Thread Tools |
Rating:
Display Modes |
Re: Calibrate Pressure Switch?
Adjusting or attempting to adjust the switch to a higher pressure is a huge wast of time. If anything you want a switch that shuts of and turns back on at a lower pressure. The compressor will thank you with building up less heat over time and getting it back up to pressure quicker. Take a look at the rated outputs of compressors the lower the pressure it is working against the higher the cfm. Or take a look at your gauge when you fill the system from empty you'll find the rate of increase in stored pressure decreases dramatically as the stored pressure rises.
Has anyone actually done the math? How much more storage volume conversion at 60 psi do you get with 110 psi stored in two tanks as opposed to 120 psi? Assume that the regulator is the same efficiency at both pressures, and that the compressor efficiency doesn't matter.
Life is always more complicated than that. In our case, the minimum useful pressure was 100 psi because that is what it took to consistently shoot the ball. What was important for us was that the compressor turned on before then. 120 psi would have been useful for precharging before the match, but 110 was good for during the match. We also went with minimal on board air storage to keep the recharge time low. So I largely agree with Mr V about what is a good set pressure. |
