Go to Post we came together, worked our butts off, and eventually looked at failure and decided....its just not our style. - Monochron [more]
Unread 13-05-2014, 17:08
AlecS AlecS is offline
FRC #1323 (Madtown Robotics)
AlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond repute
Re: 2-Speed vs 1-Speed drivetrain
The voltage the battery outputs is proportional to the amperage being drawn, and the resistance of the circuit. This is also known as ohm's law.
V=IR
Although batteries are not always perfect voltage sources, you can use ohm's law to determine the voltage drop in your robot fairly accurately. If you were drawing 300 amps, and the total circuit resistance was .020 ohms, you would lose 6 volts. This does not fluctuate over time, it is directly related to the current being drawn. (ignoring temperature and other factors). Hopefully this clears things up.
Alec S.
Engineer - Sales Representative, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 13-05-2014, 17:33
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
V=IR
I'm not an engineer (yet), but doesn't this calculation have to be related back to the capacity of the battery somehow? When drawing, say, 5 amps, intuition tells me some tiny lead-acid battery would have a much larger drop in voltage than a huge deep-cell marine battery would. Maybe I'm rusty with my basic electrical physics, but with V=IR, if you had a 300 amp draw with .02 ohms, that would mean that you must be drawing from a 6 volt source (or be in series such to draw 6 volts), not "losing" 6 volts. Our applications are of course done in parallel however on the robot, so series is not an option. If we know the current draw and resistance of the whole circuit like you said, then we solve for our voltage across the whole circuit. I'm thinking the theoretical voltage drop of the battery under load is another calc entirely. I'm simply raising a concern, not saying this it absolutely correct. I'd love to be educated otherwise if someone has a good explanation.
Here, they relate a voltage drop on current draw to a capacity fraction.
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
AdamHeard's Avatar
Lead Mentor
Originally Posted by dellagd View Post
I'm not an engineer, but doesn't this calculation have to be related back to the capacity of the battery somehow? When drawing, say, 5 amps, intuition tells me some tiny lead-acid battery would have a much larger drop in voltage than a huge deep-cell marine battery would.
A larger battery will have a lower resistance, causing less of a voltage drop.
Unread 13-05-2014, 18:12
DampRobot's Avatar
Physics Major
AKA: Roger Romani
V=IR
So, theoretically, we should be designing to maximize power out of our battery as well as out motors? IE load the battery such that V^2/R is maximized when you think you'll need the most power as possible (pushing matches).
-Plutarch
Unread 13-05-2014, 19:03
I'm not exactly sure what you mean here, as the electrical power output of the battery increases as more current is drawn. Regardless of the power though, if you are in a pushing match, your main concern would be amperage. With DC brushed motors, torque is proportional to current. Gearing slower gives you more torque for the same current, or less current for the same torque.
IMO, it would be better to focus on reducing resistance on the robot. At 300 amps, each extra milli-ohm is .3 volts. Just a few extra milli-ohms to the robot can make the difference between brownout and not. Also relevant here is acceleration in high speed robots. Since increased resistance means less current for a given voltage and current=torque, a few milli-ohms can mean a decent drop in the available torque for acceleration.
Alec S.
