robotics Team 1323
Unread 13-05-2014, 00:50
geomapguy's Avatar
Centenary '18
AKA: Graham Maxwell
FRC #1818
ah yes true
Unread 13-05-2014, 00:58
TheHolyHades1 TheHolyHades1 is offline
TheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the rough
I saw this idea in another thread, but along the same vein, would it be possible to use an electric solenoid in order to shift? I know FRC places a lot of regulations on the types of solenoids allowed, but if the force requirement isn't excessive it may be possible.
Unread 13-05-2014, 01:14
highlander's Avatar
highlander highlander is offline
Registered Boss
Team Role: Student
highlander has a spectacular aura abouthighlander has a spectacular aura abouthighlander has a spectacular aura about
What application will this ball shifter be for? I knew teams this year that used it for a winch mechanism, for which the pancake cylinder provided (3/4" bore, 1/2" stroke) was not enough force. I'm going to go ahead and assume drivetrain, though.
The main reason that a lot of teams use pneumatics is because they are very quick. Shifting with a window motor or servo wouldn't be ideal since motors don't store energy, so it could take a lot of time to shift. An added consequence of that would be offset between left and right gearboxes in shifting, something you don't want.
Aside from that if your heart is set on motor shifting, Andymark has made a shifter that I would look at to see how they shift with servos: http://www.andymark.com/product-p/am-sonicoptions.htm.
Unread 13-05-2014, 01:22
T^2 T^2 is online now
FRC #5499
We observed (anecdotally) that at our true top speed of 17.1ft/s (tested under 60fps camera) with a 3-CIM ballshifter, we had trouble shifting at less than 50-55psi. Our robot weight was about 135lbs; feel free to do the rest of the math.
Unread 13-05-2014, 01:51
craigboez's Avatar
Mechanical Engineer
This is great info. Not encouraging, since I was hoping the cylinders had a lot more safety factor, but good to know.
F = P x A, so that works out to about 25 lbs-f. Anyone else have data to support this?
Unread 13-05-2014, 02:17
Rauhul Varma Rauhul Varma is offline
Drivetrain and Design Lead
FRC #0192 (GRT)
Rauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud ofRauhul Varma has much to be proud of
I don't know how much this helps, but our custom ball shifter engages correctly with less than 10 lbf pulling/pushing the shifter shaft. That being said we have a 45 deg taper on our shifter vs Vex's ~60 deg (iirc) taper.
Actuator Details:
Bimba Flat 1
7/16" Bore, 3/8" Throw limited to ~.28"
Engaging from 45 to 60 psi
Last edited by Rauhul Varma : 13-05-2014 at 02:31. Reason: Added details on the actuator
Unread 13-05-2014, 09:36
craigboez's Avatar
Mechanical Engineer
Out of curiosity, is there a need for being able to shift at top speed or was this done just as an experiment? It would seem that to be useful, a shifter will need to shift a) once low speed has maxed out and you want to go to high speed and b) in a pushing match in high speed, when you want to drop down to low speed to limit current. I can't see a use case for downshifting from high speed at top speed.
Unread 13-05-2014, 09:42
craigboez's Avatar
Mechanical Engineer
Actuator Details:
Bimba Flat 1
Thats interesting, thanks for the info. What made you choose 45 degrees vs 60? Was your shifter also modified so that the balls were closer together? The Vex shifters are spaced apart by 0.5" so the full cylinder stroke travel is required.
Unread 13-05-2014, 09:56
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Anecdotal, but our winch this year required 50+ PSI with the provided pancake cylinder in order to shift properly while under load. We did some playing around with working pressure in order to find the "sweet spot" for each of our mechanisms to avoid wasting too much air (mostly with our pickup arm, as that used a ton of air when compared to the pancake cylinder!)
2016: Lake Superior WFFA
Unread 13-05-2014, 12:17
FRC #0192 (GRT)
Since it was my first time designing a ball shifter and I wasn't sure the design decisions that led Vex to choose the 60 deg angle, I went with the 45 deg angle as a safer alternative. (As 192 prefers to use the smallest actuators possible.)
The ball cavity spacing is the same (I've never actually looked at that value before today), however the stroke is shorter because I designed our shifter shaft to engage in different positions along the shaft for each gear.
Name:	Screen Shot 2014-05-13 at 8.59.27 AM.png
